jag installerade Ubuntu 9,10 igår efter installation.
Jag får inte funka min grafikort;
Jag har följande inställning på min dator;
här är output på lspci -v
00:00.0 Host bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 03)
Subsystem: Micro-Star International Co., Ltd. Device 5770
Flags: bus master, fast devsel, latency 0
Memory at e0000000 (32-bit, prefetchable) [size=64M]
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE Host-to-AGP Bridge (rev 03)
Flags: bus master, 66MHz, fast devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 00009000-00009fff
Memory behind bridge: e4000000-e5ffffff
Prefetchable memory behind bridge: d0000000-dfffffff
Kernel modules: shpchp
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at b800 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at b000 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at b400 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 02) (prog-if 20)
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at e8000000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 82)
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: e6000000-e7ffffff
Prefetchable memory behind bridge: 30000000-300fffff
00:1f.0 ISA bridge: Intel Corporation 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge (rev 02)
Kernel modules: iTCO_wdt, intel-rng
00:1f.1 IDE interface: Intel Corporation 82801DB (ICH4) IDE Controller (rev 02) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at f000 [size=16]
Memory at 30100000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 02)
Flags: medium devsel
I/O ports at 0500 [size=32]
Kernel modules: i2c-i801
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro]
Subsystem: ATI Technologies Inc Device 0002
Flags: bus master, stepping, 66MHz, medium devsel, latency 32, IRQ 16
Memory at d0000000 (32-bit, prefetchable) [size=128M]
I/O ports at 9000 [size=256]
Memory at e5000000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at e4000000 [disabled] [size=128K]
Kernel modules: radeon, radeonfb
01:00.1 Display controller: ATI Technologies Inc Radeon R350 [Radeon 9800 Pro] (Secondary)
Subsystem: ATI Technologies Inc Device 0003
Flags: stepping, 66MHz, medium devsel
Memory at d8000000 (32-bit, prefetchable) [disabled] [size=128M]
Memory at e5010000 (32-bit, non-prefetchable) [disabled] [size=64K]
02:0a.0 Multimedia audio controller: Creative Labs CA0106 Soundblaster
Subsystem: Creative Labs Device 100a
Flags: bus master, medium devsel, latency 32, IRQ 22
I/O ports at a000 [size=32]
Kernel driver in use: CA0106
Kernel modules: snd-ca0106
02:0c.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Micro-Star International Co., Ltd. Device 577c
Flags: bus master, medium devsel, latency 32, IRQ 23
I/O ports at a400 [size=256]
Memory at e7000000 (32-bit, non-prefetchable) [size=256]
[virtual] Expansion ROM at 30000000 [disabled] [size=64K]
Kernel driver in use: 8139too
Kernel modules: epl, 8139too, 8139cp
02:0d.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev 80) (prog-if 10)
Subsystem: Micro-Star International Co., Ltd. Device 577d
Memory at e7001000 (32-bit, non-prefetchable) [size=2K]
I/O ports at a800 [size=128]
Kernel driver in use: ohci1394
Kernel modules: firewire-ohci, ohci1394
Module Size Used by
binfmt_misc 8356 1
snd_ca0106 34240 5
snd_ac97_codec 101216 1 snd_ca0106
ac97_bus 1532 1 snd_ac97_codec
snd_pcm_oss 37920 0
snd_mixer_oss 16028 1 snd_pcm_oss
snd_pcm 75296 3 snd_ca0106,snd_ac97_codec,snd_pcm_oss
snd_seq_dummy 2656 0
snd_seq_oss 28576 0
snd_seq_midi 6432 0
snd_rawmidi 22208 2 snd_ca0106,snd_seq_midi
snd_seq_midi_event 6940 2 snd_seq_oss,snd_seq_midi
snd_seq 50224 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 22276 5 snd_pcm,snd_seq
snd_seq_device 6920 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
snd 59204 17 snd_ca0106,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
soundcore 7264 1 snd
snd_page_alloc 9156 2 snd_ca0106,snd_pcm
serio_raw 5280 0
ppdev 6688 0
lp 8964 0
parport 35340 2 ppdev,lp
iptable_filter 3100 0
ip_tables 11692 1 iptable_filter
x_tables 16544 1 ip_tables
shpchp 32272 0
usbhid 38208 0
8139too 22620 0
8139cp 19260 0
mii 5212 2 8139too,8139cp
ohci1394 29900 0
ieee1394 86596 1 ohci1394
radeon 636000 2
ttm 36212 1 radeon
drm 159584 4 radeon,ttm
i2c_algo_bit 5760 1 radeon
intel_agp 27484 1
agpgart 34988 3 ttm,drm,intel_agp
drwxr-xr-x 9 root root 4096 2009-10-28 22:05 .
drwxr-xr-x 131 root root 12288 2009-11-01 15:54 ..
drwxr-xr-x 2 root root 4096 2009-10-28 22:04 app-defaults
drwxr-xr-x 2 root root 4096 2009-10-28 22:04 cursors
-rw-r--r-- 1 root root 14 2009-10-28 22:05 default-display-manager
drwxr-xr-x 6 root root 4096 2009-10-28 22:00 fonts
-rw-r--r-- 1 root root 17394 2009-06-23 00:57 rgb.txt
lrwxrwxrwx 1 root root 13 2009-10-29 18:38 X -> /usr/bin/Xorg
drwxr-xr-x 3 root root 4096 2009-10-28 22:04 xinit
drwxr-xr-x 2 root root 4096 2009-10-28 21:55 xkb
drwxr-xr-x 2 root root 4096 2009-10-28 21:56 Xresources
-rwxr-xr-x 1 root root 3730 2008-06-25 04:05 Xsession
drwxr-xr-x 2 root root 4096 2009-10-28 22:05 Xsession.d
-rw-r--r-- 1 root root 265 2008-06-25 04:05 Xsession.options
-rw-r--r-- 1 root root 13 2009-08-25 02:37 XvMCConfig
-rw------- 1 root root 601 2009-10-28 21:56 Xwrapper.config
Tack
Remo
