Nu vill jag antingen ta bort det integrerade och köra med sweex, eller få endast det integrerade att funka.
Är ganska så nybörjare så det behövs ingående förklaringar.
mikko@mikko-laptop:~$ sudo lshw -c network
[sudo] password for mikko:
*-network:0
description: Wireless interface
product: RT2500 802.11g Cardbus/mini-PCI
vendor: RaLink
physical id: 11
bus info: pci@0000:00:11.0
logical name: wmaster0
version: 01
serial: 00:10:60:60:b8:51
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list logical ethernet physical wireless
configuration: broadcast=yes driver=rt2500pci latency=64 module=rt2500pci multicast=yes wireless=IEEE 802.11bg
*-network:1
product: ULi 1689,1573 integrated ethernet.
vendor: ALi Corporation
physical id: 1b
bus info: pci@0000:00:1b.0
logical name: eth0
version: 50
serial: 00:40:d0:7f:86:68
capacity: 100MB/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=uli526x driverversion=0.9.3 duplex=full ip=192.168.0.140 latency=128 link=yes maxlatency=40 mingnt=20 module=uli526x multicast=yes port=MII speed=100MB/s
*-network DISABLED
physical id: 2
logical name: pan0
serial: ba:a7:f7:f8:49:41
capabilities: ethernet physical
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A link=yes multicast=yes
maj08
Utgåva: 8.10 Intrepid
* Personligt meddelande
* E-post
