Brasero ger felmeddelande, men DVDn blir rätt ändå [LÖST]
mildred80
Inlägg av mildred80 »
När jag bränner en DVD från en ISO i Brasero så avslutas det hela med ett felmeddelande och en del av ett utdrag från loggen kan se ut såhär:
Checking session consistency (brasero_burn_check_session_consistency burn.c:1905)
BraseroBurnURI called brasero_job_get_action
BraseroBurnURI called brasero_job_set_output_size_for_current_track
BraseroBurnURI stopping
BraseroBurnURI called brasero_job_get_session_output_size
BraseroBurnURI output set (IMAGE) image = /tmp/brasero_tmp_ICIWYU.bin toc = none
BraseroBurnURI called brasero_job_get_current_track
BraseroBurnURI called brasero_job_get_input_type
BraseroBurnURI no burn:// URI found
BraseroLocalTrack called brasero_job_get_action
BraseroWodim called brasero_job_set_current_action
BraseroWodim got varg:
	wodim
	-v
	dev=/dev/sr0
	speed=18
	-dao
	fs=16m
	-data
	-nopad
	/home/kristoffer/torrent/Das.Boot.DirectorsCut.1981.PAL.DVDr-CLASSiC/das.boot.dc.iso
BraseroWodim Launching command
BraseroWodim called brasero_job_get_fd_out
BraseroWodim stderr: wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.scsidev: '/dev/sr0'
BraseroWodim called brasero_job_get_flags
BraseroWodim stderr: devname: '/dev/sr0'
BraseroWodim stderr: scsibus: -2 target: -2 lun: -2
BraseroWodim stderr: Linux sg driver version: 3.5.27
BraseroWodim stderr: Wodim version: 1.1.9
BraseroWodim stderr: SCSI buffer size: 64512
BraseroWodim stderr: Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
BraseroWodim stderr: communication breaks or freezes immediately after that.
BraseroWodim stdout: TOC Type: 1 = CD-ROM
BraseroWodim stdout: Device type    : Removable CD-ROM
BraseroWodim stdout: Version        : 5
BraseroReadom stderr: addr:   164352 cnt: 64
BraseroReadom called brasero_job_get_output_type
BraseroReadom stderr: addr:   164416 cnt: 64
BraseroReadom stderr: addr:   164480 cnt: 64
Det skumma är att DVDn blir helt okej att titta på etc, inget att klaga på där. Men det är lite frustrerande att alltid få detta meddelande som jag inte riktigt förstår. Någon som kan hjälpa mig?
I övrigt kan jag också nämna att jag tycker att bränningen i sig själv tar lite onödigt lång tid. Vet ej om det är relaterat till detta dock.
Tack!
//KP
Pink Panther
Re: Brasero ger felmeddelande, men DVDn blir rätt ändå
Inlägg av Pink Panther »
Brasero lider fortfarande av lite små fel som åtgärdas efterhand som nya versioner kommer. Brasero blir säkert mycket bra efterhand som utveckling framskrider.
Jag vill föreslå följande program GnomeBaker som ett alternativ.
How to Burn a CD’s/DVD’s in Ubuntu Linux.
http://www.ubuntugeek.com/how-to-burn-a ... linux.html
Pink Panther
Linux Mint 18 Sarah
mildred80
Tack för förslaget. Jag tänkte att eftersom Brasero verkar vara lite standard i Ubuntu så är det det man ska använda. Men jag ska testa detta istället.
