Körde igång totem via terminalen och får detta:
x-inimus@servern:~$ totem
/var/lib/python-support/python2.6/gdata/tlslite/utils/cryptomath.py:9: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
import sha
The program 'totem' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadAlloc (insufficient resources for operation)'.
(Details: serial 100 error_code 11 request_code 132 minor_code 19)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Har testat vlc men det är samma resultat:
[????????] x11 video output error: X11 request 132.19 failed with error code 11:
X Error of failed request: BadAlloc (insufficient resources for operation)
Major opcode of failed request: 132 (XVideo)
Minor opcode of failed request: 19 ()
Serial number of failed request: 81
Current serial number in output stream
Har ju inte direkt det bästa grafikkortet i den här burken om det kan vara det som är problemet? Det är ett inbyggt intel tror jag.
