WLAN ZyXEL ag-220
Anton Fosselius
WLAN ZyXEL ag-220
Inlägg av Anton Fosselius »
har lite problem med att få mitt nya ZyXEL ag-220 att fungera..
efter endel strul så värkar ndiswrapper fungera.
ndiswrapper -l
Installed drivers:
wlanagg         driver installed, hardware present
sudo dmesg | grep wlan
[17179589.256000] ndiswrapper: driver wlanagg (ZyXEL Communications Corp.,05/29/2006,3.4.0.0) loaded
[17179589.768000] wlan0: vendor: 'ZyXEL AG-220 Wireless USB Adapter'
[17179589.768000] wlan0: ethernet device e0:db:d6:d9:e0:db using NDIS driver wlanagg, 0586:3412.F.conf
[17179589.768000] wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
[17179589.788000] ndiswrapper: changing interface name from 'wlan0' to 'wlan1'
[17179766.768000] ndiswrapper: device wlan1 removed
[17179770.368000] ndiswrapper: driver wlanagg (ZyXEL Communications Corp.,05/29/2006,3.4.0.0) loaded
[17179770.880000] wlan0: vendor: 'ZyXEL AG-220 Wireless USB Adapter'
[17179770.880000] wlan0: ethernet device c4:9b:a8:de:c4:9b using NDIS driver wlanagg, 0586:3412.F.conf
[17179770.880000] wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
[17179770.992000] ndiswrapper: changing interface name from 'wlan0' to 'wlan1'
[17179934.160000] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[17180322.608000] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[17181625.520000] ndiswrapper: device wlan1 removed
[17181633.404000] ndiswrapper: driver wlanagg (ZyXEL Communications Corp.,05/29/2006,3.4.0.0) loaded
[17181633.916000] wlan0: vendor: 'ZyXEL AG-220 Wireless USB Adapter'
[17181633.916000] wlan0: ethernet device c4:9b:a8:de:c4:9b using NDIS driver wlanagg, 0586:3412.F.conf
[17181633.916000] wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
[17181634.028000] ndiswrapper: changing interface name from 'wlan0' to 'wlan1'
[17181634.164000] ADDRCONF(NETDEV_UP): wlan1: link is not ready
EDIT:
nu har jag fått upp wlanet :D gick att aktivera det grafiskt.
men nu har jag problem med att erhålla ipadress ifrån routern.
det är ingen säkerhet eller kryptering på nätet.
ifconfig wlan1 (har ingen wlan0 :/)
wlan1     Link encap:Ethernet  HWaddr C4:9B:A8:DE:C4:9B
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
sudo iwlist wlan1 scan
wlan1     No scan results
har wlan routern 5m ifrån usb dongeln.
och har en likadan dongel på andra datorn som fungerar fint.
WLAN Information
- Name(SSID) : router
- Channel : 6
- Security Mode : No Security
/etc/network/interface
auto wlan1
iface wlan1 inet dhcp
wireless-essid router
wireless-channel 6
wireless-mode managed
https://help.ubuntu.com/community/WifiDocs
EDIT 17: ..
hittar inga fel. men hittar inget nät heller :S
något är värkligen knas här..
1. led:en på wlan dongeln lyser bara i 2sec sen slocknar den.
2. wlan dongeln hittar inte wlan routern
3. wlan dongeln heter wlan1 :S
Ubuntu Linux
Robotic Fantastic
“Those who desire to give up freedom in order to gain security, will not have, nor do they deserve, either one.”
