Problem att få in Catalyst 9.3 på Ubuntu 8.10
Chrilleee
Inlägg av Chrilleee »
Har precis installerat Ubuntu 8.10 (Finns inga drivrutiner alls för mitt grafikkort, x800GTO2, till 9.04an). Men när jag nu skulle installera Catalyst 9.3 så får jag följande i loggen:
[Message] Kernel Module : Trying to install a precompiled kernel module.
[Message] Kernel Module : Precompiled kernel module version mismatched.
[Message] Kernel Module : Found kernel module build environment, generating kernel module now.
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.GCC* .??* *.symvers
make -C /lib/modules/2.6.27-14-generic/build SUBDIRS=/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.27-14-generic'
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
In file included from /lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:169:
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.h:164:1: warning: "PM_EVENT_SUSPEND" redefined
In file included from include/asm/apic.h:4,
                 from include/asm/smp.h:13,
                 from include/linux/smp.h:28,
                 from include/linux/topology.h:33,
                 from include/linux/mmzone.h:683,
                 from include/linux/gfp.h:4,
                 from include/linux/kmod.h:22,
                 from include/linux/module.h:13,
                 from /lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:91:
include/linux/pm.h:267:1: warning: this is the location of the previous definition
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function ‘KCL_MEM_VM_GetRegionPhysAddrStr’:
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3223: warning: return makes pointer from integer without a cast
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3224: warning: return makes pointer from integer without a cast
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3225: warning: return makes pointer from integer without a cast
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3227: warning: return makes pointer from integer without a cast
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_acpi.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_agp.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_debug.o
/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.c: In function ‘KCL_DEBUG_Print’:
/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.c:89: warning: format not a string literal and no format arguments
/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.c: In function ‘__ke_printk’:
/lib/modules/fglrx/build_mod/2.6.x/kcl_debug.c:146: warning: format not a string literal and no format arguments
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_ioctl.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_io.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_pci.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_str.o
  CC [M]  /lib/modules/fglrx/build_mod/2.6.x/kcl_wait.o
  LD [M]  /lib/modules/fglrx/build_mod/2.6.x/fglrx.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /lib/modules/fglrx/build_mod/2.6.x/fglrx.mod.o
  LD [M]  /lib/modules/fglrx/build_mod/2.6.x/fglrx.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.27-14-generic'
build succeeded with return value 0
duplicating results into driver repository...
done.
You must change your working directory to /lib/modules/fglrx
and then call ./make_install.sh in order to install the built module.
- recreating module dependency list
- trying a sample load of the kernel modules
failed.
[Error] Kernel Module : Failed to install compiled kernel module - please consult readme.
Har testat att lägga in drivrutinerna via Hårdvarustället i inställningarna. Men fick även fel där. Någon som vet vad det kan vara som är fel?
EDIT:
Lyckades få in 9.2 istället. Men, en lustig grej är att när jag kör glxgears nu så får jag runt 2500 FPS. När jag testade det i Ubuntu 9.04 utan några andra inlagda drivrutiner fick jag runt 4000 FPS. Hur kommer det sig? :S
Stationär: Xubuntu 10.10 x64
Laptop: Acer Aspire TimelineX 3820TG - Xubuntu 10.10 x64 | Fluxbox
Återgå till "Bildhantering"
