Synaptic fel.
Harlekin33
Synaptic fel.
Inlägg av Harlekin33 »
Får upp detta medd när jag ska starta synaptic:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
E: _cache->open() failed, please report.
Vad har hänt och vad ska jag göra?
Re: Synaptic fel.
Det den säger att du ska göra:
sudo dpkg --configure -a
Harlekin33
Re: Synaptic fel.
Jo..jag gjorde så men då öppnades Frostwire helt plötsligt.. :o
Krockar dom?
Sen när jag kört kommandot och stängt ner Terminalen och Frostwire så kvarstog felet i alla fall..
Re: Synaptic fel.
Vad får du för output när du utför kommandot?
Harlekin33
Re: Synaptic fel.
[sudo] password for XXXXXX:
Ställer in frostwire (4.18.0) ...
HOSTNAME IS XXXXXX-desktop
Starting FrostWire...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.6.0_07]
Configuring environment...
Loading FrostWire:
CLASSPATH SET TO: :./commons-logging.jar:./FrostWire.jar:./jcraft.jar:./themes.jar:./junit.jar:./httpcore-4.0-beta2.jar:./jflac.jar:./onion-fec.jar:./gettext-commons.jar:./jmdns.jar:./httpcore-niossl-4.0-alpha7.jar:./tritonus.jar:./messages.jar:./icu4j.jar:./foxtrot.jar:./jdic_stub.jar:./aopalliance.jar:./lw-all.jar:./httpcore-nio-4.0-beta2.jar:./mp3spi.jar:./looks.jar:./jorbis.jar:./ProgressTabs.jar:./forms.jar:./jdic.jar:./jython.jar:./log4j.jar:./jaudiotagger.jar:./guice-1.0.jar:./daap.jar:./onion-common.jar:./commons-codec-1.3.jar:./jl.jar:./clink.jar:./httpclient-4.0-alpha3.jar:./vorbisspi.jar:./jogg.jar
Main.java showInitialSplash()
****STARTUP DEBUG: Is this a supported windows or Mac? false
**OverlayAd.image() - OVERLAY AD, im going to load:http://www.frostwire.com/fwclient_welcome_image.php
UpdateManager.scheduleUpdateCheckTask() - TimerTask.run()
UpdateManager.checkForUpdates() - Invoked
Trying to start chat panel...
initializing chat community...
Creating new IRC App...
Initializing new IRC App...
Smileys should be ACTIVE!
Initialized! new IRC App...
getting nick: XXXXXChat enabled?: true
Removing previous banners...
Getting banners from server...
Loading banners...
User-Agent: FrostWire/Linux/4.18.0
UpdateMessageReader.startElement overlay intro=true
UpdateManager.isMessageForMe() - Message was null
UpdateManager.checkForUpdates() - Seems like there's no overlays.
Can load libraries!
Initializing Connection Doctor...
FrostWire's connection doctor will be started at 60 seconds, now waiting: 1 seconds
FrostWire's connection doctor will be started at 60 seconds, now waiting: 2 seconds
FrostWire's connection doctor will be started at 60 seconds, now waiting: 3 seconds
Banners loaded!
BannerContainer.banners.size() -> 0
Refresh ended
end of try...
FrostWire's connection doctor will be started at 60 seconds, now waiting: 4 seconds
FrostWire's connection doctor will be started at 60 seconds, now waiting: 5 seconds
Connection Doctor timer is now ended. Interrupted?true
Harlekin33
Re: Synaptic fel.
Ok..nu funkar inte säkerhetsuppdateringarna heller på grund av frostwire!
Grrr..
Hur avinstallerar jag frostwire?
Harlekin33
Re: Synaptic fel.
Detta blir bara roligare och roligare:
Kunde inte få exklusiv låsning
Det här betyder oftast att en annan pakethanterare (såsom apt-get eller aptitude) redan är igång. Stäng det programmet först.
Finns inget sånt i gång..
Re: Synaptic fel.
Prova att logga ut och in en gång?
Harlekin33
Re: Synaptic fel.
Jag har prövat allt..det ledde till att jag formatera om datorn istället..
Jag prövade även sudo apt-get remove frostwire men det funkade inte heller..
Jag ska passa mig för Frost/Limewire i fortsättningen..har haft strul förut också..
Men tack för hjälpen!
:D
Re: Synaptic fel.
Jag har aldrig förstått mig på varför man ska använda dom där programmen? Dom känns väldigt 90-tal. :P Lite som Bare share och Kazaa eller vad dom nu hette?
Dagon^
Re: Synaptic fel.
Inlägg av Dagon^ »
Hund skrev:Jag har aldrig förstått mig på varför man ska använda dom där programmen? Dom känns väldigt 90-tal. :P Lite som Bare share och Kazaa eller vad dom nu hette?
BearShare, Kazaa, Shareaza, Napster etc. :P
JAG ÄR INTE FADDER LÄNGRE
Re: Synaptic fel.
Harlekin33 skrev:Detta blir bara roligare och roligare:
Nästa gång du råkar ut för det, så går det snabbare med kommandot "sudo rm /var/lib/dpkg/lock" än att formatera om... :)
