Först vill jag be om ursäkt för att jag skapat ny tråd
Skälet är att jag inte fått ett enda svar. Detta är så ovanligt att jag misstänker att frågan ligger på ett ställe där ingen tittar.
Lägger det därför här, med hopp om lösning
Jag har lyckats få hpś devicemanager i panelen
kör detta i terminal, vad är fel
lasseroth@lasse-desktop:~$ hp-check -t
HP Linux Imaging and Printing System (ver. 3.9.4)
Dependency/Version Check Utility ver. 14.3
Copyright (c) 2001-9 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
1. Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.
2. Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
3. Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Saving output in log file: hp-check.log
Initializing. Please wait...
| SYSTEM INFO |
Basic system information:
Linux lasse-desktop 2.6.28-11-generic #42-Ubuntu SMP Fri Apr 17 01:57:59 UTC 2009 i686 GNU/Linux
Distribution:
ubuntu 9.04
HPOJ running?
No, HPOJ is not running (OK).
Checking Python version...
OK, version 2.6.2 installed
Checking PyQt 4.x version...
OK, version 4.4.4 installed.
Checking for CUPS...
Status: scheduler is running
Version: 1.3.9
error_log is set to level: warn
Checking for dbus/python-dbus...
dbus daemon is running.
python-dbus version: 0.83.0
| COMPILE AND RUNTIME DEPENDENCIES |
note: To check for compile-time only dependencies, re-run hp-check with the -c parameter (ie, hp-check -c).
note: To check for run-time only dependencies, re-run hp-check with the -r parameter (ie, hp-check -r).
Checking for dependency: CUPS - Common Unix Printing System...
OK, found.
Checking for dependency: CUPS DDK - CUPS driver development kit...
OK, found.
Checking for dependency: CUPS devel- Common Unix Printing System development files...
OK, found.
Checking for dependency: CUPS image - CUPS image development files...
OK, found.
Checking for dependency: DBus - Message bus system...
OK, found.
Checking for dependency: gcc - GNU Project C and C++ Compiler...
OK, found.
Checking for dependency: GhostScript - PostScript and PDF language interpreter and previewer...
OK, found.
Checking for dependency: libcrypto - OpenSSL cryptographic library...
OK, found.
Checking for dependency: libjpeg - JPEG library...
OK, found.
Checking for dependency: libnetsnmp-devel - SNMP networking library development files...
OK, found.
Checking for dependency: libpthread - POSIX threads library...
OK, found.
Checking for dependency: libtool - Library building support services...
OK, found.
Checking for dependency: libusb - USB library...
OK, found.
Checking for dependency: make - GNU make utility to maintain groups of programs...
OK, found.
Checking for dependency: PIL - Python Imaging Library (required for commandline scanning with hp-scan)...
OK, found.
Checking for dependency: PolicyKit - Administrative policy framework...
OK, found.
Checking for dependency: ppdev - Parallel port support kernel module....
OK, found.
Checking for dependency: PyQt 4 DBus - DBus Support for PyQt4...
OK, found.
Checking for dependency: Python ctypes - A foreign function library for Python...
OK, found.
Checking for dependency: Python DBus - Python bindings for DBus...
OK, found.
Checking for dependency: Python devel - Python development files...
OK, found.
Checking for dependency: Python XML libraries...
OK, found.
Checking for dependency: Python 2.3 or greater - Required for fax functionality...
OK, found.
Checking for dependency: Python 2.2 or greater - Python programming language...
OK, found.
Checking for dependency: Reportlab - PDF library for Python...
OK, found.
Checking for dependency: SANE - Scanning library...
OK, found.
Checking for dependency: SANE - Scanning library development files...
OK, found.
Checking for dependency: scanimage - Shell scanning program...
OK, found.
Checking for dependency: xsane - Graphical scanner frontend for SANE...
OK, found.
| HPLIP INSTALLATION |
Currently installed HPLIP version...
HPLIP 3.9.4 currently installed in '/usr/share/hplip'.
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.9.4
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hpijs/HP
ppdbase=/usr/share/ppd/hpijs
doc=/usr/share/doc/hplip-3.9.4
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp/
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
pp-build=yes
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
foomatic-drv-install=yes
foomatic-ppd-install=no
foomatic-rip-hplip-install=no
cups-ppd-install=no
cups-drv-install=no
internal-tag=3.9.4.102
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=yes
Current contents of '/var/lib/hp/hplip.state' file:
# hplip.state - HPLIP runtime persistent variables.
[plugin]
installed=0
eula=0
Current contents of '~/.hplip/hplip.conf' file:
[last_used]
printer_name =
working_dir = .
device_uri = "hp:/usb/HP_LaserJet_1020?serial=FN00BD2"
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[installation]
version = 3.9.4.102
date_time = 04/27/09 09:33:22
[settings]
systray_messages = 0
systray_visible = 0
[fax]
email_address =
voice_phone =
[refresh]
rate = 30
enable = false
type = 1
[polling]
enable = false
device_list =
interval = 5
| DISCOVERED PARALLEL DEVICES |
No devices found.
| DISCOVERED USB DEVICES |
No devices found.
| INSTALLED CUPS PRINTER QUEUES |
HP-LaserJet-1020
Type: Printer
Device URI: hp:/usb/HP_LaserJet_1020?serial=FN00BD2
PPD: /etc/cups/ppd/HP-LaserJet-1020.ppd
PPD Description: HP LaserJet 1020 Foomatic/foo2zjs (recommended)
Printer status: printer HP-LaserJet-1020 now printing HP-LaserJet-1020-0. enabled since Mon 27 Apr 2009 09:29:07 AM CEST
error: Required plug-in status: Not installed
error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1020?serial=FN00BD2
error: Device not found
error: Communication status: Failed
| SANE CONFIGURATION |
'hpaio' in '/etc/sane.d/dll.conf'...
OK, found. SANE backend 'hpaio' is properly set up.
Checking output of 'scanimage -L'...
device `epson2:libusb:001:010' is a Epson Perfection640 flatbed scanner
device `epson:libusb:001:010' is a Epson Perfection640 flatbed scanner
| PYTHON EXTENSIONS |
Checking 'cupsext' CUPS extension...
OK, found.
Checking 'pcardext' Photocard extension...
OK, found.
Checking 'hpmudext' I/O extension...
OK, found.
Checking 'scanext' SANE scanning extension...
OK, found.
| USER GROUPS |
lasseroth adm dialout cdrom plugdev lpadmin admin sambashare
| SUMMARY |
error: 2 errors and/or warnings.
Please refer to the installation instructions at:
http://hplip.sourceforge.net/install/index.html
Done.
jaunty kan inte få skrivare hp 1020 fungera LÖST
Re: jaunty kan inte få skrivare hp 1020 fungera LÖST
Efter ett antal omstarter började skrivaren plötsligt fungera
