Telenor GIO225 och Ubuntu 9.04 netbook remix
tpnet
Inlägg av tpnet »
Jag hade problem med att få Telenor GIO225 att fungera med Ubuntu 9.04 Notbook Remix på en Acer aspire one.
Efter en massa letande hittade jag hjälpen.
Kopierat från http://forum.ubuntu-nl.org.
Driv rutiner och program från (http://www.pharscape.org)
Jag blev tvungen att installera python för att det skulle fungera.
$ sudo apt-get install python2.5
Download hso 1.6 driver:
Code:
$ wget http://www.flxcore.com/hso/hso-1.6.tar.gz
Download ozerocdoff, hsolink and hsoconnect utilities:
Code:
$ wget http://www.flxcore.com/hso/udev.tar.gz
$ wget http://www.flxcore.com/hso/hsolink_1.0.118-1_i386.deb
$ wget http://www.flxcore.com/hso/hsoconnect-p ... 83_all.deb
Setup build environment:
Code:
$ sudo apt-get install build-essential linux-headers-$(uname -r)
Unpack and compile ozerocdoff utility:
Code:
$ tar zxvf udev.tar.gz
$ cd udev
$ sudo make install
$ cd ..
Reload udev rules to make ozerocdoff utility active:
Code:
$ sudo udevadm control reload_rules
Blacklist the normal Option driver:
Code:
$ echo "blacklist option" | sudo tee -a /etc/modprobe.d/blacklist
$ sudo modprobe -r option
Unpack and compile hso 1.6 driver:
Code:
$ tar zxvf hso-1.6.tar.gz
$ cd hso-1.6
$ make
$ sudo make install
$ cd ..
Copy hso driver to default Ubuntu location (the installer places the driver elsewhere):
Code:
$ sudo cp /lib/modules/$(uname -r)/kernel/drivers/net/wwan/hso.ko /lib/modules/$(uname -r)/kernel/drivers/net/usb/
Install hsolink and hsoconnect utilities:
Code:
$ sudo dpkg -i hso*.deb
Reboot your system and plug in the USB stick
If you currenty use a wired network, unplug your cable, disable it or stop the networkmanager:
Code:
$ sudo /etc/init.d/NetworkManager stop
Start the hsoconnect utility (located under Applications > Internet > HSOconnect or use this command):
Code:
$ python -mhsoc
Enter your PIN code if requested
Click on Connect button
Under Preferences you can increase your transfer limit if you wish (1MB is not that much..)
Funkar kanon för mig.
//tpnet
Tony Petrilä
Edit:massor av stavfel
Återgå till "Internet"
