Installera "rekomenderade" uppdateringar
Loofy
Inlägg av Loofy »
Ok...
Jag har en liten fråga när det gäller terminalen. Det gäller sudo apt-get
Vi kör --help.
Commands:
   update - Retrieve new lists of packages
   upgrade - Perform an upgrade
   install - Install new packages (pkg is libc6 not libc6.deb)
   remove - Remove packages
   autoremove - Remove automatically all unused packages
   purge - Remove and purge packages
   source - Download source archives
   build-dep - Configure build-dependencies for source packages
   dist-upgrade - Distribution upgrade, see apt-get(8)
   dselect-upgrade - Follow dselect selections
   clean - Erase downloaded archive files
   autoclean - Erase old downloaded archive files
   check - Verify that there are no broken dependencies
Options:
  -h  This help text.
  -q  Loggable output - no progress indicator
  -qq No output except for errors
  -d  Download only - do NOT install or unpack archives
  -s  No-act. Perform ordering simulation
  -y  Assume Yes to all queries and do not prompt
  -f  Attempt to correct a system with broken dependencies in place
  -m  Attempt to continue if archives are unlocatable
  -u  Show a list of upgraded packages as well
  -b  Build the source package after fetching it
  -V  Show verbose version numbers
  -c=? Read this configuration file
  -o=? Set an arbitrary configuration option, eg -o dir::cache=/tmp
See the apt-get(8), sources.list(5) and apt.conf(5) manual
pages for more information and options.
                       This APT has Super Cow Powers.
Det jag funderar på är hur man åstakommer samma sak som händer när man får ett utropstecken med uppdateringar i GUIt, klickar och väljer installera?
Är det upgrade man skall köra då?
//Loofy
LapTop: Ubuntu 9.04 64bit
"Server": Ubuntu 8.04
Blivande Devbox: Ubuntu 9.04 64bit
webaake
Re: Installera "rekomenderade" uppdateringar
Inlägg av webaake »
Jag kör ett litet script för detta;
#!/bin/bash
echo "Uppdaterar programkällorna"
echo "_____________________________"
sudo apt-get update
wait
echo "Uppgraderar programmen_______________________________"
sudo apt-get -u -y upgrade
echo "Färdigt!"
exit 0
update letar efter nyheterna
upgrade installerar dem
Loofy
Inlägg av Loofy »
Smidigt!
I samma ämne då.
De finns ju några som heter "clean" och "autoclean". Gör dessa vad jag tror? dvs:
Låt säga jag installerar en applikation från apt-get install. Installationen medför att 4 paket laddas ner och installeras.
Sedan vill jag inte ha applikationen längre. Jag kör apt-get purge. Men då, av någon anledning inte alla 4:a paketen bort.
men då finns ju "clean" som går in och undersöker och plockar bort den här typen av paket där sambandet inte längre existerar?
//Loofy
Återgå till "Terminalforum"
