"503 Service Temporarily Unavailable" ? [LÖST]
stefan_radstrom
Inlägg av stefan_radstrom »
Hej! Jag har en liten enkel Ubuntu Server 8.10 som helt plötsligt börjat spotta ur sig detta meddelande varje gång jag försöker uppdatera programvarorna, och har nu gjort det under en längre tid så det verkar inte vara "temporärt":
stefan@server1:~$ sudo aptitude update && sudo aptitude --assume-yes dist-upgrade
Hit http://security.ubuntu.com intrepid-security Release.gpg
Hit http://se.archive.ubuntu.com intrepid Release.gpg
Ign http://se.archive.ubuntu.com intrepid/main Translation-en_US
Ign http://se.archive.ubuntu.com intrepid/restricted Translation-en_US
Ign http://se.archive.ubuntu.com intrepid/universe Translation-en_US
Ign http://security.ubuntu.com intrepid-security/main Translation-en_US
Ign http://se.archive.ubuntu.com intrepid/multiverse Translation-en_US
Hit http://se.archive.ubuntu.com intrepid-updates Release.gpg
Ign http://security.ubuntu.com intrepid-security/restricted Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-updates/main Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-updates/restricted Translation-en_US
Ign http://security.ubuntu.com intrepid-security/universe Translation-en_US
Ign http://security.ubuntu.com intrepid-security/multiverse Translation-en_US
Hit http://se.archive.ubuntu.com intrepid/main Packages
Hit http://se.archive.ubuntu.com intrepid/restricted Packages
Hit http://se.archive.ubuntu.com intrepid/main Sources
Hit http://se.archive.ubuntu.com intrepid/restricted Sources
Hit http://se.archive.ubuntu.com intrepid/universe Packages
Hit http://se.archive.ubuntu.com intrepid/universe Sources
Hit http://se.archive.ubuntu.com intrepid/multiverse Packages
Hit http://se.archive.ubuntu.com intrepid/multiverse Sources
Hit http://se.archive.ubuntu.com intrepid-updates/main Packages
Hit http://se.archive.ubuntu.com intrepid-updates/restricted Packages
Hit http://se.archive.ubuntu.com intrepid-updates/main Sources
Hit http://se.archive.ubuntu.com intrepid-updates/restricted Sources
Hit http://security.ubuntu.com intrepid-security/main Packages
Hit http://security.ubuntu.com intrepid-security/restricted Packages
Hit http://security.ubuntu.com intrepid-security/main Sources
Hit http://security.ubuntu.com intrepid-security/restricted Sources
Hit http://security.ubuntu.com intrepid-security/universe Packages
Hit http://security.ubuntu.com intrepid-security/universe Sources
Hit http://security.ubuntu.com intrepid-security/multiverse Packages
Hit http://security.ubuntu.com intrepid-security/multiverse Sources
Reading package lists... Done
Building dependency tree
Reading state information... Done
Reading extended state information
Initializing package states... Done
The following packages will be upgraded:
cups-bsd cups-client cups-common cupsys-bsd cupsys-client dpkg dpkg-dev
dselect libcups2 libcupsimage2
The following packages are RECOMMENDED but will NOT be installed:
cups
10 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 4901kB of archives. After unpacking 0B will be used.
Writing extended state information... Done
Get:1 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:2 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:3 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:4 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:5 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:6 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:7 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:8 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:9 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Get:10 http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2 [2230kB]
Err http://se.archive.ubuntu.com intrepid-updates/main dpkg 1.14.20ubuntu6.2
503 Service Temporarily Unavailable [IP: 130.239.18.137 80]
Err http://se.archive.ubuntu.com intrepid-updates/main libcups2 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main cups-common 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main cups-bsd 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main libcupsimage2 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main cups-client 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main cupsys-client 1.3.9-2ubuntu8
Err http://se.archive.ubuntu.com intrepid-updates/main dpkg-dev 1.14.20ubuntu6.2
Err http://se.archive.ubuntu.com intrepid-updates/main dselect 1.14.20ubuntu6.2
Err http://se.archive.ubuntu.com intrepid-updates/main cupsys-bsd 1.3.9-2ubuntu8
E: Failed to fetch http://se.archive.ubuntu.com/ubuntu/poo ... 2_i386.deb: 503 Service Temporarily Unavailable [IP: 130.239.18.137 80]
stefan@server1:~$
Jag har uppgraderat systemet några gånger, och det har alltid gått bra. Även efter den senaste uppgraderingen till 8.10 gick det bra under lång tid, tills det helt plötsligt slutade fungera enligt ovan. Kanske är det något som har ändrat sig i sources.list, som ser ut som enligt nedan ?
etc/apt/sources.list:
# deb cdrom:[Ubuntu-Server 7.04 _Feisty Fawn_ - Release i386 (20070415)]/ feisty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://se.archive.ubuntu.com/ubuntu/ intrepid main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ intrepid main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://se.archive.ubuntu.com/ubuntu/ intrepid-updates main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ intrepid-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://se.archive.ubuntu.com/ubuntu/ intrepid universe
deb-src http://se.archive.ubuntu.com/ubuntu/ intrepid universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://se.archive.ubuntu.com/ubuntu/ intrepid multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ intrepid multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://se.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu intrepid-security main restricted
deb-src http://security.ubuntu.com/ubuntu intrepid-security main restricted
deb http://security.ubuntu.com/ubuntu intrepid-security universe
deb-src http://security.ubuntu.com/ubuntu intrepid-security universe
deb http://security.ubuntu.com/ubuntu intrepid-security multiverse
deb-src http://security.ubuntu.com/ubuntu intrepid-security multiverse
# Added this line for getting the latest CLAMAV.
# Reference: http://www.howtoforge.com/forums/showth ... hp?t=16071
# deb http://volatile.debian.org/debian-volatile etch/volatile main contrib non-free
# Added this lines for getting the latest version of flamerobin, a database
# administration tool for Firebird
# References: http://www.flamerobin.org/ , http://launchpad.net/%7Emapopa/+archive
# deb http://ppa.launchpad.net/mapopa/ubuntu gutsy main
# deb-src http://ppa.launchpad.net/mapopa/ubuntu gutsy main
Går detta att fixa? Mycket tacksam för svar.
Med vänliga hälsningar,
/Stefan
webaake
Re: "503 Service Temporarily Unavailable" ?
Inlägg av webaake »
Har problemet fortsatt? Ifall det har det kan du testa att gå in i Synaptic -> Inställningar -> Förråd -> och under "hämta från" välja Huvudserver. Kan fungera bättre.
stefan_radstrom
Tack för feedback!
Jo, problemet fortsätter olyckligtvis. Tyvärr kan jag inte göra så som du säger eftersom jag kör en server med enbart textgränssnitt. Jag antar att det är något som måste fixas i någon textfil någonstans, möjligen /etc/apt/sources.list, men jag vet inte...
/Stefan
Möjligen att du får avkommentera/kommentera bort någon rad, men detta är förråden från Ubuntu Main Server.
deb http://archive.ubuntu.com/ubuntu/ intrepid main restricted
deb-src http://archive.ubuntu.com/ubuntu/ intrepid main restricted
## distribution.
deb http://archive.ubuntu.com/ubuntu/ intrepid-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ intrepid-updates main restricted
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
## deb http://archive.ubuntu.com/ubuntu/ intrepid universe
## deb-src http://archive.ubuntu.com/ubuntu/ intrepid universe
## deb http://archive.ubuntu.com/ubuntu/ intrepid-updates universe
## deb-src http://archive.ubuntu.com/ubuntu/ intrepid-updates universe
## security team.
## deb http://archive.ubuntu.com/ubuntu/ intrepid multiverse
## deb-src http://archive.ubuntu.com/ubuntu/ intrepid multiverse
## deb http://archive.ubuntu.com/ubuntu/ intrepid-updates multiverse
## deb-src http://archive.ubuntu.com/ubuntu/ intrepid-updates multiverse
## repository.
## deb http://archive.ubuntu.com/ubuntu/ intrepid-backports main restricted universe multiverse
## deb-src http://archive.ubuntu.com/ubuntu/ intrepid-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
# deb http://archive.canonical.com/ubuntu intrepid partner
# deb-src http://archive.canonical.com/ubuntu intrepid partner
deb http://archive.ubuntu.com/ubuntu/ intrepid-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ intrepid-security main restricted
deb http://archive.ubuntu.com/ubuntu/ intrepid-security universe
deb-src http://archive.ubuntu.com/ubuntu/ intrepid-security universe
deb http://archive.ubuntu.com/ubuntu/ intrepid-security multiverse
deb-src http://archive.ubuntu.com/ubuntu/ intrepid-security multiverse
stefan_radstrom
Re: "503 Service Temporarily Unavailable" ? [LÖST]
Det tog nästan fem dygn att uppdatera, och varje ny uppdatering tar upp till ett halvt dygn nu (inte direkt Windows Update-hastighet), men nu verkar det funka i alla fall. Tack så mycket!
Oj, det var ingen bra hastighet. :( Även fast det är utländska servrar brukar jag ligga på runt 2-4 MB/s iaf, snabbast är dock dom svenska där jag brukar ligga på 8-10MB/s.
