uppdateringshanteraren
bjoost61
Inlägg av bjoost61 »
Uppdateringshanteraren slutade fungera, öppnar inte alls och inte programvarukällor heller efter senaste uppdateringarna. Någon som har en lösning eller ide'?
Inhuman Soul
Re: uppdateringshanteraren
Inlägg av Inhuman Soul »
Testa att starta dom från terminalen och se vad du får för felmeddelanden.
update-manager
gksu software-properties-gtk
bjoost61
/usr/share/themes/Dust/gtk-2.0/gtkrc:708: Murrine configuration option "highlight_ratio" will be deprecated in future releases. Please use "highlight_shade" instead.
/usr/share/themes/Dust/gtk-2.0/gtkrc:709: Murrine configuration option "lightborder_ratio" will be deprecated in future releases. Please use "lightborder_shade" instead.
Traceback (most recent call last):
File "/usr/bin/update-manager", line 33, in <module>
from UpdateManager.UpdateManager import UpdateManager
File "/usr/lib/python2.6/dist-packages/UpdateManager/UpdateManager.py", line 39, in <module>
import apt
File "/usr/lib/python2.6/dist-packages/apt/__init__.py", line 7, in <module>
from apt.package import Package
File "/usr/lib/python2.6/dist-packages/apt/package.py", line 27, in <module>
import urllib2
File "/usr/lib/python2.6/urllib2.py", line 91, in <module>
import hashlib
File "/usr/lib/python2.6/hashlib.py", line 136, in <module>
md5 = __get_builtin_constructor('md5')
File "/usr/lib/python2.6/hashlib.py", line 63, in __get_builtin_constructor
import _md5
ImportError: No module named _md5
Error in sys.excepthook:
File "/usr/lib/python2.6/dist-packages/apport_python_hook.py", line 38, in apport_excepthook
from apport.packaging_impl import impl as packaging
File "/usr/lib/python2.6/dist-packages/apport/__init__.py", line 1, in <module>
from apport.report import Report
File "/usr/lib/python2.6/dist-packages/apport/report.py", line 21, in <module>
import fileutils
File "/usr/lib/python2.6/dist-packages/apport/fileutils.py", line 16, in <module>
from packaging_impl import impl as packaging
File "/usr/lib/python2.6/dist-packages/apport/packaging_impl.py", line 18, in <module>
import apt
import urllib2
import hashlib
import _md5
Original exception was:
import apt
import urllib2
import hashlib
import _md5
TobbeT
Inlägg av TobbeT »
När jag kör update-manager via terminalen så får jag upp att det går att göra en "delvis uppdatering". Jag klickar att så ska göras. Allt laddas ner men sen blir det detta meddelande i terminalen. Vad gör man åt det?
ERROR:root:not handled expection:
  File "/usr/bin/update-manager", line 100, in <module>
    controler.doPartialUpgrade()
  File "/usr/lib/python2.6/dist-packages/DistUpgrade/DistUpgradeController.py", line 1588, in doPartialUpgrade
    if not self.doDistUpgrade():
  File "/usr/lib/python2.6/dist-packages/DistUpgrade/DistUpgradeController.py", line 965, in doDistUpgrade
    self.enableApport()
  File "/usr/lib/python2.6/dist-packages/DistUpgrade/DistUpgradeController.py", line 959, in enableApport
    shutil.copy("etc-default-apport","/etc/default/apport")
  File "/usr/lib/python2.6/shutil.py", line 88, in copy
    copyfile(src, dst)
  File "/usr/lib/python2.6/shutil.py", line 52, in copyfile
    fsrc = open(src, 'rb')
IOError: [Errno 2] Filen eller katalogen finns inte: 'etc-default-apport'
ERROR:root:failed to import apport python module, can't report bug: No module named python_hook
none
//Tobbe
GGS-Data Elite, 5200+ 4GB RAM Ubuntu 11.04 64-bitars, 2x500GB HD
jakethecak3
Inlägg av jakethecak3 »
Tobbe, skapa mappen /usr/lib/python2.6/dist-packages/computerjanitor/plugins/ så ska de fungera igen. :D
sudo mkdir /usr/lib/python2.6/dist-packages/computerjanitor/plugins/
https://bugs.launchpad.net/ubuntu/+sour ... bug/335416
TobbeT
Inlägg av TobbeT »
Tackar, ska testa det.
jakethecak3 skrev:Tobbe, skapa mappen /usr/lib/python2.6/dist-packages/computerjanitor/plugins/ så ska de fungera igen. :D
