compiz på Xubuntu strular[LÖST]
nisse2
Inlägg av nisse2 »
Fick för mig att försöka instrallera compiz funktionerna på Xubuntu men det felar, försökte med följande:
För att installera compiz från synaptic använde jag dessa:
compiz-core compiz-fusion-plugins-extra compiz-fusion-plugins-main compiz-plugins compizconfig-settings-manager libcompizconfig0 python-compizconfig
För att starta compiz:
compiz --replace
Får följande meddelande från terminalen:
nisse2@xubuntu:~$ compiz --replace
Checking for Xgl: not present.
Detected PCI ID for VGA:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1920x1200) to maximum 3D texture size (4096): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: present.
Checking for FBConfig: present.
/usr/bin/compiz.real (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
Couldn't find a perfect decorator match; trying all decorators
Found no decorator to start
Window manager warning: "" found in configuration database is not a valid value for keybinding "toggle_shaded"
Window manager warning: Failed to load theme "Human": Failed to find a valid file for theme Human
nisse2@xubuntu:~$
Verkar strula på slutet - Xgl not present osv.
Sedan kommer följande upp på terminalfönstret:
nisse2@xubuntu:~$ Window manager warning: Received a NET_CURRENT_DESKTOP message from a broken (outdated) client who sent a 0 timestamp
Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x260000a (Terminal -)
Window manager warning: meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
Har följande grafikdrivare aktiverad:
NVIDIA accelerated graphics driver (version 177)[Recommended]
Tested by Ubuntu developers
3D-accelerated proprietary graphics driver for NVIDIA cards.
This driver is required to fully utilise the 3D potential of NVIDIA graphics cards, as well as provide 2D acceleration of newer cards.
If you wish to enable desktop effects, this driver is required.
If this driver is not enabled, you will not be able to enable desktop effects and will not be able to run software that requires 3D acceleration, such as some games.
Ska det inte funka med den drivaren som jag använder ovan? eller vad är det som är problemet mer?
philip5
HC-IRCare
Re: compiz på Xubuntu strular
Inlägg av philip5 »
Verkar mer som problemet har med windows decorator än själva compiz. Testa att installera emerald och prova med det annars.
Ett enkelt sätt att starta och växla mellan compiz och andra hantererare är att köra med fusion icon. Installera paketet fusion-icon och starta programmet från menyn och du borde få en ikon på din systray som du kan använda att växla och byta mellan olika lägen på ett enkelt och smidigt sätt.
/Philip
nisse2
Inlägg av nisse2 »
Ok, det var bara att installera emerald så fukar det, tackar.
Återgå till "Skrivbordet"
