Nu verkar den inte vara uppgraderad. Dessutom har vissa kommandon slutat fungera bla apt-get och jag får felmedelande när jag använder man.
X-servern togs bort också, men det installerade vi på nytt.
apt-get:
om jag nu försöker skriva tex sudo apt-get upgrade får jag följande medelande:
Reading package lists... Done
Building dependency tree... Done
You might want to run `apt-get -f install' to correct these.
The following packages have unmet dependencies:
gnome-accessibility-themes: Depends: gtk2-engines-highcontrast
gnome-themes: Depends: gtk2-engines-thinice
Depends: gtk2-engines-crux
Depends: gtk2-engines-redmond95
Depends: gtk2-engines-lighthouseblue
Depends: gtk2-engines-smooth
Depends: gtk2-engines-mist
Depends: gtk2-engines-clearlooks
xserver-xorg-core: Depends: x11-common (>= 1:7.0.0) but 7.0.0-0ubuntu45 is installed
xutils-dev: Depends: x11-common (>= 1:7.0.0) but 7.0.0-0ubuntu45 is installed
E: Unmet dependencies. Try using -f.
Correcting dependencies... Done
The following extra packages will be installed:
dbus gnome-keyring gtk2-engines libatk1.0-0 libavahi-client-dev libavahi-client3 libavahi-glib1 libbonobo2-0 libbonobo2-common libbonoboui2-0
libbonoboui2-common libcairo2 libcupsys2 libdbus-1-3 libdbus-glib-1-2 libglib2.0-0 libglib2.0-data libgnome-keyring0 libgnomeui-0 libgnomeui-common
libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgnutls13 libgpg-error0 libgsf-1-114 libgsf-1-common libgtk2.0-0 libgtk2.0-bin libgtk2.0-common
libopencdk8 liborbit2 libpango1.0-0 libpango1.0-common libpopt0 librsvg2-2 librsvg2-common libselinux1 libsepol1 libtasn1-3 libxml2 x11-common
xserver-xorg xserver-xorg-video-all xserver-xorg-video-via
Suggested packages:
cupsys-common gnutls-bin ttf-thryomanes librsvg2-bin
Recommended packages:
libtasn1-3-bin
The following packages will be REMOVED:
xserver-xorg-driver-via
The following NEW packages will be installed:
gtk2-engines libdbus-1-3 libgnutls13 libgsf-1-114 libtasn1-3 xserver-xorg-video-all xserver-xorg-video-via
The following packages will be upgraded:
dbus gnome-keyring libatk1.0-0 libavahi-client-dev libavahi-client3 libavahi-glib1 libbonobo2-0 libbonobo2-common libbonoboui2-0 libbonoboui2-common
libcairo2 libcupsys2 libdbus-glib-1-2 libglib2.0-0 libglib2.0-data libgnome-keyring0 libgnomeui-0 libgnomeui-common libgnomevfs2-0 libgnomevfs2-common
libgnomevfs2-extra libgpg-error0 libgsf-1-common libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libopencdk8 liborbit2 libpango1.0-0 libpango1.0-common
libpopt0 librsvg2-2 librsvg2-common libselinux1 libsepol1 libxml2 x11-common xserver-xorg
38 upgraded, 7 newly installed, 1 to remove and 824 not upgraded.
39 not fully installed or removed.
Need to get 277kB/10.9MB of archives.
After unpacking 8184kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://archive.ubuntu.com edgy/main libsepol1 1.12-1 [102kB]
Get:2 http://archive.ubuntu.com edgy/main libgpg-error0 1.2-1 [14.5kB]
Get:3 http://archive.ubuntu.com edgy/main libopencdk8 0.5.8-1 [93.5kB]
Get:4 http://archive.ubuntu.com edgy/main libtasn1-3 0.3.5-1 [44.6kB]
Get:5 http://archive.ubuntu.com edgy/main libpopt0 1.10-2 [21.9kB]
Fetched 277kB in 2s (92.6kB/s)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_SE:en",
LC_ALL = (unset),
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_ALL to default locale: No such file or directory
debconf: DbDriver "config": could not open /var/cache/debconf/config.dat
dpkg: xserver-xorg: dependency problems, but removing anyway as you request:
x-window-system-core depends on xserver-xorg.
dpkg: error processing xserver-xorg (--remove):
Package is in a very bad inconsistent state - you should
reinstall it before attempting a removal.
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_S_construct NULL not valid
Aborted
daoo@omega:~$ Errors were encountered while processing:
xserver-xorg
Felmedelandet jag får vid man kommandot är följande:
man: can't set the locale; make sure $LC_* and $LANG are correct
gnome-themes
xserver-xorg-core
xutils-dev
HJÄÄÄLP!
