dhcpd: No subnet declaration for eth0 (0.0.0.0).
** Ignoring requests on eth0. If this is not what
you want, please write a subnet declaration
in your dhcpd.conf file for the network segment
to which interface eth0 is attached. **
Not configured to listen on any interfaces!
ddns-update-style none;
option domain-name-servers 83.233.79.36, 83.233.79.37;
default-lease-time 86400;
max-lease-time 604800;
authoritative;
subnet 192.168.1.0 netmask 255.255.255.0 {
range 192.168.1.1 192.168.1.115;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.1.255;
option routers 192.168.1.1;
# Defaults for dhcp initscript
# sourced by /etc/init.d/dhcp
# installed at /etc/default/dhcp3-server by the maintainer scripts
# This is a POSIX shell fragment
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACES="eth0"
Någon som vet varför servern inte startar, hittar inte felet själv och har försökt läsa alla typer av manualer som jag kan hitta.
