jansson
Inlägg: 527 Blev medlem: 31 okt 2006, 13:35
Inlägg
av jansson » 27 jan 2009, 20:48
Hej.
Jag körde sudo apt-get update och fick.
Notera texten i slutet.
micke@micke-desktop:~$ sudo apt-get update
[sudo] password for micke:
Ign http://ppa.launchpad.net intrepid Release.gpg
Ign http://ppa.launchpad.net intrepid/main Translation-en_US
Get:1 http://ppa.launchpad.net intrepid Release.gpg [307B]
Hit http://se.archive.ubuntu.com intrepid Release.gpg
Ign http://se.archive.ubuntu.com intrepid/main Translation-en_US
Get:2 http://ppa.launchpad.net intrepid Release [27.6kB]
Ign http://se.archive.ubuntu.com intrepid/restricted Translation-en_US
Ign http://se.archive.ubuntu.com intrepid/universe Translation-en_US
Ign http://se.archive.ubuntu.com intrepid/multiverse Translation-en_US
Hit http://se.archive.ubuntu.com intrepid-updates Release.gpg
Ign http://se.archive.ubuntu.com intrepid-updates/main Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-updates/restricted Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-updates/universe Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-updates/multiverse Translation-en_US
Get:3 http://ppa.launchpad.net intrepid Release [27.6kB]
Hit http://se.archive.ubuntu.com intrepid-security Release.gpg
Ign http://se.archive.ubuntu.com intrepid-security/main Translation-en_US
Get:4 http://ppa.launchpad.net intrepid Release [27.6kB]
Ign http://se.archive.ubuntu.com intrepid-security/restricted Translation-en_US
Ign http://ppa.launchpad.net intrepid/main Packages
Ign http://ppa.launchpad.net intrepid/main Sources
Ign http://se.archive.ubuntu.com intrepid-security/universe Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-security/multiverse Translation-en_US
Hit http://se.archive.ubuntu.com intrepid-proposed Release.gpg
Hit http://ppa.launchpad.net intrepid/main Packages
Ign http://se.archive.ubuntu.com intrepid-proposed/restricted Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-proposed/main Translation-en_US
Ign http://se.archive.ubuntu.com intrepid-proposed/multiverse Translation-en_US
Hit http://ppa.launchpad.net intrepid/main Sources
Ign http://se.archive.ubuntu.com intrepid-proposed/universe Translation-en_US
Hit http://se.archive.ubuntu.com intrepid/main Packages
Hit http://se.archive.ubuntu.com intrepid/restricted Packages
Hit http://se.archive.ubuntu.com intrepid/universe Packages
Hit http://se.archive.ubuntu.com intrepid/multiverse Packages
Hit http://se.archive.ubuntu.com intrepid-updates/main Packages
Hit http://se.archive.ubuntu.com intrepid-updates/restricted Packages
Hit http://se.archive.ubuntu.com intrepid-updates/universe Packages
Hit http://se.archive.ubuntu.com intrepid-updates/multiverse Packages
Hit http://se.archive.ubuntu.com intrepid-security/main Packages
Hit http://se.archive.ubuntu.com intrepid-security/restricted Packages
Hit http://se.archive.ubuntu.com intrepid-security/universe Packages
Hit http://se.archive.ubuntu.com intrepid-security/multiverse Packages
Hit http://se.archive.ubuntu.com intrepid-proposed/restricted Packages
Get:5 http://se.archive.ubuntu.com intrepid-proposed/main Packages [95.3kB]
Hit http://se.archive.ubuntu.com intrepid-proposed/multiverse Packages
Get:6 http://se.archive.ubuntu.com intrepid-proposed/universe Packages [41.9kB]
Fetched 312B in 0s (370B/s)
W: GPG error: http://ppa.launchpad.net intrepid Release: The following signatures couldn'tbe verified because the public key is not available: NO_PUBKEY 60487016493B3065
W: Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/intrepid-proposed/main/binary-amd64/Packages.bz2 Hash Sum mismatch
W: Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/intrepid-proposed/universe/binary-amd64/Packages.bz2 Hash Sum mismatch
E: Some index files failed to download, they have been ignored, or old ones used instead.
Någon mer som har så?
Jag kör 8.10 och har kde 4.2 (rc-1).
jansson
Inlägg
av jansson » 27 jan 2009, 20:51
Jag böt server också till den Amerikanska.
Samma sak - nästan.
Reading package lists... Done
W: You may want to run apt-get update to correct these problems
Det sista i slutet var inte med nu.
mcNisse
Inlägg: 5211 Blev medlem: 06 feb 2007, 20:51
Inlägg
av mcNisse » 27 jan 2009, 21:35
Du behöver installera nyckeln i apt. Använd tex apt-key. Hur du får tag på nyckeln vet jag inte..
jansson
Inlägg
av jansson » 27 jan 2009, 21:40
Ok. Men hur kan den ha försvunnit?
mcNisse
Inlägg
av mcNisse » 27 jan 2009, 23:02
Den har inte försvunnit. Du har nog aldrig haft den. Jag får samma varningar som du. Jag ska kolla om jag kan få tag på nyckeln...
jansson
Inlägg
av jansson » 27 jan 2009, 23:22
Aha. Så nu när de har släppt KDE 4.2 stabilt så kommer den flaggad som relese och av någon anledning så finns inte den publicka nyckeln för PGP-sigilet till relese-flaggade saker med i Intrepid. Har jag fattat rätt då?
andol
Inlägg: 3093 Blev medlem: 31 dec 2007, 00:19
Inlägg
av andol » 27 jan 2009, 23:32
Ser ut som om du har ett PPA inlagt. Dessa håller just nu på och förses med nycklar.
Gissar att det du vill göra är att besöka respektive PPAs hemsida och laddar ner den publika nyckeln därifrån.
mcNisse
Inlägg
av mcNisse » 27 jan 2009, 23:47
Hittad
När du importerar nyckeln betyder det att du litar på de som signerar med den nyckeln.
Från den här tråden kunde jag importera nyckeln:
http://kubuntuforums.net/forums/index.php?topic=3101218
gpg --keyserver keyserver.ubuntu.com --recv 493b3065
gpg --export --armor 493b3065 | sudo apt-key add -
Är det någon som kan förklara de 8 första tecknen står för i nyckelidet som apt saknar? Det borde bli 60487016 i det här fallet.
jansson
Inlägg
av jansson » 28 jan 2009, 00:22
OK det hjälpte.
Jag vet inte vad de 8 sista står för. Jag förstår inte riktigt frågan heller så...
andol
Inlägg
av andol » 28 jan 2009, 01:21
Skillnaden på 6048 7016 493B 3065 och 493b 3065 är i princip endast att de är olika grader utav exakthet.
(Där båda rent strikt är en förkortning utav nyckelns fullständiga "fingerprint" F3C4 8CB3 011F A791 D74A CAAC 6048 7016 493B 3065)
mcNisse
Inlägg
av mcNisse » 28 jan 2009, 01:25
Tack för förklaringen.
shwan
Inlägg: 11 Blev medlem: 25 okt 2008, 01:49
Inlägg
av shwan » 31 jan 2009, 14:45
de 8 sista är Key ID , varje pgp krypteringnyckel har ett nam/ID så att man kan lätt hitta de på de publika servrarna eller i sin dator. kör seahorse ivia alt+f2 så får du lite koll på detta. läg gärna pgp eller gnupgp på wikipedia det är rätt skoj!
mhenriday
Inlägg: 89 Blev medlem: 26 sep 2006, 16:05
Inlägg
av mhenriday » 05 feb 2009, 15:44
På senaste tiden får jag upp det följande meddelandet när jag kör uppdateringshanteraren :
W: GPG-fel:
http://ppa.launchpad.net intrepid Release: Följande signaturer kunde inte verifieras för att den öppna nyckeln inte är tillgänglig: NO_PUBKEY 60D11217247D1CFF
Jag tog då de sista åtta tecknen - 247D1CFF - och körde följande i en terminal :
gpg --keyserver keyserver.ubuntu.com --recv 247D1CFF
gpg --export --armor 247D1CFF | sudo apt-key add -
men får upp fortfarande meddelandet om att den öppna nyckeln inte är tillgänglig. Förslag ?...
Henri
PS : Felmeddelandet försvann när jag, istället för de sista åtta tecknen, la till
alla 16 tecken i terminalen -
gpg --keyserver keyserver.ubuntu.com --recv 60D11217247D1CFF
gpg --export --armor 60D11217247D1CFF | sudo apt-key add -
Härligt !
ds
mhenriday , redigerad totalt 5 gånger.
andol
Inlägg
av andol » 05 feb 2009, 15:56
Om inte annat så verkar det som om du saknar ett mellanslag.
mhenriday
Inlägg
av mhenriday » 05 feb 2009, 16:29
Hej andol och tack för svar ! Se mitt post scriptum ovan - mellanslaget mellan »armor« och de åtta kodtecknen fanns inte i terminalen (annars hade jag inte fått meddelandet »OK«), utan uppstod när jag kopierade till mitt inlägg här. Men, som sagt, efter jag hade lagt till alla 16 tecknen i terminalen försvann problemet för min del....
Henri
