Kategoriregler Varning! Det som diskuteras här är inte alltid enkelt och det kan hända att vissa installationer/modifieringar kan göra ditt system oanvändbart. Inget för nybörjare. Gör alltid backup av känslig data innan du experimenterar.
/set bell_beeps ON
/set beep_msg_level MSGS NOTICES DCC DCCMSGS HILIGHT
/set beep_when_away ON
/set beep_when_window_active ON
och sen <ctrl>+<a> <ctrl>+<g> men det ger inget, har även terminal bell ibockad i min terminal.
jag kör jaunty på min laptop med pulseaudio och det mesta ljud fungerar (spotify i wine genom alsa och flash i firefox amarok osv.), dock har jag problem med theme ljudet i gnome.
# $Id: screenrc,v 0.15 2003/10/08 11:39:03 zal Exp $
# /etc/screenrc
# This is the system wide screenrc.
# You can use this file to change the default behavior of screen system wide
# or copy it to ~/.screenrc and use it as a starting point for your own
# settings.
# Commands in this file are used to set options, bind screen functions to
# keys, redefine terminal capabilities, and to automatically establish one or
# more windows at the beginning of your screen session.
# This is not a comprehensive list of options, look at the screen manual for
# details on everything that you can put in this file.
# SCREEN SETTINGS
#startup_message off
#nethack on
#defflow on # will force screen to process ^S/^Q
deflogin on
#autodetach off
# turn visual bell on
vbell on
vbell_msg " Wuff ---- Wuff!! "
# define a bigger scrollback, default is 100 lines
defscrollback 1024
# SCREEN KEYBINDINGS
# Remove some stupid / dangerous key bindings
bind ^k
#bind L
bind ^\
# Make them better
bind \\ quit
bind K kill
bind I login on
bind O login off
bind } history
# An example of a "screen scraper" which will launch urlview on the current
# screen window
#bind ^B eval "hardcopy_append off" "hardcopy -h $HOME/.screen-urlview" "screen urlview $HOME/.screen-urlview"
# TERMINAL SETTINGS
# The vt100 description does not mention "dl". *sigh*
termcapinfo vt100 dl=5\E[M
# turn sending of screen messages to hardstatus off
hardstatus off
# Set the hardstatus prop on gui terms to set the titlebar/icon title
termcapinfo xterm*|rxvt*|kterm*|Eterm* hs:ts=\E]0;:fs=\007:ds=\E]0;\007
# use this for the hard status string
hardstatus string "%h%? users: %u%?"
# An alternative hardstatus to display a bar at the bottom listing the
# windownames and highlighting the current windowname in blue. (This is only
# enabled if there is no hardstatus setting for your terminal)
#hardstatus lastline "%-Lw%{= BW}%50>%n%f* %t%{-}%+Lw%<"
# set these terminals up to be 'optimal' instead of vt100
termcapinfo xterm*|linux*|rxvt*|Eterm* OP
# Change the xterm initialization string from is2=\E[!p\E[?3;4l\E[4l\E>
# (This fixes the "Aborted because of window size change" konsole symptoms found
# in bug #134198)
termcapinfo xterm 'is=\E[r\E[m\E[2J\E[H\E[?7h\E[?1;4;6l'
# To get screen to add lines to xterm's scrollback buffer, uncomment the
# following termcapinfo line which tells xterm to use the normal screen buffer
# (which has scrollback), not the alternate screen buffer.
#termcapinfo xterm|xterms|xs|rxvt ti@:te@
# Enable non-blocking mode to better cope with flaky ssh connections.
defnonblock 5
# STARTUP SCREENS
# Example of automatically running some programs in windows on screen startup.
# The following will open top in the first window, an ssh session to monkey
# in the next window, and then open mutt and tail in windows 8 and 9
# respectively.
# screen top
# screen -t monkey ssh monkey
# screen -t mail 8 mutt
# screen -t daemon 9 tail -f /var/log/daemon.log
