flimmer med conky[LÖST]
narius
Inlägg av narius »
Tja
Jag kör conky "inbäddad" på skrivbordet. Mitt problem är att jag när conky uppdateras var 5:e sekund "försvinner" iconerna på skrivbordet. Om man jag rör över dem med musen kommer de tillbaka. finns det något sätt att göra så att de inte försvinner.
Min conkyrc ser ut som nedan
# Conky sample configuration
# the list of variables has been removed from this file in favour
# of keeping the documentation more maintainable.
# Check http://conky.sf.net for an up-to-date-list.
# set to yes if you want Conky to be forked in the background
background no
# X font when Xft is disabled, you can pick one with program xfontsel
#font 5x7
#font 6x10
#font 7x13
#font 8x13
#font 9x15
#font *mintsmild.se*
#font -*-*-*-*-*-*-34-*-*-*-*-*-*-*
# Use Xft?
use_xft yes
# Xft font when Xft is enabled
xftfont Bitstream Vera Sans Mono:size=8
# Text alpha when using Xft
xftalpha 0.8
# Print everything to stdout?
# out_to_console no
# c host/port
# mpd_host localhost
# mpd_port 6600
# mpd_password tinker_bell
# Print everything to console?
# out_to_console no
# mail spool
#mail_spool $MAIL
# Update interval in seconds
update_interval 5.0
# This is the number of times Conky will update before quitting.
# Set to zero to run forever.
total_run_times 0
# Create own window instead of using desktop (required in nautilus)
own_window no
# If own_window is yes, you may use type normal, desktop or override
#own_window_type normal
# Use pseudo transparency with own_window?
#own_window_transparent yes
# If own_window_transparent is set to no, you can set the background colour here
#own_window_colour hotpink
# If own_window is yes, these window manager hints may be used
#own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
s
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
minimum_size 280 5
# Draw shades?
draw_shades yes
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders yes
# Draw borders around graphs
draw_graph_borders yes
# Stippled borders?
stippled_borders 8
# border margins
border_margin 4
# border width
border_width 1
# Default colors and also border colors
default_color white
default_shade_color black
default_outline_color black
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
#alignment none
# Gap between borders of screen and text
# same thing as passing -x at command line
gap_x 12
gap_y 12
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# number of cpu samples to average
# set to 1 to disable averaging
cpu_avg_samples 2
# number of net samples to average
net_avg_samples 2
# Force UTF8? note that UTF8 support required XFT
override_utf8_locale no
# Add spaces to keep things from moving about?  This only affects certain objects.
use_spacer none
# Shows the maximum value in scaled graphs.
show_graph_scale no
# Shows the time range covered by a graph.
show_graph_range no
# Allow each port monitor to track at most this many connections (if 0 or not set, default is 256)
#max_port_monitor_connections 256
# Maximum number of special things, e.g. fonts, offsets, aligns, etc.
#max_specials 512
# Maximum size of buffer for user text, i.e. below TEXT line.
#max_user_text 16384
# Timing interval for music player thread, e.g. mpd, audacious
#music_player_interval (update_interval is default)
# Strictness of if_up. One of: up, link or address. The later ones imply the further ones.
# Defaults to up.
#if_up_strictness address
# variable is given either in format $variable or in ${variable}. Latter
# allows characters right after the variable and must be used in network
# stuff because of an argument
# stuff after 'TEXT' will be formatted on screen
TEXT
$nodename - $sysname $kernel on $machine
$stippled_hr
${color lightgrey}Uptime:$color $uptime ${color lightgrey}- Load:$color $loadavg
${color lightgrey}CPU Usage:${color #cc2222} $cpu% ${cpubar}
${color red}${cpugraph 0000ff 00ff00}
${color lightgrey}RAM Usage:$color $mem/$memmax - $memperc% ${membar}
${color lightgrey}Swap Usage:$color $swap/$swapmax - $swapperc% ${swapbar}
${color lightgrey}Processes:$color $processes  ${color grey}Running:$color $running_processes
$color$stippled_hr
${color lightgrey}Networking:
 Down:${color #8844ee} ${downspeed eth0} k/s${color lightgrey} ${offset 80}Up:${color #22ccff} ${upspeed eth0} k/s
${color #0000ff}${downspeedgraph eth0 32,150 ff0000 0000ff} ${color #22ccff}${upspeedgraph eth0 32,150 0000ff ff0000}
${color lightgrey}File systems:
 / $color${fs_used /}/${fs_size /} ${fs_bar /}
${color #88aadd}MPD: ${alignc}$mpd_artist - $mpd_title
${color #88aadd}$mpd_bar
${color #88aadd}${alignc}$mpd_status
${color}Name              PID     CPU%   MEM%
${color #ddaa00} ${top name 1} ${top pid 1} ${top cpu 1} ${top mem 1}
${color lightgrey} ${top name 2} ${top pid 2} ${top cpu 2} ${top mem 2}
${color lightgrey} ${top name 3} ${top pid 3} ${top cpu 3} ${top mem 3}
${color lightgrey} ${top name 4} ${top pid 4} ${top cpu 4} ${top mem 4}
${color}Mem usage
${color #ddaa00} ${top_mem name 1} ${top_mem pid 1} ${top_mem cpu 1} ${top_mem mem 1}
${color lightgrey} ${top_mem name 2} ${top_mem pid 2} ${top_mem cpu 2} ${top_mem mem 2}
${color lightgrey} ${top_mem name 3} ${top_mem pid 3} ${top_mem cpu 3} ${top_mem mem 3}
$stippled_hr
${color #ddaa00}Port(s)${alignr}#Connections
$color Inbound: ${tcp_portmon 1 32767 count}  Outbound: ${tcp_portmon 32768 61000 count}${alignr}ALL: ${tcp_portmon 1 65535 count}
${color #ddaa00}Inbound Connection ${alignr} Local Service/Port$color
 ${tcp_portmon 1 32767 rhost 0} ${alignr} ${tcp_portmon 1 32767 lservice 0}
 ${tcp_portmon 1 32767 rhost 1} ${alignr} ${tcp_portmon 1 32767 lservice 1}
 ${tcp_portmon 1 32767 rhost 2} ${alignr} ${tcp_portmon 1 32767 lservice 2}
 ${tcp_portmon 1 32767 rhost 3} ${alignr} ${tcp_portmon 1 32767 lservice 3}
 ${tcp_portmon 1 32767 rhost 4} ${alignr} ${tcp_portmon 1 32767 lservice 4}
 ${tcp_portmon 1 32767 rhost 5} ${alignr} ${tcp_portmon 1 32767 lservice 5}
${color #ddaa00}Outbound Connection ${alignr} Remote Service/Port$color
 ${tcp_portmon 32768 61000 rhost 0} ${alignr} ${tcp_portmon 32768 61000 rservice 0}
 ${tcp_portmon 32768 61000 rhost 1} ${alignr} ${tcp_portmon 32768 61000 rservice 1}
 ${tcp_portmon 32768 61000 rhost 2} ${alignr} ${tcp_portmon 32768 61000 rservice 2}
 ${tcp_portmon 32768 61000 rhost 3} ${alignr} ${tcp_portmon 32768 61000 rservice 3}
 ${tcp_portmon 32768 61000 rhost 4} ${alignr} ${tcp_portmon 32768 61000 rservice 4}
 ${tcp_portmon 32768 61000 rhost 5} ${alignr} ${tcp_portmon 32768 61000 rservice 5}
Defunctus
Re: flimmer med conky
Inlägg av Defunctus »
hade samma problem själv men ändrade
till
override_utf8_locale yes
då funkade det finfint så prova det
Girls, girls, girls
narius
Inlägg av narius »
Det hjälpte tyvär inte. Några fler idéer?
narius
Inlägg av narius »
Har hittat en lösning
lägg till detta i conkyrc så slutar det flimmrar
own_window yes
own_window_type override
hittade tipset här
http://ronnietucker.co.uk/blog/2008/12/ ... itor-woes/
