Tja, jag e newie på linux .. och försöker installera ett Apple mac tema.. har följt den här guiden
http://www.howtoforge.com/mac4lin_make_ ... like_a_mac
dock utan att lyckas, som rubriker säger så klyddar mitt gtk o allt som hör där till.. här kommer ett tudrag när jag försöker configa gtk
polak@polak-laptop:~/gtk+-2.8.0$ ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for native Win32... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
appending configuration tag "F77" to libtool
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for _LARGE_FILES value needed for large files... no
checking for nm... /usr/bin/nm -B
checking whether to enable maintainer-specific portions of Makefiles... no
checking for some Win32 platform... no
checking for strerror in -lcposix... no
checking whether make sets $(MAKE)... (cached) yes
checking for pkg-config... /usr/local/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for BASE_DEPENDENCIES_CFLAGS...
checking for BASE_DEPENDENCIES_LIBS...
configure: error: Package requirements (glib-2.0 >= 2.7.1 atk >= 1.0.1 pango >= 1.9.0 cairo >= 0.9.2) were not met.
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively you may set the BASE_DEPENDENCIES_CFLAGS and BASE_DEPENDENCIES_LIBS environment variables
to avoid the need to call pkg-config. See the pkg-config man page for
more details.
Vad ska jag göra?
GTK och annat klydd
- micke_nordin
Re: GTK och annat klydd
Jag tror att du måste installera lite bibliotek, kör detta i terminalen:
/Micke
sudo apt-get install libpango1.0-dev libcairo0.9.0-dev libatk1.0-dev libgtk2.0-dev
fick detta som svar
Läser paketlistor... Färdig
Bygger beroendeträd
Paketet libcairo0.9.0-dev är inte tillgängligt, men ett annat paket hänvisar till det.
Det kan betyda att paketet saknas, har blivit föråldrat eller endast
är tillgängligt från andra källor
Dock kan följande paket ersätta det:
libcairo2-dev
Bygger beroendeträd
libcairo2-dev
- mcNisse
- OS: Debian
Installera libcairo2-dev installet!
- micke_nordin
Då ändrar du till:
/Micke
sudo apt-get install libpango1.0-dev libcairo2-dev libatk1.0-dev libgtk2.0-dev
