Går jag ut på http://ipv6.org så står det ju "You are using IPv6 from 2001
2001
Till servern har jag ju dock ett eget nt som tunneln sen är routad över:
sixxs Link encap:IPv6-in-IPv4
inet6 addr: 2001:16d8:ff00:2b9::2/64 Scope:Global
Men jag skulle vilja att servern ansluter över subnätet istället...
ifconfig och "ip -6 route":
root@Sandnabba.se: /home/emil #> ip -6 route
2001:16d8:ff00:2b9::/64 via :: dev sixxs metric 256 mtu 1280 advmss 1220 hoplimit 4294967295
2001:16d8:ff13:dead::/64 dev eth-loc metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth-net metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev eth-loc metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 dev tap0 metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
fe80::/64 via :: dev sixxs metric 256 mtu 1280 advmss 1220 hoplimit 4294967295
ff00::/8 dev eth-net metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev eth-loc metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev tap0 metric 256 mtu 1500 advmss 1440 hoplimit 4294967295
ff00::/8 dev sixxs metric 256 mtu 1280 advmss 1220 hoplimit 4294967295
default via 2001:16d8:ff00:2b9::1 dev sixxs metric 1024 mtu 1280 advmss 1220 hoplimit 4294967295
root@Sandnabba.se: /home/emil #> ifconfig
eth-loc Link encap:Ethernet HWaddr 00:1B:11:F1:00:1C
inet addr:10.0.0.1 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: 2001:16d8:ff13:dead::1/64 Scope:Global
inet6 addr: fe80::21b:11ff:fef1:1c/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:846740 errors:0 dropped:0 overruns:0 frame:0
TX packets:1164728 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:412517348 (393.4 MB) TX bytes:1348802076 (1.2 GB)
Interrupt:5 Base address:0xe400
eth-net Link encap:Ethernet HWaddr 00:01:02:05:16:F7
inet addr:91.95.226.62 Bcast:91.95.231.255 Mask:255.255.248.0
inet6 addr: fe80::201:2ff:fe05:16f7/64 Scope:Link
RX packets:829999 errors:0 dropped:0 overruns:0 frame:0
TX packets:601143 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:963930008 (919.2 MB) TX bytes:125362834 (119.5 MB)
Interrupt:10 Base address:0xc800
inet6 addr: fe80::5b5f:e23e/128 Scope:Link
UP POINTOPOINT RUNNING NOARP MTU:1280 Metric:1
RX packets:24241 errors:0 dropped:0 overruns:0 frame:0
TX packets:21172 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:13424224 (12.8 MB) TX bytes:3016550 (2.8 MB)
Borde väl vara möjligt antar jag? Men hur?
