Vad är detta för fil : /usr/sbin/unhide ?
Edit: /usr/sbin/unhide länkar till : /etc/alternatives/unhide som länkar till : /usr/sbin/unhide-linux26
filen: unhide ?
Re: filen: unhide ?
$ dpkg-query -S /usr/sbin/unhide
unhide: /usr/sbin/unhide
$ apt-cache show unhide
Package: unhide
Priority: extra
Section: universe/admin
Installed-Size: 1916
Maintainer: Ubuntu MOTU Developers <ubuntu-motu@lists.ubuntu.com>
Original-Maintainer: Francois Marier <francois@debian.org>
Architecture: amd64
Version: 20080519-2
Suggests: rkhunter
Filename: pool/universe/u/unhide/unhide_20080519-2_amd64.deb
MD5sum: 0fe00b3da67da35bcee9b6f26017508b
SHA1: 766ad1dbf47b579ae3e6ff4aedfb35be7ab26c9a
SHA256: 15c75d02ec1ec236a08e0e6a6bb7b96b355b8dfebacfe1cf690e015bed8d395e
Description: Forensic tool to find hidden processes and ports
Unhide is a forensic tool to find processes and TCP/UDP ports hidden by
rootkits, Linux kernel modules or by other techniques. It includes two
utilities: unhide and unhide-tcp.
unhide detects hidden processes using three techniques:
- comparing the output of /proc and /bin/ps
- comparing the information gathered from /bin/ps with the one gathered
from system calls (syscall scanning)
- full scan of the process ID space (PIDs bruteforcing)
unhide-tcp identifies TCP/UDP ports that are listening but are not listed in
/bin/netstat through brute forcing of all TCP/UDP ports available.
This package can be used by rkhunter in its daily scans.
Homepage: http://www.security-projects.com/?Unhide
Bugs: mailto:ubuntu-users@lists.ubuntu.com
Origin: Ubuntu
- petroleum
Re: filen: unhide ?
hmm okej .. tack
unhide
apt-cache show filnamn ?
unhide
dessutom lärde jag mig nåt nytt: apt-cacheTo enable it, just remove “hidden_procs” from the DISABLE_TESTS variable in /etc/rkhunter.conf
Re: filen: unhide ?
Nä, apt-cache show paketnamn
- maths57
Re: filen: unhide ?
Jag har inte unhide på mitt system. Antar att man måste installera det separat. Kan det vara så att du har installerat något annat program där unhide följde med som ett s k beroende?
- petroleum
Re: filen: unhide ?
lars .. ok tack
ja, det fanns bara där så det måste ha kommit med något annat jag har installerat
