Om jag startar från terminalen får jag följande felmeddelande:
Starting new FSpot server
Stacktrace:
at (wrapper managed-to-native) GdkGlx.Context.glXChooseVisual (intptr,int,int[]) <0x00004>
at (wrapper managed-to-native) GdkGlx.Context.glXChooseVisual (intptr,int,int[]) <0xffffffff>
at GdkGlx.Context..ctor (Gdk.Screen,GdkGlx.Context,int[]) <0x0008f>
at GdkGlx.Context..ctor (Gdk.Screen,int[]) <0x00012>
at FSpot.PhotoImageView.HandleRealized (object,System.EventArgs) <0x00060>
at FSpot.PhotoImageView..ctor (FSpot.BrowsablePointer) <0x0014f>
at FSpot.PhotoView..ctor (FSpot.IBrowsableCollection) <0x00278>
at MainWindow..ctor (Db) <0x01963>
at FSpot.Core.get_MainWindow () <0x00035>
at FSpot.Core.Organize () <0x0000f>
at FSpot.Driver.Main (string[]) <0x00f7a>
at (wrapper runtime-invoke) FSpot.Driver.runtime_invoke_int_string[] (object,intptr,intptr,intptr) <0xffffffff>
Native stacktrace:
f-spot [0x816b1fa]
f-spot [0x807de81]
[0xb7eff440]
/usr/lib/dri/fglrx_dri.so(__driCreateNewScreen_20050727+0xcf) [0xa41f727f]
/usr/lib/xorg/libGL.so.1 [0xa44faa2e]
/usr/lib/xorg/libGL.so.1(glXChooseVisual+0x37) [0xa44f6b97]
[0xa48159b5]
[0xa4815400]
[0xa481535b]
[0xa48151d9]
[0xa48143a0]
[0xa4812a99]
[0xa4bb1634]
[0xa4baf6ce]
[0xa4baf660]
[0xb7757773]
[0xb77561c4]
f-spot(mono_runtime_exec_main+0x10e) [0x809c68e]
f-spot(mono_runtime_run_main+0x173) [0x809c933]
f-spot(mono_main+0x6a9) [0x805acd9]
f-spot [0x805a122]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe0) [0xb7cb1450]
f-spot [0x805a091]
Debug info from gdb:
(no debugging symbols found)
[Thread debugging using libthread_db enabled]
[New Thread 0xb7c726d0 (LWP 25633)]
[New Thread 0xa4707b90 (LWP 25640)]
[New Thread 0xa480cb90 (LWP 25639)]
[New Thread 0xa5d98b90 (LWP 25636)]
[New Thread 0xb71ceb90 (LWP 25635)]
[New Thread 0xb71f2b90 (LWP 25634)]
0xb7eff410 in __kernel_vsyscall ()
6 Thread 0xb71f2b90 (LWP 25634) 0xb7eff410 in __kernel_vsyscall ()
5 Thread 0xb71ceb90 (LWP 25635) 0xb7eff410 in __kernel_vsyscall ()
4 Thread 0xa5d98b90 (LWP 25636) 0xb7eff410 in __kernel_vsyscall ()
3 Thread 0xa480cb90 (LWP 25639) 0xb7eff410 in __kernel_vsyscall ()
2 Thread 0xa4707b90 (LWP 25640) 0xb7eff410 in __kernel_vsyscall ()
1 Thread 0xb7c726d0 (LWP 25633) 0xb7eff410 in __kernel_vsyscall ()
Thread 6 (Thread 0xb71f2b90 (LWP 25634)):
#0 0xb7eff410 in __kernel_vsyscall ()
#1 0xb7e1c196 in nanosleep () from /lib/tls/i686/cmov/libpthread.so.0
#2 0x08105c91 in ?? ()
#3 0xb7e144fb in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#4 0xb7d71e5e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 5 (Thread 0xb71ceb90 (LWP 25635)):
#1 0xb7e18aa5 in pthread_cond_wait@@GLIBC_2.3.2 ()
#2 0x081088ff in ?? ()
#3 0x0810b3cd in ?? ()
#4 0x0810b43c in ?? ()
#5 0x0811ba1a in ?? ()
#6 0x080b1c0a in ?? ()
#7 0x080cef04 in ?? ()
#8 0x0811a7c2 in ?? ()
#9 0x081317a5 in ?? ()
#10 0xb7e144fb in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#11 0xb7d71e5e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 4 (Thread 0xa5d98b90 (LWP 25636)):
#1 0xb7e18dd2 in pthread_cond_timedwait@@GLIBC_2.3.2 ()
#2 0x081088ba in ?? ()
#6 0x080cca8e in ?? ()
#7 0xb5a784a2 in ?? ()
#8 0xb5a78293 in ?? ()
#9 0xb5a76eeb in ?? ()
#10 0xb5a76d6a in ?? ()
#11 0xb7759fc9 in ?? ()
#12 0x08095ea4 in mono_runtime_delegate_invoke ()
#13 0x080cef6e in ?? ()
#14 0x0811a7c2 in ?? ()
#15 0x081317a5 in ?? ()
#16 0xb7e144fb in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#17 0xb7d71e5e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 3 (Thread 0xa480cb90 (LWP 25639)):
#6 0x080cbc7e in ?? ()
#7 0xa480d66a in ?? ()
#8 0xa480d54e in ?? ()
#9 0xa480d470 in ?? ()
Thread 2 (Thread 0xa4707b90 (LWP 25640)):
#9 0xa480d836 in ?? ()
Thread 1 (Thread 0xb7c726d0 (LWP 25633)):
#1 0xb7d6a881 in select () from /lib/tls/i686/cmov/libc.so.6
#2 0xb7e991a4 in g_spawn_sync () from /usr/lib/libglib-2.0.so.0
#3 0xb7e9956c in g_spawn_command_line_sync () from /usr/lib/libglib-2.0.so.0
#4 0x0816b295 in ?? ()
#5 0x0807de81 in ?? ()
#6 <signal handler called>
#7 0xa451abdf in AtiCallFGLGetGPUMapInfo () from /usr/lib/xorg/libGL.so.1
#8 0xa41f727f in __driCreateNewScreen_20050727 ()
from /usr/lib/dri/fglrx_dri.so
#9 0xa44faa2e in ?? () from /usr/lib/xorg/libGL.so.1
#10 0xa44f6b97 in glXChooseVisual () from /usr/lib/xorg/libGL.so.1
#11 0xa48159b5 in ?? ()
#12 0xa4815400 in ?? ()
#13 0xa481535b in ?? ()
#14 0xa48151d9 in ?? ()
#15 0xa48143a0 in ?? ()
#16 0xa4812a99 in ?? ()
#17 0xa4bb1634 in ?? ()
#18 0xa4baf6ce in ?? ()
#19 0xa4baf660 in ?? ()
#20 0xb7757773 in ?? ()
#21 0xb77561c4 in ?? ()
#22 0x0809c68e in mono_runtime_exec_main ()
#23 0x0809c933 in mono_runtime_run_main ()
#24 0x0805acd9 in mono_main ()
#25 0x0805a122 in ?? ()
#26 0xb7cb1450 in __libc_start_main () from /lib/tls/i686/cmov/libc.so.6
#27 0x0805a091 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Avbruten (SIGABRT)
Så nu undrar jag om det finns någon go ubuntuist som kan hjälpa mig med detta?
Tack på förhand,
Anders
