För att hitta mini-ison som gör det snabbt att installera ett cli system (boot parameter: cli) följ länken nedan. För att få in scriptet i maskinen om ni ids testa får ni använda er fantasi.
https://help.ubuntu.com/community/Insta ... /MinimalCD.
Här är scriptet då:
#!/bin/bash
# Install script for LXDE on Ubuntu 8.10 Intrepid Ibex.
# It is recommended to run this install script on a fresh cli system.
echo "Checking Ubuntu version . . . "
if test $(lsb_release -rs) != "8.10"; then
echo "Error: system must be Ubuntu 8.10"
echo "Exit"
exit
fi
# What repos to use.
echo -n "Activate Backports and Partner repositories? [y/N] "
read REPLY
case $REPLY in
[Yy]*)
sudo cp /etc/apt/sources.list /etc/apt/sources.list.old
sudo sed 's/# deb/deb/' /etc/apt/sources.list > /etc/apt/sources.list.tmp
sudo mv /etc/apt/sources.list.tmp /etc/apt/sources.list
echo "Your sources.list is left alone"
esac
# To medi or not to medi?
echo -n "Do you wish to install software from Medibuntu, (options for removing non-free software are provided)? [y/N] "
read REPLY
case $REPLY in
[Yy]*)
sudo wget http://www.medibuntu.org/sources.list.d/intrepid.list --output-document=/etc/apt/sources.list.d/medibuntu.list
sudo apt-get update && sudo apt-get install medibuntu-keyring && sudo apt-get update
echo -n "Remove non-free medibuntu software? [y/N] "
read REPLY
case $REPLY in
[Yy]*)
sudo sed -e 's/ non-free//' -i /etc/apt/sources.list.d/medibuntu.list
esac
echo "Continuing"
esac
# Make install current.
sudo apt-get update
sudo apt-get upgrade
# Finaly!
while echo -n "Do you want a minimal, bare or extensive install? [m/b/e] "
do read REPLY
case $REPLY in
[Mm]*)
sudo apt-get install lxde xterm xpdf dillo
break ;;
[Bb]*)
sudo apt-get install lxde xterm synaptic xpdf abiword gnumeric epiphany lxrandr lxnm
break ;;
[Ee]*)
sudo apt-get install lxde lxterminal synaptic xpdf openoffice.org firefox mplayer libdvdcss2 w32codecs grandr lxnm flashplayer-nonfree
break ;;
esac
done
mkdir $HOME/Desktop
echo "Installation complete! Reboot and have fun!"
Tack på för hand!!
//Simon
