problem med unrar
Zeba
problem med unrar
Inlägg av Zeba »
Kan inte packa upp rar filer.
Jag har installerat de flesta unrar/unzip program som finns, men det funkar ändå inte!
Det står RW på skydd.
Om filerna är passwordprotected så har jag lösenordet, men hur ska jag skriva in det när jag bara får felmeddelanden?
Felmedelande "ett fel uppstod vid försök att öppna arkivet.
tar -xvzf makingitT1part1.rar
tar: makingitT1part1.rar: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
unrar makingitT1part1.rar
UNRAR 3.71 beta 1 freeware Copyright (c) 1993-2007 Alexander Roshal
Usage: unrar <command> -<switch 1> -<switch N> <archive> <files...>
<@listfiles...> <path_to_extract\>
<Commands>
e Extract files to current directory
l[t,b] List archive [technical, bare]
p Print file to stdout
t Test archive files
v[t,b] Verbosely list archive [technical,bare]
x Extract files with full path
<Switches>
- Stop switches scanning
ad Append archive name to destination path
ap<path> Set path inside archive
av- Disable authenticity verification check
c- Disable comments show
cfg- Disable read configuration
cl Convert names to lower case
cu Convert names to upper case
dh Open shared files
ep Exclude paths from names
ep3 Expand paths to full including the drive letter
f Freshen files
id[c,d,p,q] Disable messages
ierr Send all messages to stderr
inul Disable all messages
kb Keep broken extracted files
n<file> Include only specified file
n@ Read file names to include from stdin
n@<list> Include files in specified list file
o+ Overwrite existing files
o- Do not overwrite existing files
or Rename files automatically
ow Save or restore file owner and group
p[password] Set password
p- Do not query password
r Recurse subdirectories
sl<size> Process files with size less than specified
sm<size> Process files with size more than specified
ta<date> Process files modified after <date> in YYYYMMDDHHMMSS format
tb<date> Process files modified before <date> in YYYYMMDDHHMMSS format
tn<time> Process files newer than <time>
to<time> Process files older than <time>
ts<m,c,a>[N] Save or restore file time (modification, creation, access)
u Update files
v List all volumes
ver[n] File version control
vp Pause before each volume
x<file> Exclude specified file
x@ Read file names to exclude from stdin
x@<list> Exclude files in specified list file
y Assume Yes on all queries
mcNisse
Re: problem med unrar
Inlägg av mcNisse »
Detta borde fungera:
unrar e makingitT1part1.rar
Det packar upp i aktuell katalog. Byt ut e mot p om du vill titta i arkivet.
