Jag hittade "Julius" i Synaptic.
Tittade även lite på www.
Det så intressant ut. så jag intsallerade det.
Men vart tog det vägen?
Hur använder jag det?
Julius; speech recognition
- OS: Crunchbang
Re: Julius; speech recognition
Jag kollade på det lite snabbt och det verkar behövas en del konfiguration innan användning
om du skriver
alternativt
i terminalen så får du nog lite mer hjälp, annars kan du läsa i
för mer information.
om du skriver
julius
julius -settting
man julius
- OS: Crunchbang
This was very interesting. I have been using speech recognition for quite some time. But it is only the English version that is good enough. And now as I have switched to open source, it would be great if this programme could support me in the future.
Together with "Konservburk" there has been "progress" in speech synthesising.
You may take a look at the link
http://ubuntu-se.org/phpBB3/viewtopic.p ... 60#p262066
My knowledge in speech recognition is only at the level as a user. Even though I'm an engineer and salesperson. I
f you have further knowledge about this. I would be very happy to continue a similar program as ongoing with "Konservburk" about speech synteszier. It might be so that this programme is still at a level that it is actually difficult to use.
However I got really excited.
By the way the reason for being able to read the manual. Was thanks to the speech synthesiser, that has been put together with the key mapping here on this forum.
This text has been created with the programme called Dragon NaturallySpeaking. I have of course also edit it manually, that is why you might find some misspelling. I hope this will encourage you and other readers in this forum to participate.
Welcome,
Hans
Welcome,
Hans
- OS: Crunchbang
Eftersom i alla fall min "bandbredd" är utnyttjad, så skulle det vara kul om ett annat "team" tog sig an "tal till text".
Julius skulle jag vilja ha i mitt verktygs kit.
