Här är några exempel på bookmarklets som fungerar (utan att posta ett utdrag av texten då):
javascript:void(document.location%20=%20('http://www.example.com/Pligg%20Beta%209.9.5/submit.php?url='.concat(encodeURIComponent(document.location))))
javascript:%20d=document;void(window.open('http://www.example.com/post?url='+encodeURIComponent(d.location.href)+'&title='+encodeURIComponent(d.title)+'&description='+encodeURIComponent(d.selection?d.selection.createRange().text:d.getSelection())))
<?php
// The source code packaged with this file is Free Software, Copyright (C) 2005 by
// Ricardo Galli <gallir at uib dot es>.
// It's licensed under the AFFERO GENERAL PUBLIC LICENSE unless stated otherwise.
// You can get copies of the licenses here:
// http://www.affero.org/oagpl.html
// AFFERO GENERAL PUBLIC LICENSE is also included in the file called "COPYING".
include_once('Smarty.class.php');
$main_smarty = new Smarty;
include('config.php');
include(mnminclude.'html1.php');
include(mnminclude.'ts.php');
include(mnminclude.'link.php');
include(mnminclude.'tags.php');
include(mnminclude.'smartyvariables.php');
// html tags allowed during submit
$main_smarty->assign('Story_Content_Tags_To_Allow', htmlspecialchars(Story_Content_Tags_To_Allow));
// breadcrumbs and page titles
$navwhere['text1'] = $main_smarty->get_config_vars('PLIGG_Visual_Breadcrumb_Submit');
$navwhere['link1'] = getmyurl('submit', '');
$main_smarty->assign('navbar_where', $navwhere);
$main_smarty->assign('posttitle', " / " . $main_smarty->get_config_vars('PLIGG_Visual_Breadcrumb_Submit'));
$main_smarty = do_sidebar($main_smarty);
// make sure user is logged in
force_authentication();
// module system hook
$vars = '';
check_actions('submit_post_authentication', $vars);
// this is for direct links from weblogs
if(empty($_POST['phase']) && !empty($_GET['url'])) {
$_POST['phase'] = 1;
$_POST['url'] = $_GET['url'];
$_POST['randkey'] = rand(10000,10000000);
if(!empty($_GET['trackback']))
$_POST['trackback'] = $_GET['trackback'];
// determine which step of the submit process we are on
if(isset($_POST["phase"])) {
$phase = $_POST["phase"];
else {
$phase = 0;
// If show URL input box is disabled, go straight to step 2
if($phase == 0 && Submit_Show_URL_Input == false) {
$phase = 1;
switch ($phase) {
case 0:
do_submit0();
break;
case 1:
do_submit1();
break;
case 2:
do_submit2();
break;
case 3:
do_submit3();
break;
exit;
// enter URL before submit process
function do_submit0() {
global $main_smarty, $the_template;
$main_smarty->assign('submit_rand', rand(10000,10000000));
$main_smarty->assign('Submit_Show_URL_Input', Submit_Show_URL_Input);
$main_smarty->assign('Submit_Require_A_URL', Submit_Require_A_URL);
define('pagename', 'submit');
$main_smarty->assign('pagename', pagename);
$main_smarty->assign('tpl_center', $the_template . '/submit_step_1');
$vars = '';
check_actions('do_submit0', $vars);
$main_smarty->display($the_template . '/pligg.tpl');
// submit step 1
function do_submit1() {
global $main_smarty, $db, $dblang, $current_user, $the_template;
$url = htmlspecialchars(strip_tags(trim($_POST['url'])));
$url = str_replace('&', '&', $url);
$url = html_entity_decode($url);
$linkres=new Link;
$linkres->randkey = strip_tags($_POST['randkey']);
if(Submit_Show_URL_Input == false) {
$url = "http://";
$linkres->randkey = rand(10000,10000000);
$Submit_Show_URL_Input = Submit_Show_URL_Input;
if($url == "http://" || $url == ""){
$Submit_Show_URL_Input = false;
$main_smarty->assign('randkey', $linkres->randkey);
$main_smarty->assign('submit_url', $url);
$main_smarty->assign('Submit_Show_URL_Input', $Submit_Show_URL_Input);
$edit = false;
$linkres->get($url);
$trackback=$linkres->trackback;
if(Submit_Require_A_URL == false){
$linkres->valid = true;}
else{
$linkres->valid = false;
$linkres->url_title = "";
$vars = array("url" => $url,'linkres'=>$linkres);
check_actions('submit_validating_url', $vars);
$linkres = $vars['linkres'];
if(!$linkres->valid) {
$main_smarty->assign('submit_error', 'invalidurl');
$main_smarty->assign('tpl_center', $the_template . '/submit_errors');
return;
if(Submit_Require_A_URL == true || ($url != "http://" && $url != "")){
if($linkres->duplicates($url) > 0) {
$main_smarty->assign('submit_search', getmyurl("search_url", htmlentities($url)));
$main_smarty->assign('submit_error', 'dupeurl');
return;
$vars = array("url" => $url);
totals_adjust_count('discard', 1);
$linkres->status='discard';
$linkres->author=$current_user->user_id;
$linkres->store();
$main_smarty->assign('StorySummary_ContentTruncate', StorySummary_ContentTruncate);
$main_smarty->assign('SubmitSummary_Allow_Edit', SubmitSummary_Allow_Edit);
$main_smarty->assign('enable_tags', Enable_Tags);
$main_smarty->assign('submit_url_title', $linkres->url_title);
$main_smarty->assign('submit_id', $linkres->id);
$main_smarty->assign('submit_type', $linkres->type());
if(isset($link_title)){$main_smarty->assign('submit_title', $link_title);}
if(isset($link_content)){$main_smarty->assign('submit_content', $link_content);}
$main_smarty->assign('submit_trackback', $trackback);
$main_smarty->assign('submit_link_field1', $linkres->link_field1);
$main_smarty->assign('submit_link_field2', $linkres->link_field2);
$main_smarty->assign('submit_link_field3', $linkres->link_field3);
$main_smarty->assign('submit_link_field4', $linkres->link_field4);
$main_smarty->assign('submit_link_field5', $linkres->link_field5);
$main_smarty->assign('submit_link_field6', $linkres->link_field6);
$main_smarty->assign('submit_link_field7', $linkres->link_field7);
$main_smarty->assign('submit_link_field8', $linkres->link_field8);
$main_smarty->assign('submit_link_field9', $linkres->link_field9);
$main_smarty->assign('submit_link_field10', $linkres->link_field10);
$main_smarty->assign('submit_link_field11', $linkres->link_field11);
$main_smarty->assign('submit_link_field12', $linkres->link_field12);
$main_smarty->assign('submit_link_field13', $linkres->link_field13);
$main_smarty->assign('submit_link_field14', $linkres->link_field14);
$main_smarty->assign('submit_link_field15', $linkres->link_field15);
include_once(mnminclude.'dbtree.php');
$array = tree_to_array(0, table_categories, FALSE);
$main_smarty->assign('submit_lastspacer', 0);
$main_smarty->assign('submit_cat_array', $array);
$main_smarty->assign('Spell_Checker', Spell_Checker);
$main_smarty->assign('tpl_extra_fields', $the_template . '/submit_extra_fields');
$main_smarty->assign('tpl_center', $the_template . '/submit_step_2');
$vars = '';
check_actions('do_submit1', $vars);
// submit step 2
function do_submit2() {
global $db, $main_smarty, $dblang, $the_template, $linkres, $current_user;
$main_smarty->assign('auto_vote', auto_vote);
$linkres=new Link;
$linkres->id=$link_id = $_POST['id'];
if(!$linkres->verify_ownership($current_user->user_id)){
die($main_smarty->get_config_vars('PLIGG_Visual_Submit2Errors_NoAccess'));
$linkres->read(FALSE);
if($linkres->votes($current_user->user_id) == 0 && auto_vote == true) {
$linkres->insert_vote($current_user->user_id, '10');
$linkres->store_basic();
$linkres->category=$_POST['category'];
$linkres->title = strip_tags(trim($_POST['title']));
$linkres->title_url = makeUrlFriendly($linkres->title);
$linkres->tags = tags_normalize_string(strip_tags(trim($_POST['tags'])));
$linkres->content = strip_tags(trim($_POST['bodytext']), Story_Content_Tags_To_Allow);
$linkres->content = str_replace("\n", "<br />", $linkres->content);
// Steef 2k7-07 security fix start ----------------------------------------------------------
if(isset($_POST['link_field1'])){$linkres->link_field1 = strip_tags(trim($_POST['link_field1']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field2'])){$linkres->link_field2 = strip_tags(trim($_POST['link_field2']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field3'])){$linkres->link_field3 = strip_tags(trim($_POST['link_field3']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field4'])){$linkres->link_field4 = strip_tags(trim($_POST['link_field4']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field5'])){$linkres->link_field5 = strip_tags(trim($_POST['link_field5']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field6'])){$linkres->link_field6 = strip_tags(trim($_POST['link_field6']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field7'])){$linkres->link_field7 = strip_tags(trim($_POST['link_field7']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field8'])){$linkres->link_field8 = strip_tags(trim($_POST['link_field8']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field9'])){$linkres->link_field9 = strip_tags(trim($_POST['link_field9']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field10'])){$linkres->link_field10 = strip_tags(trim($_POST['link_field10']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field11'])){$linkres->link_field11 = strip_tags(trim($_POST['link_field11']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field12'])){$linkres->link_field12 = strip_tags(trim($_POST['link_field12']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field13'])){$linkres->link_field13 = strip_tags(trim($_POST['link_field13']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field14'])){$linkres->link_field14 = strip_tags(trim($_POST['link_field14']), Story_Content_Tags_To_Allow);}
if(isset($_POST['link_field15'])){$linkres->link_field15 = strip_tags(trim($_POST['link_field15']), Story_Content_Tags_To_Allow);}
// Steef 2k7-07 security fix end --------------------------------------------------------------
if(!isset($_POST['summarytext'])){
$linkres->link_summary = utf8_substr(strip_tags(trim($_POST['bodytext']), Story_Content_Tags_To_Allow), 0, StorySummary_ContentTruncate - 1);
$linkres->link_summary = str_replace("\n", "<br />", $linkres->link_summary);
} else {
$linkres->link_summary = strip_tags(trim($_POST['summarytext']), Story_Content_Tags_To_Allow);
if(strlen($linkres->link_summary) > StorySummary_ContentTruncate){
loghack('SubmitAStory-SummaryGreaterThanLimit', 'username: ' . $_POST["username"].'|email: '.$_POST["email"], true);
$linkres->link_summary = utf8_substr($linkres->link_summary, 0, StorySummary_ContentTruncate - 1);
if (link_errors($linkres)) {
return;
$linkres->store();
tags_insert_string($linkres->id, $dblang, $linkres->tags);
$vars = '';
check_actions('submit_step_3_after_first_store', $vars);
$edit = true;
$link_title = $linkres->title;
$link_content = $linkres->content;
$link_title = stripslashes(strip_tags(trim($_POST['title'])));
$main_smarty->assign('the_story', $linkres->print_summary('full', true));
$main_smarty->assign('tags', $linkres->tags);
if (!empty($linkres->tags)) {
$tags_words = str_replace(",", ", ", $linkres->tags);
$tags_url = urlencode($linkres->tags);
$main_smarty->assign('tags_words', $tags_words);
$main_smarty->assign('tags_url', $tags_url);
if(isset($url)){
} else {
$main_smarty->assign('submit_url', '');
if(isset($trackback)){
} else {
$main_smarty->assign('submit_trackback', '');
$main_smarty->assign('tpl_center', $the_template . '/submit_step_3');
$vars = '';
check_actions('do_submit2', $vars);
// submit step 3
function do_submit3() {
global $db;
$linkres=new Link;
$linkres->id=$link_id = strip_tags($_POST['id']);
if(!is_numeric($linkres->id))die();
$linkres->read();
totals_adjust_count($linkres->status, -1);
totals_adjust_count('queued', 1);
$linkres->status='queued';
$vars = array('linkres'=>$linkres);
check_actions('do_submit3', $vars);
$linkres->check_should_publish();
if(!empty($_POST['trackback'])) {
require_once(mnminclude.'trackback.php');
$trackres = new Trackback;
$trackres->url=trim($_POST['trackback']);
$trackres->link=$linkres->id;
$trackres->title=$linkres->title;
$trackres->author=$linkres->author;
$trackres->content=$linkres->content;
$res = $trackres->send();
header("Location: " . getmyurl('upcoming'));
die;
// assign any errors found during submit
function link_errors($linkres)
$error = false;
if($_POST['randkey'] !== $linkres->randkey) { // random key error
$main_smarty->assign('submit_error', 'badkey');
$main_smarty->display($the_template . '/submit_errors.tpl');
$error = true;
if($linkres->status != 'discard') { // if link has already been submitted
$main_smarty->assign('submit_error', 'hashistory');
$main_smarty->assign('submit_error_history', $linkres->status);
$error = true;
if(strlen($linkres->title) < minTitleLength || strlen($linkres->content) < minStoryLength ) { // if link title or descrition is too short
$main_smarty->assign('submit_error', 'incomplete');
$error = true;
if(preg_match('/.*http:\//', $linkres->title)) { // if URL is found in link title
$main_smarty->assign('submit_error', 'urlintitle');
$error = true;
if(!$linkres->category > 0) { // if no category is selected
$main_smarty->assign('submit_error', 'nocategory');
$error = true;
return $error;
