Jag vil att windows starta först i grub /menu list
smari57
Inlägg av smari57 »
Hej
jag vill att Window xp startar först då min fru använder dator. hon är inte insresserad av Linux
här är min grub menu list var ska jag ändra i den så aatt windows starta först
smari57
# menu.lst - See: grub(8), info grub, update-grub(8)
# grub-install(8), grub-floppy(8),
# grub-md5-crypt, /usr/share/doc/grub
# and /usr/share/doc/grub-doc/.
## default num
# Set the default entry to the entry number NUM. Numbering starts from 0, and
# the entry number 0 is the default if the command is not used.
# You can specify 'saved' instead of a number. In this case, the default entry
# is the entry saved with the command 'savedefault'.
# WARNING: If you are using dmraid do not use 'savedefault' or your
# array will desync and will not let you boot your system.
default 0
## timeout sec
# Set a timeout, in SEC seconds, before automatically booting the default entry
# (normally the first entry defined).
timeout 10
## hiddenmenu
# Hides the menu by default (press ESC to see the menu)
#hiddenmenu
# Pretty colours
#color cyan/blue white/blue
## password ['--md5'] passwd
# If used in the first section of a menu file, disable all interactive editing
# control (menu entry editor and command-line) and entries protected by the
# command 'lock'
# e.g. password topsecret
# password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
# password topsecret
# examples
# title Windows 95/98/NT/2000
# root (hd0,0)
# makeactive
# chainloader +1
# title Linux
# root (hd0,1)
# kernel /vmlinuz root=/dev/hda2 ro
# Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
### BEGIN AUTOMAGIC KERNELS LIST
## lines between the AUTOMAGIC KERNELS LIST markers will be modified
## by the debian update-grub script except for the default options below
## DO NOT UNCOMMENT THEM, Just edit them to your needs
## ## Start Default Options ##
## default kernel options
## default kernel options for automagic boot options
## If you want special options for specific kernels use kopt_x_y_z
## where x.y.z is kernel version. Minor versions can be omitted.
## e.g. kopt=root=/dev/hda1 ro
## kopt_2_6_8=root=/dev/hdc1 ro
## kopt_2_6_8_2_686=root=/dev/hdc2 ro
# kopt=root=UUID=314d2f6d-8ff9-49e5-a3a2-282a2fd10ba9 ro
## default grub root device
## e.g. groot=(hd0,0)
# groot=314d2f6d-8ff9-49e5-a3a2-282a2fd10ba9
## should update-grub create alternative automagic boot options
## e.g. alternative=true
## alternative=false
# alternative=true
## should update-grub lock alternative automagic boot options
## e.g. lockalternative=true
## lockalternative=false
## additional options to use with the default boot option, but not with the
## alternatives
## e.g. defoptions=vga=791 resume=/dev/hda5
# defoptions=quiet splash
## should update-grub lock old automagic boot options
## e.g. lockold=false
## lockold=true
# lockold=false
## Xen hypervisor options to use with the default Xen boot option
# xenhopt=
## Xen Linux kernel options to use with the default Xen boot option
# xenkopt=console=tty0
## altoption boot targets option
## multiple altoptions lines are allowed
## e.g. altoptions=(extra menu suffix) extra boot options
## altoptions=(recovery) single
# altoptions=(recovery mode) single
## controls how many kernels should be put into the menu.lst
## only counts the first occurence of a kernel, not the
## alternative kernel options
## e.g. howmany=all
## howmany=7
# howmany=all
## should update-grub create memtest86 boot option
## e.g. memtest86=true
## memtest86=false
# memtest86=true
## should update-grub adjust the value of the default booted system
## can be true or false
# updatedefaultentry=false
## should update-grub add savedefault to the default options
# savedefault=false
## ## End Default Options ##
title Ubuntu 8.10, kernel 2.6.27-7-generic
uuid 314d2f6d-8ff9-49e5-a3a2-282a2fd10ba9
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=314d2f6d-8ff9-49e5-a3a2-282a2fd10ba9 ro quiet splash
initrd /boot/initrd.img-2.6.27-7-generic
quiet
title Ubuntu 8.10, kernel 2.6.27-7-generic (recovery mode)
kernel /boot/vmlinuz-2.6.27-7-generic root=UUID=314d2f6d-8ff9-49e5-a3a2-282a2fd10ba9 ro single
title Ubuntu 8.10, memtest86+
kernel /boot/memtest86+.bin
quiet
### END DEBIAN AUTOMAGIC KERNELS LIST
# This is a divider, added to separate the menu items below from the Debian
# ones.
title Other operating systems:
root
# This entry automatically added by the Debian installer for a non-linux OS
# on /dev/sda1
title Microsoft Windows XP Home Edition
root (hd0,0)
savedefault
makeactive
chainloader +1
mcNisse
Re: Jag vil att windows starta först i grub /menu list
Inlägg av mcNisse »
Stoppa in windows i tomraden ovan, dvs det som står nedanför.
root (hd0,0)
savedefault
makeactive
chainloader +1
smari57
Inlägg av smari57 »
hej
det var enkelt nu startar windows xp först.
tack för hjälpen
smari57
balkansuperstar
Inlägg av balkansuperstar »
tjena jag behöver också hjälp, dethär med Grub... först och främst hade jag ingen aning om vilket helvette som väntade mig när jag installerade ubuntu på min acer (vista home premium) jag vill helst av allt bli av med ubuntu och det hemska programmet grub!!! trodde jag var smart igår och tog bort partitionen men då vägrade datorn starta så ja installera ubuntu igen så funka de... nu skulle ja vilja fråga er proffs här.... hur tar jag bort Ubuntu, Grub och får tillbaka windows MBR!!!
ett litet problem är att acer e så snåla så jag fick ingen vista skiva med.. kom inte en enda cd med datorn... så jag kan inte fixa de på de sättet... går de att på något sätt innuti vista skriva in något kommando som fixar vista MBR till det vanliga?:) vilket programm ska jag använda isåfall och hur går jag tillväga?? jag har noll koll kokosboll när de gäller vista.. och ennu värre ligger det till med ubuntu!
anledningen varför jag isntallerade ubuntu från första början e att jag fick en impuls och fick för mig att testa hur det var:)
snälla hjälp mig!!! MVH!
bbauto
Inlägg av bbauto »
root (hd0,0)
savedefault
makeactive
chainloader +1
Jepp det funkar bra, men inte säker på hur uppgraderingar sköter ovanstående. Annars kan man byta default = 0 -> 3
Första valet = 0, andra = 1, tredje = 2 etc, räkna antalet titlar... 0,1,2,3
default 0 --> 3
## timeout sec
timeout 10
mcNisse
Inlägg av mcNisse »
bbauto skrev:Jepp det funkar bra, men inte säker på hur uppgraderingar sköter ovanstående. Annars kan man byta default = 0 -> 3
Poängen med att lägga windows där jag beskriver är att den blir oberoende av nya kärnor (uppdateringar). När man får en ny kärna läggs din in som 1. Windows blir tyvår kvar som alternav 0, beroende på hur man ser på saken ;)
bbauto
Inlägg av bbauto »
Ja körde samma metod som dig på 7.04, men har för mig att grub uppdaterades felaktigt, men det kan ha varit vid uppgradering till 7.10. Numera har jag satt en max gräns på 2 kärnor (vill ju kunna backa om jag får en riktigt sur en) vilket innebär att grub inte fylls på med fler. Alla sätt är bra, när det funkar... :)
krassegrand
Inlägg av krassegrand »
Nedan står de sista raderna i min boot/grub/menu.lst. Kan man helt enkelt stuva om i ordningen genom att flytta styckena upp eller ner?
title Ubuntu 9.04, kernel 2.6.28-11-generic
root (hd0,0)
kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro quiet splash
initrd /boot/initrd.img-2.6.28-11-generic
quiet
title Ubuntu 9.04, kernel 2.6.28-11-generic (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro single
title Ubuntu 9.04, kernel 2.6.27-11-generic
root (hd0,0)
kernel /boot/vmlinuz-2.6.27-11-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro quiet splash
initrd /boot/initrd.img-2.6.27-11-generic
quiet
title Ubuntu 9.04, kernel 2.6.27-11-generic (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.27-11-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro single
title Ubuntu 9.04, kernel 2.6.24-24-generic
root (hd0,0)
kernel /boot/vmlinuz-2.6.24-24-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro quiet splash
initrd /boot/initrd.img-2.6.24-24-generic
quiet
title Ubuntu 9.04, kernel 2.6.24-24-generic (recovery mode)
root (hd0,0)
kernel /boot/vmlinuz-2.6.24-24-generic root=UUID=a0491c80-92be-4d40-8abc-e110b914f2a4 ro single
title Ubuntu 9.04, memtest86+
root (hd0,0)
quiet
# ones.
root
# on /dev/sdb1
root (hd1,0)
savedefault
makeactive
map (hd0) (hd1)
map (hd1) (hd0)
chainloader +1
Tex. om jag flyttar
root (hd0,0)
quiet
ner till efter det stycke som heter nästan samma men där 2.6.28-11 ersätts av 2.6.27-11?
Jag vill att det 3e alternativet ska vara det som startar automatiskt.
Jörgen
bbauto
Inlägg av bbauto »
Ja du kan stuva om styckena precis som du vill, eller ta bort dom du inte önskar, tänk bara på att default = 0 pekar på översta titeln, =1 pekar på andra etc
Titta längre upp i filen /boot/grub/menu.lst
## default num
default 0 <-- Pekar på första titeln, dvs det som kommer starta upp automatiskt efter inställd timeout nedan...
## timeout sec
timeout 5 <-- Timeout innan default title startar...
## e.g. howmany=all
## howmany=7
# howmany=2 <-- Hur många kärnor du vill ha i grub menyn, detta innebär att du kan sätta ex. default = 4 om du har windows. när det kommer en ny kärna så kommer grub rensa bort övriga dvs. att den kommer behålla windows som default...
TweekiE
Inlägg av TweekiE »
balkansuperstar skrev:tjena jag behöver också hjälp, dethär med Grub... först och främst hade jag ingen aning om vilket helvette som väntade mig när jag installerade ubuntu på min acer (vista home premium) jag vill helst av allt bli av med ubuntu och det hemska programmet grub!!! trodde jag var smart igår och tog bort partitionen men då vägrade datorn starta så ja installera ubuntu igen så funka de... nu skulle ja vilja fråga er proffs här.... hur tar jag bort Ubuntu, Grub och får tillbaka windows MBR!!!
skapa en ny tråd!
OT: och vad är det som inte funkar med ubuntu?
