Hur göra? Formatera, tuta och köra verkar inte funka så väl
Mvh
Johan Linnarsson
/dev/sdb1 on /media/disk type ext3 (rw,nosuid,nodev,uhelper=hal)
/dev/hdc2 on / type ext3 (rw,relatime,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
/sys on /sys type sysfs (rw,noexec,nosuid,nodev)
varrun on /var/run type tmpfs (rw,noexec,nosuid,nodev,mode=0755)
varlock on /var/lock type tmpfs (rw,noexec,nosuid,nodev,mode=1777)
udev on /dev type tmpfs (rw,mode=0755)
devshm on /dev/shm type tmpfs (rw)
devpts on /dev/pts type devpts (rw,gid=5,mode=620)
lrm on /lib/modules/2.6.24-21-generic/volatile type tmpfs (rw)
/dev/hdc3 on /home type ext3 (rw,relatime)
securityfs on /sys/kernel/security type securityfs (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
gvfs-fuse-daemon on /home/johan/.gvfs type fuse.gvfs-fuse-daemon (rw,nosuid,nodev,user=johan)
/dev/hdb1 on /media/Bocken2 type fuseblk (rw,nosuid,nodev,noatime,allow_other,blksize=4096)
grep -i sdb1 /etc/fstab
sudo blkid
sudo blkid
/dev/sda1: UUID="702062B120627E4A" LABEL="Bocken1" TYPE="ntfs"
/dev/hdb1: UUID="CAA4D265A4D25393" LABEL="Bocken2" TYPE="ntfs"
/dev/hdc1: TYPE="swap" UUID="7cde332d-3c0d-42d0-ac37-081558b1e0f6"
/dev/hdc2: UUID="ffe9ea51-9a22-4044-9024-2d9aff18260f" TYPE="ext3"
/dev/hdc3: UUID="d4ecf39a-1ef6-43c3-8d6e-697ea3013f48" TYPE="ext3"
/dev/sdb1: UUID="fd4acaed-9b49-46e4-a582-96972a8787e7" TYPE="ext3"
sudo mkdir /media/sdb1
sudo gedit /etc/fstab
UUID="fd4acaed-9b49-46e4-a582-96972a8787e7 /media/sdb1 ext3 defaults,relatime 0 2
sudo mount -a
sudo e2label /dev/sdb1 "namnet på din disk"
UUID=fd4acaed-9b49-46e4-a582-96972a8787e7 /media/sdb1 ext3 defaults,relatime 0 2
sudo chown datar:datar /media/sdb1
sudo chgrp plugdev /media/sdb1
sudo chmod g+w /media/sdb1
Inte riktigt verkar det somI Linux heter det "formatera, montera och köra" :-)
sudo apt-get install pysdm
