Problem med WLAN (iwl4965)
Nätverkskort (även trådlösa), modem och bredbandsmodem
trasan
Inlägg av trasan »
Hej
Sedan en tid tillbaka fungerar inte mitt trådlösa längre.
Funkade out-of-the-box vid installation, men sedan antagligen en uppdateringsfas så vill det ej mer.
Lite uppgifter:
Version: Ubuntu 8.04 - Hardy Heron
ifconfig
wlan0     Link encap:Ethernet  HWaddr 00:21:5c:56:e0:43
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0:avahi Link encap:Ethernet  HWaddr 00:21:5c:56:e0:43
          inet addr:169.254.6.171  Bcast:169.254.255.255  Mask:255.255.0.0
wmaster0  Link encap:UNSPEC  HWaddr 00-21-5C-56-E0-43-00-00-00-00-00-00-00-00-00-00
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
dmesg | grep iw
[   31.720961] iwl4965: Intel(R) Wireless WiFi Link 4965AGN driver for Linux, 1.2.0
[   31.720964] iwl4965: Copyright(c) 2003-2007 Intel Corporation
[   31.721156] iwl4965: Detected Intel Wireless WiFi Link 4965AGN
[   32.308818] iwl4965: Tunable channels: 13 802.11bg, 19 802.11a channels
[   32.309119] wmaster0: Selected rate control algorithm 'iwl-4965-rs'
dhclient wlan0
There is already a pid file /var/run/dhclient.pid with pid 7630
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.6
Copyright 2004-2007 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:21:5c:56:e0:43
Sending on   LPF/wlan0/00:21:5c:56:e0:43
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
lsmod | grep iw
iwl4965               105844  0
iwlwifi_mac80211      218980  1 iwl4965
cfg80211               15112  1 iwlwifi_mac80211
uname -a
Linux dator 2.6.24-21-generic #1 SMP Mon Aug 25 17:32:09 UTC 2008 i686 GNU/Linux
Vad behövs det mer vetas?
Finns det någon lösning?
Cadryc
Re: Problem med WLAN (iwl4965)
Inlägg av Cadryc »
Vet inte om det här hjälper dig, men hittade en annan som haft problem med den modulen, http://backports.ubuntuforums.com/showp ... ostcount=8 så kan
Genom att lägga till namnet (iw4965 antar jag) i /etc/modules så löstes det
Dock så är jag ingen expert på just såna här grejer, är du osäker så fråga, det finns massa annat folk som vet mer :)
trasan
Inlägg av trasan »
Hej
Gjorde ingen skillnad med att lägga modules i /etc/modules.
Cadryc
Inlägg av Cadryc »
trasan skrev:Gjorde ingen skillnad med att lägga modules i /etc/modules.
Om det var "modules" du lade till så blir det inget bättre nej. Lägg till iwl4965
Skriv lsmod i en terminal och se om den är med där redan.
trasan
Inlägg av trasan »
Hej
Felformulerat av mig.
Gjorde ingen skillnad med att lägga till iwl4965 i /etc/modules
Återgå till "Internet"
