D-link DWL-G510
Ade
D-link DWL-G510
Inlägg av Ade »
Hejsan! Jag önskar hjälp med mitt nätverkskort DWL-G510. Gärna på svenska, är ingen superhjälte på engelska!
Okänd
D-link DWL-G510
Inlägg av Okänd »
Den borde fungera enligt https://help.ubuntu.com/community/WifiD ... sSupported om du råkar inte ha revision C2. Vad ger lspci för utskrift (klistar in i terminal), kan du posta den här?
Ade
D-link DWL-G510
Inlägg av Ade »
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev f2)
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev f3)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2)
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:07.0 Network controller: RaLink Unknown device 0302
01:0c.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 46)
01:0d.0 Multimedia audio controller: Creative Labs SB Audigy LS
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8053 PCI-E Gigabit Ethernet Controller (rev 15)
03:00.0 Mass storage controller: Silicon Image, Inc. SiI 3132 Serial ATA Raid II Controller (rev 01)
05:00.0 VGA compatible controller: nVidia Corporation NV43 [GeForce 6600 GT] (rev a2)
Okänd
D-link DWL-G510
Inlägg av Okänd »
Rad nr 6 från slutet: "01:07.0 Network controller: RaLink Unknown device 0302" avslöjar att drivrutiner till kortet är inte installerade. Tyvärr talar raden inte om vilken revision kortet är.
Ifall den är revision C2
revision B1 4.10 -- revision C2 should work if you download and compile the RT61 drivers for Linux from [WWW] http://www.ralinktech.com/supp-1.htm but they are hard to compile.
vilket betyder ifall du har rev. 2 (går att läsa på kortet?) så måste du kompilera själv drivrutinerna som finns att hitta i länken http://www.ralinktech.com/supp-1.htm
Jag själv har inte trådlöst och därmed ingen egen erfarenhet och kan inte hjälpa dig vidare :| men jag hoppas att någon som har erfarenhet och/eller kunskap får syn på tråden. :)
Ade
D-link DWL-G510
Inlägg av Ade »
Tack för hjälpen petri0! Naturligtvis har jag ver c2. Jag har tittat på den länken men fattar inte så mycket. Hoppas det kommer drivisar snart.
HenrikAn
D-link DWL-G510
Inlägg av HenrikAn »
Kanske den här sidan kan hjälpa?
- John Gilmore
Stefan Liden
D-link DWL-G510
Inlägg av Stefan Liden »
Har själv G-650 och använde drivrutinen (98/ME) från min CD skiva och följde instruktionerna från:
http://lxer.com/module/newswire/view/46385/
Förhoppningsvis fungerar det för ditt kort också...
/Stefan
http://www.jofan.net
