Försöker få igång tvtime med tvkortet Asus MyCinema-P7131 med dåligt resultat. Har googlat runt och förstått att många har problem med det. Någon här som vet hur man gör? dmesg visar
- [ 33.720911] wifi0: Use hw queue 8 for CAB traffic
[ 33.720912] wifi0: Use hw queue 9 for beacons
[ 33.731720] wifi0: Atheros 5212: mem=0xd2000000, irq=20
[ 33.732489] ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16
[ 33.732497] ACPI: PCI Interrupt 0000:05:06.0[A] -> Link [APC1] -> GSI 16 (level, low) -> IRQ 21
[ 33.732505] saa7133[0]: found at 0000:05:06.0, rev: 208, irq: 21, latency: 32, mmio: 0xd2010000
[ 33.732510] saa7133[0]: subsystem: 1043:4845, board: ASUS TV-FM 7135 [card=53,autodetected]
[ 33.732517] saa7133[0]: board init: gpio is 0
[ 33.732824] ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
[ 33.732826] ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCJ] -> GSI 22 (level, low) -> IRQ 17
[ 33.732840] PCI: Setting latency timer of device 0000:00:04.0 to 64
[ 33.865963] saa7133[0]: i2c eeprom 00: 43 10 45 48 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[ 33.865972] saa7133[0]: i2c eeprom 10: 00 ff e2 0f ff 20 ff ff ff ff ff ff ff ff ff ff
[ 33.865978] saa7133[0]: i2c eeprom 20: 01 40 01 02 03 01 01 03 08 ff 00 88 ff ff ff ff
[ 33.865985] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 33.865991] saa7133[0]: i2c eeprom 40: ff 22 00 c2 96 ff 02 30 15 ff ff ff ff ff ff ff
[ 33.865997] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 33.866003] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 33.866009] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 33.981775] tuner 2-004b: chip found @ 0x96 (saa7133[0])
[ 34.029668] tda8290 2-004b: setting tuner address to 61
[ 34.053626] intel8x0_measure_ac97_clock: measured 54690 usecs
[ 34.053630] intel8x0: clocking to 46877
[ 34.133486] tuner 2-004b: type set to tda8290+75a
[ 34.181394] tda8290 2-004b: setting tuner address to 61
[ 34.285221] tuner 2-004b: type set to tda8290+75a
[ 34.287491] saa7133[0]: registered device video0 [v4l2]
[ 34.287509] saa7133[0]: registered device vbi0
[ 34.287523] saa7133[0]: registered device radio0
[ 34.319674] saa7134 ALSA driver for DMA sound loaded
[ 34.319702] saa7133[0]/alsa: saa7133[0] at 0xd2010000 irq 21 registered as card -2
[ 35.543620] lp: driver loaded but no devices found
[ 35.734437] Adding 6080560k swap on /dev/sda5. Priority:-1 extents:1 across:6080560k
[ 36.299712] EXT3 FS on sda1, internal journal
Fråga: card=53, tuner=61, stämmer det?
Card=53 verkar ju vara Asus.
Language=?, jag har kabeltv, dvs inte vanliga tv-kanaler?
Jag googlar vidare.
