USB problem
thalle
USB problem
Inlägg av thalle »
Nu vill jag lösa problemet. Tror det har funnits sedan uppgradering till 8.04.
Inget USB minne vill hittas, varken olika usb-stickor eller mobiltelefon. Detta har funkat.
Var ska jag börja leta?
fstab :
  • # /etc/fstab: static file system information.
    # <file system> <mount point> <type> <options> <dump> <pass>
    proc /proc proc defaults 0 0
    # /dev/sda3
    UUID=4a5f5dee-bc73-48d7-971d-064ed2112bb7 / ext3 defaults,errors=remount-ro 0 1
    # /dev/mmcblk0p1
    UUID=6432-6138 /media/mmcblk0p1 vfat defaults,utf8,umask=007,gid=46 0 1
    # /dev/sda1
    UUID=E2E4F7AEE4F782D9 /media/sda1 ntfs defaults,umask=007,gid=46 0 1
    # /dev/sda2
    UUID=3AA05666A05628A1 /media/sda2 ntfs defaults,umask=007,gid=46 0 1
    # /dev/sda4
    UUID=a21aad30-9f5b-41b0-8ac2-208d026775c3 /home ext3 defaults,errors=remount-ro 0 1
    # Swap
    UUID=da0551bf-b814-44d6-918e-2474eeaac327 none swap sw 0 0
    #UUID=6b3ea748-fd4f-4073-81a1-232c06712002 none swap sw 0 0
    #cd-rom
    /dev/scd0 /media/cdrom0 udf,iso9660 user,noauto,exec 0 0
mtab :
  • /dev/sda3 / ext3 rw,errors=remount-ro 0 0
    proc /proc proc rw,noexec,nosuid,nodev 0 0
    /sys /sys sysfs rw,noexec,nosuid,nodev 0 0
    varrun /var/run tmpfs rw,noexec,nosuid,nodev,mode=0755 0 0
    varlock /var/lock tmpfs rw,noexec,nosuid,nodev,mode=1777 0 0
    udev /dev tmpfs rw,mode=0755 0 0
    devshm /dev/shm tmpfs rw 0 0
    devpts /dev/pts devpts rw,gid=5,mode=620 0 0
    lrm /lib/modules/2.6.24-19-generic/volatile tmpfs rw 0 0
    /dev/sda1 /media/sda1 fuseblk rw,nosuid,nodev,noatime,allow_other,default_permissions,blksize=4096 0 0
    /dev/sda2 /media/sda2 fuseblk rw,nosuid,nodev,noatime,allow_other,default_permissions,blksize=4096 0 0
    /dev/sda4 /home ext3 rw,errors=remount-ro 0 0
    securityfs /sys/kernel/security securityfs rw 0 0
    binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,noexec,nosuid,nodev 0 0
/dev/mmcblk0p1 är en inbyggd kortläsare och den fungerar.
/T
Rune.K
Re: USB problem
Inlägg av Rune.K »
Kolla "tail /var/log/messages" när du nyss satt i ett USB-minne.
thalle
Re: USB problem
Inlägg av thalle »
  • Sep 8 17:21:07 tt kernel: [28452.752390] usb 5-8: new high speed USB device using ehci_hcd and address 6
    Sep 8 17:21:07 tt kernel: [28452.889296] usb 5-8: configuration #4 chosen from 1 choice
Och när jag drar ut enheten :
  • Sep 8 17:22:31 tt kernel: [28536.848432] usb 5-8: USB disconnect, address 6
...så systemet verkar ju fatta att något kopplas in men...
Kom över ett annat minne och testade, det funkar som det ska: Verkar bara vara de minnen jag använt på maskinen innan som inte dyker upp...
  • Sep 8 17:26:01 tt kernel: [28746.462472] usb 5-8: new high speed USB device using ehci_hcd and address 8
    Sep 8 17:26:01 tt kernel: [28746.594161] usb 5-8: configuration #1 chosen from 1 choice
    Sep 8 17:26:01 tt kernel: [28746.594973] scsi3 : SCSI emulation for USB Mass Storage devices
    Sep 8 17:26:06 tt kernel: [28751.593143] scsi 3:0:0:0: Direct-Access I0MEGA UMni512MB*IOM2J4 1.00 PQ: 0 ANSI: 2
    Sep 8 17:26:06 tt kernel: [28751.604092] sd 3:0:0:0: [sdb] 1015808 512-byte hardware sectors (520 MB)
    Sep 8 17:26:06 tt kernel: [28751.605089] sd 3:0:0:0: [sdb] Write Protect is off
    Sep 8 17:26:06 tt kernel: [28751.608088] sd 3:0:0:0: [sdb] 1015808 512-byte hardware sectors (520 MB)
    Sep 8 17:26:06 tt kernel: [28751.608711] sd 3:0:0:0: [sdb] Write Protect is off
    Sep 8 17:26:06 tt kernel: [28751.608726] sdb: sdb1
    Sep 8 17:26:06 tt kernel: [28751.609816] sd 3:0:0:0: [sdb] Attached SCSI removable disk
    Sep 8 17:26:06 tt kernel: [28751.609882] sd 3:0:0:0: Attached scsi generic sg2 type 0
    Sep 8 17:28:25 tt kernel: [28890.262701] usb 5-8: USB disconnect, address 8
    Sep 8 17:28:25 tt kernel: [28890.272081] scsi 3:0:0:0: [sdb] READ CAPACITY failed
    Sep 8 17:28:25 tt kernel: [28890.272084] scsi 3:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK,SUGGEST_OK
    Sep 8 17:28:25 tt kernel: [28890.272090] scsi 3:0:0:0: [sdb] Sense not available.
    Sep 8 17:28:25 tt kernel: [28890.272102] scsi 3:0:0:0: [sdb] Write Protect is off
Rune.K
Re: USB problem
Inlägg av Rune.K »
Du skriver
Har du provat att skriva till det minnet och sen koppla ur det, för att se att det fungerar även nästa gång.
Hoppas att du använder motsvarigheten till windowstermen "säker borttagning av maskinvara" !?
thalle
Re: USB problem
Inlägg av thalle »
Jo, det funkar att skriva till/från och funkar fortfarande...
Jag avmonterar enheten oftast/alltid. Men visst, ibland har man väl missat...
micke_nordin
Re: USB problem
Inlägg av micke_nordin »
Vilket filsystem är det på pinnen? Om minnet är nytt sätter jag en slant på att det är NTFS och att det är därför Ubuntu inte monterar pinnen. Jag vet inte hur man kollar vilket filsystem det är i Ubuntu dock... Om du har tillgång till en Windozeburk kan du ju alltid sätta i pinnen där och kolla. Om det är NTFS kan du använda samma Windozeburk till att formatera om pinnen till FAT32 eller FAT16. Säkert kan någon fiffig person här på forumet hjälpa dig med att fixa detta i Ubuntu också.
/Micke
micke_nordin
Re: USB problem
Vad är det för mobiltelefon? Funkade den modellen tidigare i Ubuntu?
/Micke
thalle
Re: USB problem
Inlägg av thalle »
En Sonyericsson.
Och ja, den fungerade innan. Funkar varken via telefonen eller med minnet i en usb-adapter.
Har inte formaterat om minnet sedan det slutade funka, så där tror jag inte problemet är.
Och självklart är minnet okej, både i luren och när jag bootar om till windows....
