Jag är helt lost nu... En disk i min array är 'removed'
Om jag kör en "sudo mdadm -D /dev/md0"
så ser det ut så här:
/dev/md0:
Version : 00.90.03
Creation Time : Sun Sep 30 19:20:50 2007
Raid Level : raid5
Device Size : 488383936 (465.76 GiB 500.11 GB)
Raid Devices : 3
Total Devices : 2
Preferred Minor : 0
Persistence : Superblock is persistent
Update Time : Sat Aug 23 12:32:51 2008
State : active, degraded, Not Started
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 2d7edc98:375f616d:8e536f94:c5c9eb57 (local to host Gaderoben)
Events : 0.30517
Number Major Minor RaidDevice State
0 8 33 0 active sync /dev/sdc1
1 8 1 1 active sync /dev/sda1
2 0 0 2 removed
En "sudo mdadm --examine /dev/sdb1" ger:
/dev/sdb1:
Magic : a92b4efc
Version : 00.90.00
Raid Level : raid5
Array Size : 976767872 (931.52 GiB 1000.21 GB)
Raid Devices : 3
Total Devices : 3
Preferred Minor : 0
Update Time : Wed Aug 20 07:41:15 2008
State : clean
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0
Checksum : eef9898 - correct
Events : 0.60
Chunk Size : 64K
this 2 8 17 2 active sync /dev/sdb1
0 0 8 49 0 active sync /dev/.static/dev/sdd1
1 1 8 1 1 active sync /dev/sda1
2 2 8 17 2 active sync /dev/sdb1
och en "sudo mdadm --examine /dev/sdc1" ger:
/dev/sdc1:
Magic : a92b4efc
Version : 00.90.00
Raid Level : raid5
Raid Devices : 3
Total Devices : 2
Preferred Minor : 0
State : active
Active Devices : 2
Working Devices : 2
Failed Devices : 1
Spare Devices : 0
Checksum : ef447e0 - correct
Events : 0.30517
Chunk Size : 64K
this 0 8 1 0 active sync /dev/sda1
0 0 8 1 0 active sync /dev/sda1
1 1 8 17 1 active sync /dev/sdb1
2 2 0 0 2 faulty removed
Och "sudo fdisk -l" ger:
Disk /dev/hda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/hda1 1 122 979933+ 82 Linux swap / Solaris
/dev/hda2 123 9729 77168227+ 83 Linux
Disk /dev/sda: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders
/dev/sda1 1 60801 488384001 fd Linux raid autodetect
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
/dev/sdb1 1 60801 488384001 fd Linux raid autodetect
Disk /dev/sdc: 500.1 GB, 500107862016 bytes
/dev/sdc1 1 60801 488384001 fd Linux raid autodetect
Personalities : [raid6] [raid5] [raid4]
md0 : inactive sdc1[0] sda1[1]
976767872 blocks
unused devices: <none>
Vad händer egentligen? Någon som vet?
Tack på förhand
BB
