Hej. Har följande nätverkskort : Connect2Air E-5400 USB
Jag har problem att få ingång mitt trådlösa nätverk och jag tror att mitt nätverkskort inte hittas. Har kört lspci och följande kommer upp:
lspci
00:00.0 Memory controller: nVidia Corporation CK804 Memory Controller (rev a3)
00:01.0 ISA bridge: nVidia Corporation CK804 ISA Bridge (rev a3)
00:01.1 SMBus: nVidia Corporation CK804 SMBus (rev a2)
00:02.0 USB Controller: nVidia Corporation CK804 USB Controller (rev a2)
00:02.1 USB Controller: nVidia Corporation CK804 USB Controller (rev a3)
00:06.0 IDE interface: nVidia Corporation CK804 IDE (rev a2)
00:07.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3)
00:08.0 IDE interface: nVidia Corporation CK804 Serial ATA Controller (rev a3)
00:09.0 PCI bridge: nVidia Corporation CK804 PCI Bridge (rev a2)
00:0a.0 Bridge: nVidia Corporation CK804 Ethernet Controller (rev a3)
00:0b.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0c.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0d.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:0e.0 PCI bridge: nVidia Corporation CK804 PCIE Bridge (rev a3)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: ATI Technologies Inc RV410 [Radeon X700]
01:00.1 Display controller: ATI Technologies Inc Unknown device 5e6f
05:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 80)
05:04.0 Multimedia audio controller: Creative Labs SB Audigy (rev 04)
05:04.1 Input device controller: Creative Labs SB Audigy Game Port (rev 04)
05:04.2 FireWire (IEEE 1394): Creative Labs SB Audigy FireWire Port (rev 04)
05:05.0 Communication controller: Conexant HSF 56k Data/Fax Modem
Har skrivit lshw -C network och fick följande:
WARNING: you should run this program as super-user.
*-network
description: Wireless interface
physical id: 1
logical name: wlan0
serial: 00:30:05:74:d3:0c
capabilities: ethernet physical wireless
configuration: broadcast=yes multicast=yes wireless=IEEE 802.11g
Vet inte riktigt vad det säger mig, men jag tror inte kortet är riktigt installerat. Är det nån som kan hjälpa mig att rätta till det och hur laddar man in nya drivisar om det behövs?
Drivrutiner till Nätverkskort [LÖST]
Hårdvara som Hårdvara
- Cadryc
Re: Drivrutiner till Nätverkskort
Det är väl USBanslutet? Då ger iaf inte lspci nånting, pröva lsusb
I en del fall med krånglande wlanskort så kan man köra med drivrutiner för windows genom ndiswrapper, installera genom Lägg till/ta bort Sen ligger det under System -> Administration -> Windows-drivrutiner för trådlösa nätverkskort, öppna det och välj den nerladdade .inf -filen (Drivrutinen för windows som man laddar ner från lämpligt ställe är antagligen ett arkiv typ .zip eller .rar och när man packar upp så kan det finnas flera filer, tex en .exe-fil som vore intressant om man satt i windows, nu är det .inf-filen man vill ha)
Tack!
Jag kom en bit på vägen, nu får jag kontakt med mitt kort. Men jag lyckas inte få nåt ip-nummer.
Jag har bockat i Allow roaming och då kan jag komma åt mitt nätverk, har ca 70% styrka tex. Kollar i infon, men den bara säger
0.0.0.0 på ip och dem andra i infon. Har testat att bocka av roaming och fylla i ett eget ip som skall funka med min router men
får heller ingen kontakt.
Några tips på vad jag bör kolla??
Här har du U-Fs klistrade trubbel guide för att kolla via terminalen
http://ubuntuforums.org/showthread.php?t=684495
Du ser även i guiden hur det ser ut när det lyckas.
Sen måste du ha koll på om din router delar ut en dynamisk eller fast adress mot LAN klienterna
De allra flesta routrar surfar man bara in i via 192.168.
olika för olika märken, se manualen.
Nu har det äntligen löst sig.
Tack för hjälpen, när jag fått in drivrutinerna för XP och efter mycket om och men (Kortet verkar bara klara WEP, minns detta nu sen jag körde XP på burken) så funkar det.
