apt-get update ger en massa 404 fel
niska
Inlägg av niska »
Jag kör Ubuntu 6.10. Min sources fil ser ut så här
deb http://se.archive.ubuntu.com/ubuntu/ edgy main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ edgy main restricted
deb http://se.archive.ubuntu.com/ubuntu/ edgy-updates main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ edgy-updates main restricted
deb http://security.ubuntu.com/ubuntu edgy-security main restricted
deb-src http://security.ubuntu.com/ubuntu edgy-security main restricted
deb http://security.ubuntu.com/ubuntu edgy-security universe
deb-src http://security.ubuntu.com/ubuntu edgy-security universe
När jag kör apt-get update får jag en massa 404 fel
Ign http://se.archive.ubuntu.com edgy Release.gpg
Ign http://se.archive.ubuntu.com edgy/main Translation-en_US
Ign http://se.archive.ubuntu.com edgy/restricted Translation-en_US
Ign http://se.archive.ubuntu.com edgy/universe Translation-en_US
Ign http://security.ubuntu.com edgy-security Release.gpg
Ign http://security.ubuntu.com edgy-security/main Translation-en_US
Ign http://security.ubuntu.com edgy-security/restricted Translation-en_US
Ign http://security.ubuntu.com edgy-security/universe Translation-en_US
Ign http://se.archive.ubuntu.com edgy-updates Release.gpg
Ign http://security.ubuntu.com edgy-security/main Packages
Ign http://security.ubuntu.com edgy-security/restricted Packages
Ign http://security.ubuntu.com edgy-security/main Sources
Ign http://security.ubuntu.com edgy-security/restricted Sources
Ign http://se.archive.ubuntu.com edgy-updates/main Translation-en_US
Ign http://security.ubuntu.com edgy-security/universe Packages
Ign http://security.ubuntu.com edgy-security/universe Sources
Err http://security.ubuntu.com edgy-security/main Packages
404 Not Found
Err http://security.ubuntu.com edgy-security/restricted Packages
404 Not Found
Err http://security.ubuntu.com edgy-security/main Sources
404 Not Found
Err http://security.ubuntu.com edgy-security/restricted Sources
404 Not Found
Err http://security.ubuntu.com edgy-security/universe Packages
404 Not Found
Err http://security.ubuntu.com edgy-security/universe Sources
404 Not Found
Ign http://se.archive.ubuntu.com edgy-updates/restricted Translation-en_US
Ign http://se.archive.ubuntu.com edgy/main Packages
Ign http://se.archive.ubuntu.com edgy/restricted Packages
Ign http://se.archive.ubuntu.com edgy/main Sources
Ign http://se.archive.ubuntu.com edgy/restricted Sources
Ign http://se.archive.ubuntu.com edgy/universe Packages
Ign http://se.archive.ubuntu.com edgy/universe Sources
Ign http://se.archive.ubuntu.com edgy-updates/main Packages
Ign http://se.archive.ubuntu.com edgy-updates/restricted Packages
Ign http://se.archive.ubuntu.com edgy-updates/main Sources
Ign http://se.archive.ubuntu.com edgy-updates/restricted Sources
Err http://se.archive.ubuntu.com edgy/main Packages
404 Not Found [IP: 130.239.18.173 80]
Err http://se.archive.ubuntu.com edgy/restricted Packages
Err http://se.archive.ubuntu.com edgy/main Sources
Err http://se.archive.ubuntu.com edgy/restricted Sources
Err http://se.archive.ubuntu.com edgy/universe Packages
Err http://se.archive.ubuntu.com edgy/universe Sources
Err http://se.archive.ubuntu.com edgy-updates/main Packages
Err http://se.archive.ubuntu.com edgy-updates/restricted Packages
Err http://se.archive.ubuntu.com edgy-updates/main Sources
Err http://se.archive.ubuntu.com edgy-updates/restricted Sources
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/main/binary-amd64/Packages.gz 404 Not Found
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/restricted/binary-amd64/Packages.gz 404 Not Found
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/main/source/Sources.gz 404 Not Found
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/restricted/source/Sources.gz 404 Not Found
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/universe/binary-amd64/Packages.gz 404 Not Found
Failed to fetch http://security.ubuntu.com/ubuntu/dists/edgy-security/universe/source/Sources.gz 404 Not Found
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/main/binary-amd64/Packages.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/restricted/binary-amd64/Packages.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/main/source/Sources.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/restricted/source/Sources.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/universe/binary-amd64/Packages.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy/universe/source/Sources.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy-updates/main/binary-amd64/Packages.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy-updates/restricted/binary-amd64/Packages.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy-updates/main/source/Sources.gz 404 Not Found [IP: 130.239.18.173 80]
Failed to fetch http://se.archive.ubuntu.com/ubuntu/dists/edgy-updates/restricted/source/Sources.gz 404 Not Found [IP: 130.239.18.173 80]
Reading package lists... Done
E: Some index files failed to download, they have been ignored, or old ones used instead.
Någon som vet vad som kan vara fel?
Re: apt-get update ger en massa 404 fel
Min första tanke är att det kan vara något med nätet som krånglar, antingen hos dig eller någon annanstans på vägen...
pun
Inlägg av pun »
Edgy nådde "End of Life" i våras så det är hög tid att uppgradera.
http://www.ubuntu.com/news/ubuntu610end-of-life
Du måste först till Feisty osv
https://help.ubuntu.com/community/FeistyUpgrades
Har du /home på en separat partition ?
niska
Inlägg av niska »
pun skrev:Edgy nådde "End of Life" i våras så det är hög tid att uppgradera.
The latest version of Update Manager (0.45.2) must be installed before you upgrade. Otherwise, you will receive an Authentication failed error.
# dpkg -l update-manager
No packages found matching update-manager.
Hur gör jag för att installera den senaste update manager? Jag kör alltså via prompten.
pun skrev:Har du /home på en separat partition ?
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda1             366G  291G   57G  84% /
varrun                502M  136K  501M   1% /var/run
varlock               502M     0  502M   0% /var/lock
procbususb             10M   60K   10M   1% /proc/bus/usb
udev                   10M   60K   10M   1% /dev
devshm                502M     0  502M   0% /dev/shm
niska
Inlägg av niska »
Jag har kört
#sudo apt-get install update-manager-core
enligt instruktionerna.
Men det står även
The latest version of Update Manager (0.45.2) must be installed before you upgrade. Otherwise, you will receive an Authentication failed error. See here for instructions how to check if you have the required version.
Får dock fortfarande inte något resultat när jag kör:
#dpkg -l update-manager
Hur gör jag för att installera update-manager 0.45.2?
pun
Inlägg av pun »
Jo det var en knepig utmaning.....
Nu kommer inte jag ihåg hur det såg ut i Edgy men kolla.
Meny System > Administration > Programvarukällor eller om man översatt det Mjukvarukällor...
I mitten har du en rullgardin, ändra till "Main" som repo.
Plus en uppdatering. Ska kolla lite mer på det här....
Till 8.04 ska det bara gå att nå från 6.06 eller 7.10
http://www.ubuntu.com/getubuntu/upgrading
EDIT
Den här ska gälla precis vad du håller på med
https://help.ubuntu.com/community/Insta ... OldVersion
pun
Inlägg av pun »
Followup.... det finns ingen 0.45 version i arkivet
http://archive.ubuntu.com/ubuntu/pool/m ... e-manager/
0.59 är nästa.
Har du backup på dina personliga alster ???
(har inte kollat U-F eller googlat pga tidsbrist)
EDIT jo nu har jag kollat och det blir den manuella vägen
https://help.ubuntu.com/community/FeistyUpgradesManual
Backuper ?
niska
Inlägg av niska »
pun skrev:Followup.... det finns ingen 0.45 version i arkivet
0.59 är nästa.
Ok. Så då står det fel i instruktionerna alltså?
Jag körde
do-release-upgrade
och det fungerade bra. Det räckte alltså med update-manager-core. update-manager var inte nödvändig.
pun
Inlägg av pun »
Jo funkar det så är det ju bara bra... ;)
Vart landade du ?
En server ska det funka bra på (en bra bit ner)
Ska ju då bara gå från 6.06 till 8.04 alt 7.10 > 8.04
Om du landade med 7.04 så borde GUIet funka nu.
