Inget ljud i Lenovo n200. Testat inställn. m.m.
Hejsan,
Jag har inget ljud i min Lenovo 3000 n200. Jag har kollat "sound preferance", " men inget bättre där . Behövs det u nån drivrutin kanske?
TACK!!!!
TACK!!!!
Re: behöver verkligen hjälp
När det gäller ljudet, tryck ALT+F2 och klistra in följande rad.
Kopiera in resultatet i denna tråd.
lspci > /tmp/lspci && gedit /tmp/lspci
tack, men sedan då? jag är ju helgrön med ubuntu
lspci > /tmp/lspci && gedit /tmp/lspci:
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
00:01.0 PCI bridge: Intel Corporation Mobile PM965/GM965/GL960 PCI Express Root Port (rev 0c)
00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03)
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 4 (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: nVidia Corporation G72M [Quadro NVS 110M/GeForce Go 7300] (rev a1)
04:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
06:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5906M Fast Ethernet PCI Express (rev 02)
08:06.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller
08:06.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 19)
08:06.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 0a)
08:06.3 System peripheral: Ricoh Co Ltd xD-Picture Card Controller (rev 05)
Det är nog inte någon tröst, men det verkar som om du inte är ensam med problemet. Det finns lösningar, men vissa är för speciella datorer.
Exakt vad för dator har du?
Vilken Ubuntuversion har du? Är den uppdaterad? Den senaste versionen heter Ubuntu 8.04.1
Om du vill läsa själv kan du googla:
Ge det lite tid så skall du se att någon med lika ljudkort som du ser den här tråden.ubuntu 82801H
tack. jag har en Lenovo 3000 N200, bärbar sak. Min första nyköpta PC, som jag inte byggt, så det kom med vista på den, vilket var tråkigt tyckte jag.
Så jag testade ubuntu 8.04 (har kvar windows).
okej,ber om så hemskt mkt om ursäkt (ab)solut inte ironisk) för mitt dubbelpostande.
Jag har sagt problem med ljudet i så väl mediaspelare som beepljud i PC miljön,. Jag för stå inte vad det kan vara, har testat så mkt. Är det någon som har koll på detta så vore mkt tacksam
mvh Philip
mvh Philip
- BadOmen
- OS: Kubuntu
Re: Inget ljud i Lenovo n200. Testat inställn. m.m.
Det här fixade ljudet för en annan som hade en Lenovo 3000 N200 och körde Ubuntu 8.04.
Du kanske har fått det att funka redan men jag har inte sett att du skrivit det någonstans men du har tydligen dubbel postat så jag kan ha missat det.
OBS för säkerhetsskull så gör en bakup av den här filen innan du ändrar i den /etc/modprobe.d/alsa-base
lägg detta längst ned i filen:
ock kör sen:
du kanske behöver starta om datorn sen för att vara säkert på att det ger effekt.
Om du får ett pipande ljud undertiden du startar datorn så skriv in alsamixer i terminalen och minska Front Mic till 33 % så ska det sluta pipa. Du kan höja andra staplar i alsamixer sen om du får svagt ljud.
EDIT: Du kan även ta en koll på denna sida http://www.linlap.com/wiki/Lenovo+3000+N200
gksudo gedit /etc/modprobe.d/alsa-base
options snd-hda-intel model=lenovo enable=1 index=0
sudo /etc/init.d/alsa-tools restart
