Drivrutin till geforce 9600gt
Hej, har precis köpt ny dator med intel quadcore duo processor geforce 9600gt grafikkort. Kör ubuntu 8.04.
Jag har lyckats installera drivrutinerna till grafikkortet från nvidias hemsida, men skärmen blir bara svart vid omstart. Kör felsäkert läge och reparerar x. Då får jag rätt upplösning igen. När jag går till systemverktyg - nvidia x-server settings får jag felmeddelandet att "You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-xconfig` as root), and restart the X server. "
När jag skriver in "sudo nvidia-xconfig" står det så här:
Using X configuration file: "/etc/X11/xorg.conf".
VALIDATION ERROR: Data incomplete in file /etc/X11/xorg.conf.
Device section "Configured Video Device" must have a Driver
line.
Backed up file '/etc/X11/xorg.conf' as '/etc/X11/xorg.conf.backup'
New X configuration file written to '/etc/X11/xorg.conf'
Någon som förstår sig på det här? Jätteglad för eventuell hjälp...
Min xorg.conf ser ut så här:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Thu Jun 5 00:10:21 PDT 2008
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 110.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
line.
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Re: Drivrutin till geforce 9600gt
En manuellt installerad nVidia drivare slängs ut av kärnan vid nästa
omstart om man inte "pillrat" rätt samt att det är beroende på om man har restricted moduler installerade.
Beskrivs så här av nVidia http://www.nvnews.net/vbulletin/showthread.php?t=72490
(en bit ner)
Nu finns 173 drivaren i hardys repo men bara som proposed.
Det det här paketet som envy ska installera som ligger i Hardy-updates/proposed. FÖR INFO bara.
http://packages.ubuntu.com/hardy-update ... x-new-envy
Du lägger då bara till proposed/föreslagna till Meny System > Administration > Mjukvarukällor samt kör en uppdatering (innan du stänger )
Du ska installera 2 paket
Sen kör du Envy.
Efter omstart så bockar du ur Föreslagna igen.
Albertos blog om det här
http://albertomilone.com/wordpress/?p=210
Klarar då ditt 9600 kort.
Du slipper det manuella pillrandet om det här går bra.
(en bit ner)
sudo apt-get update
sudo apt-get install envyng-gtk envyng-core
Sen kör du Envy.
Viktig ändring, envyng-core har en högre version i updates
Flyttat installationen av Envy i instruktionen
Så här ser Envy paketen ut
http://packages.ubuntu.com/search?searc ... words=envy
Ok, jag formaterade om datorn forst for att vara pa sakra sidan...
Foljde din instruktion och valde manuell driverinstallation i envy. Startade om datorn, men hamnar da i laggrafiklage som skarmen inte klarar av... Det stod att varken skarmen eller grafikkortet kunde identifieras. Hur gar jag vidare nu? antar att jag maste stalla in skarmupplosningen utanfor X...
Protesterade Envy när du körde ?
Hursomhelst en Linuxburk behöver inget GUI
Ctrl-Alt-F1 > en terminal ska öppnas
Logga in
Gå ner till sektion Device > ändra till vesa
Section "Device"
Driver "vesa"
EndSection
Ctrl-X > Y för att spara
För att starta X igen
Hör av dig direkt för jag vill veta drivarversion som åkte på....
Logga in
sudo /etc/init.d/gdm stop
sudo nano /etc/X11/xorg.conf
Section "Device"
Driver "vesa"
EndSection
startx
Hann lägga mig igår... Fortsätter ikväll när jag är hemma
OK, vet inte om jag har tid ikväll....Daniel skrev:Hann lägga mig igår... Fortsätter ikväll när jag är hemma
Hursomhelst så har man då alltid en terminal via Ctrl-Alt-F1
När du sedan är inne igen
Starta Envy > Kolla vilka versioner som man kan välja på > nVidia fliken.
Du kan behöva välja manuellt eftersom autodetekteringen kan klicka för 9XXX kort.
173.14 ska du då se i listan
Du kan även köra envy från terminal (Ctrl-Alt-F1 tricket)
sudo envyng -t
Där kan du även avinstallera drivaren.
Alternativ strul väg beskrivs här som då är nVidia metoden. Byt ut 177 > 173, du ser siffrorna i nedladdningen
Den saknar en viktig ingrediens att har man restricted moduler installerade vilket många har så
måste man blocka dom annars stöts drivaren bort precis som det blev för dig.
http://ubuntu-se.org/phpBB3/viewtopic.php?f=55&t=27112
sudo gedit /etc/default/linux-restricted-modules-common
DISABLED_MODULES="nv nvidia_new"
Avinstallera drivrutiner från Ubuntu (och förhindra dem från att störa):Kod: Markera allt
sudo apt-get install linux-headers-`uname -r` build-essential gcc gcc-3.4 xserver-xorg-dev
sudo apt-get --purge remove nvidia-glx nvidia-settings nvidia-kernel-common sudo rm /etc/init.d/nvidia-* sudo rm /lib/linux-restricted-modules/.nvidia_new_installed
Det här måste man göra i en tty > logga ut > Ctrl-Alt-F1
Stäng av X (Kubuntuanvändare: ersätt gdm med kdm)
Installera drivrutinen (64-bitarsanvändare, ersätt x86-177.13-pkg1 med x86_64-177.13-pkg2):Kod: Markera allt
Starta X (Kubuntuanvändare, ersätt gdm med kdm)sudo sh NVIDIA-Linux-x86-177.13-pkg1.run
sudo nvidia-xconfig --add-argb-glx-visualsKod: Markera allt
sudo /etc/init.d/gdm start
I Intrepid är det här helt omgjort och 9XXX korten har stöd
Lycka Till !!!!
