http://it.slashdot.org/article.pl?sid=0 ... 9&from=rss
Efter en stunds påläsning så kan jag konstatera att det funkar mycket bra, och är riktigt enkelt att använda.
För mer info, se:
http://adeona.cs.washington.edu/
Så här ser det ut när jag spårar min MacBook (OS X), med servern (Ubuntu):
root@Sandnabba.se: /home/emil #> adeona_track -s adeona-macbooken.ost -n 1
Please enter password for Adeona:
* These results are for informational, research and evaluation purposes only. *
* Do not attempt to recover your lost or stolen laptop yourself. *
* If you believe your laptop has been stolen, contact the appropriate *
* law enforcement agency. *
Searching for most recent 1 update(s) in time period [ 07/12/2008,23:47 (CEST) - NOW ]
Connecting to remote storage server...
Trying server 1...please be patient
Succesfully connected to remote storage server
Checking update scheduled on 07/14/2008,23:41 (CEST)
Update replica 0 not available
Update replica 1 not available
Checking update scheduled on 07/14/2008,23:10 (CEST)
Succesfully retrieved update replica 0
Retrieved location information:
update time: 07/14/2008,23:46 (CEST)
internal ip: 10.0.0.8
external ip: 91.95.226.62
access point: (n/a)
Nearby routers:
1 0.616ms 10.0.0.1 (could not resolve)
2 84.601ms 87.227.2.1 (1.2.227.87.static.ter-blg.siw.siwnet.net)
3 26.503ms 195.54.136.153 (could not resolve)
4 58.671ms 83.88.20.30 (ge-5-0-0.alb2nxu7.ip.tele.dk)
5 38.985ms 195.215.109.2 (kbn-b1.telia.net)
6 73.116ms 80.91.250.125 (kbn-bb2-link.telia.net)
7 57.751ms 80.91.254.2 (hbg-bb2-link.telia.net)
8 104.692ms 80.91.250.133 (bpt-b2-link.telia.net)
9 73.902ms 80.239.134.2 (dante-ic-125711-bpt-b2.c.telia.net)
10 90.704ms 62.40.112.13 (so-6-1-0.rt1.vie.at.geant2.net)
11 116.467ms 62.40.124.6 (arnes-gw.rt1.vie.at.geant2.net)
12 109.372ms 212.235.160.244 (larnes7-V101.arnes.si)
13 99.842ms 194.249.21.198 (lunilj1-V819.arnes.si)
14 106.141ms 193.2.96.2 (could not resolve)
15 91.458ms 193.2.96.105 (cis-alu.metulj.uni-lj.si)
=> iSight snapshot saved in adeona_test/adeona-snapshot-07-14-2008-2346-CEST-91.95.226.62.jpg
# Are there any things you might change in the Adeona system, perhaps for future versions?
Yes. Please see our research paper for more information. One example avenue for improvement might be to create a cleaner interface between Adeona and the DHT (which is used as a bulletin board to store the location updates). Currently, because PlanetLab nodes (which house OpenDHT) are not always guaranteed to be stable, the Adeona client will download a fresh set of OpenDHT nodes from http://adeona.cs.washington.edu/gateways.adeona at every update interval.
# What else could Adeona be made to do in the future?
The Adeona system is designed with extensibility in mind. We envision that it would be straightforward to add functionality to send authenticated commands back to the laptop (e.g., so as to delete sensitive data). Here the remote storage service, OpenDHT, would act as a private, anonymous bulletin board for relaying communication between the device and its owner. The Adeona client could also be engineered to be significantly more resistant to thieves attempting to disable it, via kernel-level support or even hardware support.
