Video
• Grafikprocessor/tillverkare Intel GMA 900
• Intel® 915GM Express chipset
• Videominne Dynamic Video Memory Technology 3.0
• Max upplösning (extern) 1600 x 1200 / 32-bitarsfärg
Taget från webhallen: http://www.webhallen.com/prod.php?id=57311
Satt o försökte med denna guiden (http://ubuntuforums.org/showthread.php?t=54544) men jag får det inte att fungera så här ser det ut ni får gärna dumförklara mig för jag vill verkligen att det ska funka nu!
andreas@nemo:~/Skrivbord/i810-20060403-linux.i386$ sudo ./install.sh
DIRECT RENDERING OPEN SOURCE PROJECT - DRIVER INSTALLATION SCRIPT
[ http://dri.freedesktop.org ]
Welcome to the DRI Driver Installation Script
The package you downloaded is for the following driver:
Driver Name : i810
Description : Intel i810/i815 Driver
Architecture :
Build Date : 20060403
Kernel Module : i810
Optional Information
Driver Version :
Special Description :
Press ENTER to continue or CTRL-C to exit.
The script will need to copy the DRI Xorg driver modules to
your Xorg directories.
The script will use the following Xorg directories:
Xorg Dir : /usr/X11R6
Xorg Modules Dir : /usr/X11R6/lib/modules
Xorg Library Dir : /usr/X11R6/lib
If this is correct press ENTER, press C to change or CTRL-C to exit.
The script also needs to copy the DRM kernel modules to your
kernel module directory.
This version of the script supports 2.4.x and 2.6.x kernels.
Kernel Version : 2.6.24-19-generic
Module Directory : /lib/modules/2.6.24-19-generic
The script will now compile the DRM kernel modules for your machine.
Compiling...
ERROR: Kernel modules did not compile
The DRI drivers can not be installed without the latest kernel modules.
Installation will be aborted. See the dri.log file for information on
what went wrong.
