Problem med sources.list,kan inte uppdatera
kenta
Inlägg av kenta »
Hej Kenta här jag har problem att hitta uppdateringar, har kollat i sources.list men den ser OK ut.
Jag använder en D-Link 604 router och har öppnat en del portar, jag tror att jag har gjort rätt.
Jag är nybörjare.
Min sources.list ser ut så här:
# deb cdrom:[Ubuntu-Server 8.04 _Hardy Heron_ - Release i386 (20080423.2)]/ hardy main restricted
#deb cdrom:[Ubuntu-Server 8.04 _Hardy Heron_ - Release i386 (20080423.2)]/ hardy main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://se.archive.ubuntu.com/ubuntu/ hardy main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://se.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://se.archive.ubuntu.com/ubuntu/ hardy universe
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy universe
deb http://se.archive.ubuntu.com/ubuntu/ hardy-updates universe
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://se.archive.ubuntu.com/ubuntu/ hardy multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy multiverse
deb http://se.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
deb-src http://se.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://se.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
# deb-src http://se.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
# deb http://archive.canonical.com/ubuntu hardy partner
# deb-src http://archive.canonical.com/ubuntu hardy partner
deb http://security.ubuntu.com/ubuntu hardy-security main restricted
deb-src http://security.ubuntu.com/ubuntu hardy-security main restricted
deb http://security.ubuntu.com/ubuntu hardy-security universe
deb-src http://security.ubuntu.com/ubuntu hardy-security universe
deb http://security.ubuntu.com/ubuntu hardy-security multiverse
deb-src http://security.ubuntu.com/ubuntu hardy-security multiverse
Jag får 404 not found.
Mvh Kenta
PS: Jag tack ajja och maths57 för den hjälp jag fått av dem i tråden http://ubuntu-se.org/phpBB3/viewtopic.php?f=17&t=28222
Sid
Re: Problem med sources.list,kan inte uppdatera
Inlägg av Sid »
kan du pinga se.archive.ubuntu.com?
ping -c 3 se.archive.ubuntu.com
