Får inte till rätt upplösning i twinmode på HTPC skärmen
masterlinkX
Utgåva: 10.04 Lucid LTS
Inlägg av masterlinkX »
Hejsan!!!!
Har ett bekymmer som jag dragit med rätt så länge nu. Har googlat och testat den ena guiden efter den andra. Jag får inte till samma upplösning på mina båda skärmar.
Min LCD tv körs i rätt upplösning 1360x768. Sen har jag en 7 tums skärm till mitt cooltek3000 chassi. Den kan man köra i 1360x768, det fungerar i Vista iallafall.
Men i Nvidias controlpanel under linux så finns inte 1360x768 som alternativ, hittar ingenting som heter custom resolution heller!!!!
Min xorg.conf fil ser ut så här
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 1.0 (buildmeister@builder63) Mon May 19 00:34:28 PDT 2008
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 1.0 (buildmeister@builder63) Mon May 19 00:33:37 PDT 2008
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
InputDevice "Generic Keyboard" "CoreKeyboard"
InputDevice "Configured Mouse"
EndSection
Section "ServerFlags"
Option "Xinerama" "0"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "se"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-1"
HorizSync 28.0 - 67.0
VertRefresh 50.0 - 75.0
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "LG 42LC55"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "nvidia"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 9600 GT"
EndSection
Section "Device"
Identifier "Videocard1"
Driver "nvidia"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Configured Video Device"
Monitor "Configured Monitor"
SubSection "Display"
Modes "nvidia-auto-select"
EndSubSection
EndSection
Section "Screen"
# Removed Option "TwinView" "0"
# Removed Option "metamodes" "1360x768 +0+0"
# Removed Option "TwinView" "1"
# Removed Option "metamodes" "CRT: nvidia-auto-select +0+0, DFP: 1360x768 +0+0"
# Removed Option "metamodes" "CRT: nvidia-auto-select +0+0"
# Removed Option "metamodes" "CRT: 1360x768_60 +0+0 +168+0, DFP: 1360x768_60 +0+0"
# Removed Option "metamodes" "CRT: nvidia-auto-select, DFP: 1360x768_60 +0+0"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinViewXineramaInfoOrder" "DFP-2"
Option "metamodes" "CRT: nvidia-auto-select +168+0, DFP: 1360x768_60 +0+0"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Videocard0"
Monitor "Monitor1"
DefaultDepth 24
Option "metamodes" "DFP: 1360x768_60 +0+0"
Depth 24
EndSubSection
EndSection
Hoppas någon har ett svar eller kan hjälpa mig!!!!!
MVH HENKE
masterlinkX
Re: Får inte till rätt upplösning i twinmode på HTPC skärmen
Ingen som vet hur jag "tvingar" fram rätt upplösning till min lilla 7 tums skärm till mitt htpc-chassi.
Som sagt......det går att köra i 1360x768 på touch skärmen i Vista......men tyvärr inte så långt jag försökt under ubuntu.
Chassit heter cooltek 3000 och touch-skärms tillverkaren heter Maple Touch. Någon som kan hjälpa mig??????
MVH Henke
