Ta bort gamla kärnor?
Inlägg av 8301 »
Kan jag ta bort alla gamla kernellerna som finns på datorn den ända jag vet jag använder är linux-image-2.6.25-1-386 ( jag vet att det är en beta version men allt fungerar med den vilket inte med 2.6.24)
sebastian@ubuntu:~$ sudo aptitude search linux-image
[sudo] password for sebastian:
p   linux-image                     - Generic Linux kernel image.
v   linux-image-2.6                 -
i   linux-image-2.6.22-14-generic   - Linux kernel image for version 2.6.22 on x
i   linux-image-2.6.24-16-386       - Linux kernel image for version 2.6.24 on i
i   linux-image-2.6.24-16-generic   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-16-openvz    - Linux kernel image for version 2.6.24 on O
p   linux-image-2.6.24-16-rt        - Linux kernel image for version 2.6.24 on I
p   linux-image-2.6.24-16-server    - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-16-virtual   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-16-xen       - Linux kernel image for version 2.6.24 on T
i   linux-image-2.6.24-17-386       - Linux kernel image for version 2.6.24 on i
i   linux-image-2.6.24-17-generic   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-17-openvz    - Linux kernel image for version 2.6.24 on O
p   linux-image-2.6.24-17-rt        - Linux kernel image for version 2.6.24 on I
p   linux-image-2.6.24-17-server    - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-17-virtual   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-17-xen       - Linux kernel image for version 2.6.24 on T
p   linux-image-2.6.24-18-386       - Linux kernel image for version 2.6.24 on i
p   linux-image-2.6.24-18-generic   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-18-openvz    - Linux kernel image for version 2.6.24 on O
p   linux-image-2.6.24-18-rt        - Linux kernel image for version 2.6.24 on I
p   linux-image-2.6.24-18-server    - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-18-virtual   - Linux kernel image for version 2.6.24 on x
p   linux-image-2.6.24-18-xen       - Linux kernel image for version 2.6.24 on T
i   linux-image-2.6.25-1-386        - Linux kernel image for version 2.6.25 on i
i   linux-image-386                 - Linux kernel image on 386.
p   linux-image-686                 - Upgrade dummy package. Can be removed
p   linux-image-debug-2.6.24-16-386 - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-16-gen - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-16-ser - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-16-vir - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-17-386 - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-17-gen - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-17-ser - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-17-vir - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-18-386 - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-18-gen - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-18-ser - Linux kernel debug image for version 2.6.2
p   linux-image-debug-2.6.24-18-vir - Linux kernel debug image for version 2.6.2
p   linux-image-debug-386           - Linux kernel debug image for 386 kernel im
p   linux-image-debug-generic       - Linux kernel debug image for generic kerne
p   linux-image-debug-server        - Linux kernel debug image for server kernel
i   linux-image-generic             - Generic Linux kernel image
p   linux-image-k7                  - Upgrade dummy package. Can be removed
p   linux-image-openvz              - Real time Linux kernel image
p   linux-image-rt                  - Real time Linux kernel image
p   linux-image-server              - Linux kernel image on Server Equipment.
p   linux-image-virtual             - Description: Linux kernel image geared tow
p   linux-image-xen                 - Real time Linux kernel image
Re: Ta bort gamla kärnor?
Jag tror bara att det är de som det står ett "i" framför som är installerade och det bör inte vara någon fara att ta bort alla utom den du använder. Däremot är det en god idé att också spara den förra du använde så att du har den som reserv om något mindre kul skulle hända.
Hur aptitude funkar i det här sammanhanget vet jag faktiskt inte, men generellt kan du ju prova med att rensa bort alla kärnor förutom de du ska spara från /boot och lägga dem i typ /boot/old. Då har du ju möjlighet att kopiera tillbaka dem om något mot all förmodan skulle klaga. Naturligtvis är också bra att editera /boot/grub/menu.lst efteråt, så att den stämmer med verkligheten.
