Kopiera nedan och spara som körbarfil med lämpligt namn i ~/.gnome2/nautilus-scripts/
Det är en av filerna från paketet nautilus-scripts
#!/usr/bin/env python
# Open command prompt in a single selected directory
# or otherwise in current dir
# Put this (executable) file in ~/.gnome2/nautilus-scripts/
# Then right click a directory or anywhere in current dir window
# to get the scripts->command_prompt_here menu option
# This has been tested on nautilus 2.2 and 2.4
def nautilus_script_display_error():
"""This is a general error message display for nautilus scripts"""
import sys
#errors_fd,errors_name=tempfile.mkstemp() #This not available until python 2.3
errors_name=os.tmpnam()
errors_fd=file(errors_name,"w")
etype, emsg, etb = sys.exc_info()
errors_fd.write('line '+str(etb.tb_lineno)+': '+str(etype)+': '+str(emsg)+'\n')
errors_fd.write('\n$PWD: %s' % os.getcwd())
errors_fd.write('\nsys.argv: %s' % str(sys.argv[1:]))
for var in os.environ:
if var.startswith("NAUTILUS_"):
errors_fd.write("\n%s: %s" % (var,os.environ[var].replace('\n',"\\n")))
errors_fd.close()
pid = os.fork()
if pid == 0:
cmd = ["zenity", "--text-info", "--filename=%s" % errors_name, "--title=error", "--width=640", "--height=220"]
os.execvp(cmd[0],cmd)
os.waitpid(pid,0)
os.unlink(errors_name)
import os
import urllib, urlparse
try:
home_dir=os.environ["HOME"]
# An alternative to below could be:
# 1. get where we are (CURRENT_URI (file://, trash:, x-nautilus-desktop:///))
# 2. use argv to see if 1 selected dir under that?
dir_to_open=""
selected=os.environ["NAUTILUS_SCRIPT_SELECTED_URIS"].split("\n")[:-1]
#Note getting SELECTED_URIS rather than SELECTED_FILE_PATHS as later
#is not set when ~/Desktop and ~/.Trash selected??
if len(selected) == 1:
uri_bits=urlparse.urlparse(urllib.unquote(selected[0]))
if uri_bits[0] == "file":
dir_to_open=uri_bits[2]
elif uri_bits[0] == "x-nautilus-desktop":
if uri_bits[2] == "///trash":
dir_to_open=home_dir+'/.Trash'
elif uri_bits[2] == "///home":
dir_to_open=home_dir+'/Desktop'
if not os.path.isdir(dir_to_open):
dir_to_open=""
if not dir_to_open: #we didn't select 1 directory so open current dir
current_uri=os.environ["NAUTILUS_SCRIPT_CURRENT_URI"]
uri_bits=urlparse.urlparse(urllib.unquote(current_uri))
elif uri_bits[0] == "trash":
shell_cmd=["gnome-terminal", "--working-directory=%s"%dir_to_open]
os.execvp(shell_cmd[0],shell_cmd)
except:
