Hej HenrikAn. dmesg ger detta svar:
stirner@stirner-laptop:~$ dmesg
[ 0.000000] Linux version 2.6.20-15-generic (root@palmer) (gcc version 4.1.2 (Ubuntu 4.1.2-0ubuntu4)) #2 SMP Sun Apr 15 07:36:31 UTC 2007 (Ubuntu 2.6.20-15.27-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] sanitize start
[ 0.000000] sanitize end
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 894MB LOWMEM available.
[ 0.000000] found SMP MP-table at 000f7090
[ 0.000000] Entering add_active_range(0, 0, 229008) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229008
[ 0.000000] HighMem 229008 -> 229008
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 229008
[ 0.000000] On node 0 totalpages: 229008
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1757 pages used for memmap
[ 0.000000] Normal zone: 223155 pages, LIFO batch:31
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP (v000 Acer ) @ 0x000f7000
[ 0.000000] ACPI: RSDT (v001 Acer RSDT 0x06040000 LTP 0x00000000) @ 0x37e95a7a
[ 0.000000] ACPI: FADT (v001 Acer GrapeII 0x06040000 ATI 0x000f4240) @ 0x37e9bf0a
[ 0.000000] ACPI: MADT (v001 PTLTD APIC 0x06040000 LTP 0x00000000) @ 0x37e9bf7e
[ 0.000000] ACPI: MCFG (v001 PTLTD MCFG 0x06040000 LTP 0x00000000) @ 0x37e9bfc4
[ 0.000000] ACPI: SSDT (v001 PmRef Cpu0Cst 0x00003001 INTL 0x20050228) @ 0x37e95fe7
[ 0.000000] ACPI: SSDT (v001 PmRef CpuPm 0x00003000 INTL 0x20050228) @ 0x37e95ab2
[ 0.000000] ACPI: DSDT (v001 Acer BONEFISH 0x06040000 MSFT 0x0100000e) @ 0x00000000
[ 0.000000] ATI board detected. Disabling timer routing over 8254.
[ 0.000000] ACPI: PM-Timer IO Port: 0x8008
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] Processor #0 6:14 APIC version 20
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 38000000:a8000000)
[ 0.000000] Detected 1466.814 MHz processor.
[ 12.863099] Built 1 zonelists. Total pages: 227219
[ 12.863105] Kernel command line: root=UUID=35f5725d-75b2-46fd-b8d7-5e2e328e8e34 ro quiet splash
[ 12.863300] mapped APIC to ffffd000 (fee00000)
[ 12.863303] mapped IOAPIC to ffffc000 (fec00000)
[ 12.863307] Enabling fast FPU save and restore... done.
[ 12.863310] Enabling unmasked SIMD FPU exception support... done.
[ 12.863325] Initializing CPU#0
[ 12.863422] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 12.864503] Console: colour VGA+ 80x25
[ 12.865468] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 12.866221] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 12.894076] Memory: 896696k/916032k available (1992k kernel code, 18656k reserved, 893k data, 328k init, 0k highmem)
[ 12.894088] virtual kernel memory layout:
[ 12.894089] fixmap : 0xfff4e000 - 0xfffff000 ( 708 kB)
[ 12.894091] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 12.894092] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 12.894094] lowmem : 0xc0000000 - 0xf7e90000 ( 894 MB)
[ 12.894096] .init : 0xc03d7000 - 0xc0429000 ( 328 kB)
[ 12.894097] .data : 0xc02f2264 - 0xc03d16d4 ( 893 kB)
[ 12.894099] .text : 0xc0100000 - 0xc02f2264 (1992 kB)
[ 12.894103] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 12.971413] Calibrating delay using timer specific routine.. 2937.09 BogoMIPS (lpj=5874186)
[ 12.971460] Security Framework v1.0.0 initialized
[ 12.971470] SELinux: Disabled at boot.
[ 12.971488] Mount-cache hash table entries: 512
[ 12.971639] CPU: After generic identify, caps: afe9fbff 00100000 00000000 00000000 0000c109 00000000 00000000
[ 12.971649] monitor/mwait feature present.
[ 12.971651] using mwait in idle threads.
[ 12.971656] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 12.971659] CPU: L2 cache: 1024K
[ 12.971663] CPU: After all inits, caps: afe9fbff 00100000 00000000 00002940 0000c109 00000000 00000000
[ 12.971675] Compat vDSO mapped to ffffe000.
[ 12.971679] Remapping vsyscall page to ffffe000
[ 12.971694] Checking 'hlt' instruction... OK.
[ 12.987525] SMP alternatives: switching to UP code
[ 12.987725] Freeing SMP alternatives: 11k freed
[ 12.987933] Early unpacking initramfs... done
[ 13.380007] ACPI: Core revision 20060707
[ 13.397668] ACPI: Looking for DSDT in initramfs... file /DSDT.aml not found, using machine DSDT.
[ 13.815048] CPU0: Intel(R) Celeron(R) M CPU 410 @ 1.46GHz stepping 08
[ 13.815078] Total of 1 processors activated (2937.09 BogoMIPS).
[ 13.815257] ENABLING IO-APIC IRQs
[ 13.815475] ..TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 13.959294] Brought up 1 CPUs
[ 13.959554] Booting paravirtualized kernel on bare hardware
[ 13.959651] Time: 14:38:58 Date: 04/19/108
[ 13.959680] NET: Registered protocol family 16
[ 13.959771] EISA bus registered
[ 13.959776] ACPI: bus type pci registered
[ 13.961909] PCI: PCI BIOS revision 2.10 entry at 0xfd2f4, last bus=14
[ 13.961911] PCI: Using configuration type 1
[ 13.961913] Setting up standard PCI resources
[ 13.970546] ACPI: Interpreter enabled
[ 13.970550] ACPI: Using IOAPIC for interrupt routing
[ 13.971200] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 13.971208] PCI: Probing PCI hardware (bus 00)
[ 13.972699] Boot video device is 0000:01:05.0
[ 13.973086] PCI: Transparent bridge - 0000:00:14.4
[ 13.973201] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 13.977427] ACPI: PCI Interrupt Link [LNKA] (IRQs 10 11) *0, disabled.
[ 13.977741] ACPI: PCI Interrupt Link [LNKB] (IRQs 10 11) *0, disabled.
[ 13.978050] ACPI: PCI Interrupt Link [LNKC] (IRQs 10 11) *0, disabled.
[ 13.978360] ACPI: PCI Interrupt Link [LNKD] (IRQs 10 11) *0, disabled.
[ 13.978667] ACPI: PCI Interrupt Link [LNKE] (IRQs 10 11) *0, disabled.
[ 13.978971] ACPI: PCI Interrupt Link [LNKF] (IRQs 10 11) *0, disabled.
[ 13.979307] ACPI: PCI Interrupt Link [LNKG] (IRQs 10 11) *0, disabled.
[ 13.979614] ACPI: PCI Interrupt Link [LNKH] (IRQs 10 11) *0, disabled.
[ 13.979915] ACPI: PCI Interrupt Link [LNKU] (IRQs 3 4 5 7) *0, disabled.
[ 14.019352] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT]
[ 14.019749] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT]
[ 14.020328] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 14.020337] pnp: PnP ACPI init
[ 14.043321] pnp: PnP ACPI: found 10 devices
[ 14.043326] PnPBIOS: Disabled by ACPI PNP
[ 14.043377] PCI: Using ACPI for IRQ routing
[ 14.043380] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[ 14.073840] NET: Registered protocol family 8
[ 14.073842] NET: Registered protocol family 20
[ 14.074077] pnp: 00:08: ioport range 0x1080-0x1080 has been reserved
[ 14.074080] pnp: 00:08: ioport range 0x220-0x22f has been reserved
[ 14.074084] pnp: 00:08: ioport range 0x40b-0x40b has been reserved
[ 14.074087] pnp: 00:08: ioport range 0x4d0-0x4d1 has been reserved
[ 14.074382] PCI: Bridge: 0000:00:01.0
[ 14.074385] IO window: 9000-9fff
[ 14.074390] MEM window: c0000000-c00fffff
[ 14.074394] PREFETCH window: d0000000-dfffffff
[ 14.074406] PCI: Bus 10, cardbus bridge: 0000:09:04.0
[ 14.074409] IO window: 0000a400-0000a4ff
[ 14.074416] IO window: 0000a800-0000a8ff
[ 14.074423] PREFETCH window: 40000000-43ffffff
[ 14.074430] MEM window: 44000000-47ffffff
[ 14.074437] PCI: Bridge: 0000:00:14.4
[ 14.074441] IO window: a000-afff
[ 14.074449] MEM window: c0100000-c01fffff
[ 14.074455] PREFETCH window: 40000000-43ffffff
[ 14.074503] ACPI: PCI Interrupt 0000:09:04.0[A] -> GSI 20 (level, low) -> IRQ 16
[ 14.074536] NET: Registered protocol family 2
[ 14.107310] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 14.107513] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 14.108941] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 14.109943] TCP: Hash tables configured (established 131072 bind 65536)
[ 14.109948] TCP reno registered
[ 14.119416] checking if image is initramfs... it is
[ 14.900256] Freeing initrd memory: 6996k freed
[ 14.900882] audit: initializing netlink socket (disabled)
[ 14.900899] audit(1211207938.708:1): initialized
[ 14.901041] VFS: Disk quotas dquot_6.5.1
[ 14.901063] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 14.901121] io scheduler noop registered
[ 14.901124] io scheduler anticipatory registered
[ 14.901127] io scheduler deadline registered
[ 14.901136] io scheduler cfq registered (default)
[ 14.901416] isapnp: Scanning for PnP cards...
[ 15.258639] isapnp: No Plug & Play device found
[ 15.285693] Real Time Clock Driver v1.12ac
[ 15.285763] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 15.286556] mice: PS/2 mouse device common for all mice
[ 15.288067] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 15.288236] input: Macintosh mouse button emulation as /class/input/input0
[ 15.288273] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 15.288278] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 15.288575] PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSS0] at 0x60,0x64 irq 1,12
[ 15.288824] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 15.288907] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 15.288911] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 15.288914] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 15.288917] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 15.288920] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 15.289042] EISA: Probing bus 0 at eisa.0
[ 15.289055] Cannot allocate resource for EISA slot 1
[ 15.289086] Cannot allocate resource for EISA slot 8
[ 15.289088] EISA: Detected 0 cards.
[ 15.319204] TCP cubic registered
[ 15.319213] NET: Registered protocol family 1
[ 15.319234] Using IPI No-Shortcut mode
[ 15.319306] ACPI: (supports S0 S3 S4 S5)
[ 15.319362] Magic number: 8:486:637
[ 15.319890] Freeing unused kernel memory: 328k freed
[ 15.321483] input: AT Translated Set 2 keyboard as /class/input/input1
[ 15.323021] Time: tsc clocksource has been installed.
[ 16.558263] Capability LSM initialized
[ 16.597740] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 16.597754] ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
[ 17.028679] usbcore: registered new interface driver usbfs
[ 17.028706] usbcore: registered new interface driver hub
[ 17.028729] usbcore: registered new device driver usb
[ 17.029563] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 17.029615] ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 19 (level, low) -> IRQ 17
[ 17.029631] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 17.029823] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 1
[ 17.029848] ohci_hcd 0000:00:13.0: irq 17, io mem 0xc0404000
[ 17.064577] SCSI subsystem initialized
[ 17.070822] libata version 2.20 loaded.
[ 17.091058] usb usb1: configuration #1 chosen from 1 choice
[ 17.091093] hub 1-0:1.0: USB hub found
[ 17.091110] hub 1-0:1.0: 4 ports detected
[ 17.169848] 8139too Fast Ethernet driver 0.9.28
[ 17.194925] ACPI: PCI Interrupt 0000:00:13.1[A] -> GSI 19 (level, low) -> IRQ 17
[ 17.194952] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 17.194978] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 2
[ 17.194997] ohci_hcd 0000:00:13.1: irq 17, io mem 0xc0405000
[ 17.250908] usb usb2: configuration #1 chosen from 1 choice
[ 17.250943] hub 2-0:1.0: USB hub found
[ 17.250959] hub 2-0:1.0: 4 ports detected
[ 3.972000] Time: acpi_pm clocksource has been installed.
[ 3.980000] ACPI: PCI Interrupt 0000:00:13.2[A] -> GSI 19 (level, low) -> IRQ 17
[ 3.980000] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 3.980000] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 3.980000] ehci_hcd 0000:00:13.2: irq 17, io mem 0xc0406000
[ 3.980000] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 3.980000] usb usb3: configuration #1 chosen from 1 choice
[ 3.980000] hub 3-0:1.0: USB hub found
[ 3.980000] hub 3-0:1.0: 8 ports detected
[ 4.084000] ATIIXP: IDE controller at PCI slot 0000:00:14.1
[ 4.084000] ACPI: PCI Interrupt 0000:00:14.1[A] -> GSI 16 (level, low) -> IRQ 18
[ 4.084000] ATIIXP: chipset revision 128
[ 4.084000] ATIIXP: not 100% native mode: will probe irqs later
[ 4.084000] ide0: BM-DMA at 0x8410-0x8417, BIOS settings: hda:DMA, hdb:DMA
[ 4.084000] ide1: BM-DMA at 0x8418-0x841f, BIOS settings: hdc:pio, hdd:pio
[ 4.084000] Probing IDE interface ide0...
[ 4.376000] hda: HTS541080G9AT00, ATA DISK drive
[ 5.160000] hdb: MATSHITADVD-RAM UJ-850S, ATAPI CD/DVD-ROM drive
[ 5.216000] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 5.236000] Probing IDE interface ide1...
[ 5.804000] ACPI: PCI Interrupt 0000:09:06.0[A] -> GSI 22 (level, low) -> IRQ 19
[ 5.808000] eth0: RealTek RTL8139 at 0xf8832000, 00:16:d4:10:d1:4a, IRQ 19
[ 5.808000] eth0: Identified 8139 chip type 'RTL-8100B/8139D'
[ 5.808000] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 5.816000] hda: max request size: 512KiB
[ 5.828000] hda: 156301488 sectors (80026 MB) w/7539KiB Cache, CHS=16383/255/63, UDMA(100)
[ 5.828000] hda: cache flushes supported
[ 5.828000] hda: hda1 hda2 hda3
[ 5.896000] hdb: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
[ 5.896000] Uniform CD-ROM driver Revision: 3.20
[ 6.216000] Attempting manual resume
[ 6.216000] swsusp: Resume From Partition 3:3
[ 6.216000] PM: Checking swsusp image.
[ 6.244000] PM: Resume from disk failed.
[ 6.300000] kjournald starting. Commit interval 5 seconds
[ 6.300000] EXT3-fs: mounted filesystem with ordered data mode.
[ 15.276000] eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 16.456000] NET: Registered protocol family 17
[ 16.592000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 16.620000] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 17.484000] ath_hal: module license 'Proprietary' taints kernel.
[ 17.484000] ath_hal: 0.9.18.0 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413)
[ 17.564000] piix4_smbus 0000:00:14.0: Found 0000:00:14.0 device
[ 17.592000] Linux agpgart interface v0.102 (c) Dave Jones
[ 17.812000] input: PC Speaker as /class/input/input2
[ 17.900000] wlan: 0.8.4.2 (0.9.3)
[ 17.920000] Synaptics Touchpad, model: 1, fw: 6.2, id: 0x12a0b1, caps: 0xa04713/0x204000
[ 17.944000] ath_pci: 0.9.4.5 (0.9.3)
[ 17.944000] ACPI: PCI Interrupt 0000:09:02.0[A] -> GSI 21 (level, low) -> IRQ 20
[ 18.592000] input: SynPS/2 Synaptics TouchPad as /class/input/input3
[ 18.928000] ath_rate_sample: 1.2 (0.9.3)
[ 18.928000] wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
[ 18.928000] wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36Mbps 48Mbps 54Mbps
[ 18.928000] wifi0: H/W encryption support: WEP AES AES_CCM TKIP
[ 18.928000] wifi0: mac 7.8 phy 4.5 radio 5.6
[ 18.928000] wifi0: Use hw queue 1 for WME_AC_BE traffic
[ 18.928000] wifi0: Use hw queue 0 for WME_AC_BK traffic
[ 18.928000] wifi0: Use hw queue 2 for WME_AC_VI traffic
[ 18.928000] wifi0: Use hw queue 3 for WME_AC_VO traffic
[ 18.928000] wifi0: Use hw queue 8 for CAB traffic
[ 18.928000] wifi0: Use hw queue 9 for beacons
[ 18.980000] wifi0: Atheros 5212: mem=0xc0100000, irq=20
[ 18.980000] Yenta: CardBus bridge found at 0000:09:04.0 [1025:0109]
[ 18.980000] Yenta: Using CSCINT to route CSC interrupts to PCI
[ 18.980000] Yenta: Routing CardBus interrupts to PCI
[ 18.980000] Yenta TI: socket 0000:09:04.0, mfunc 0x00111212, devctl 0x44
[ 18.980000] ACPI: PCI Interrupt 0000:00:14.2[A] -> GSI 16 (level, low) -> IRQ 18
[ 19.212000] Yenta: ISA IRQ mask 0x0cf8, PCI irq 16
[ 19.212000] Socket status: 30000006
[ 19.212000] pcmcia: parent PCI bridge I/O window: 0xa000 - 0xafff
[ 19.212000] cs: IO port probe 0xa000-0xafff: clean.
[ 19.212000] pcmcia: parent PCI bridge Memory window: 0xc0100000 - 0xc01fffff
[ 19.212000] pcmcia: parent PCI bridge Memory window: 0x40000000 - 0x43ffffff
[ 19.640000] cs: IO port probe 0x100-0x3af: clean.
[ 19.644000] cs: IO port probe 0x3e0-0x4ff: clean.
[ 19.644000] cs: IO port probe 0x820-0x8ff: excluding 0x878-0x87f
[ 19.644000] cs: IO port probe 0xc00-0xcf7: excluding 0xc00-0xc07 0xc10-0xc17 0xc50-0xc57 0xc68-0xc6f 0xcd0-0xcdf
[ 19.644000] cs: IO port probe 0xa00-0xaff: clean.
[ 19.784000] fuse init (API version 7.8)
[ 19.864000] lp: driver loaded but no devices found
[ 19.892000] Adding 1951888k swap on /dev/disk/by-uuid/e2e8a9d2-fe16-4536-8fa6-ffdc943a1bae. Priority:-1 extents:1 across:1951888k
[ 20.036000] EXT3 FS on hda1, internal journal
[ 20.192000] NET: Registered protocol family 10
[ 20.192000] lo: Disabled Privacy Extensions
[ 20.340000] kjournald starting. Commit interval 5 seconds
[ 20.340000] EXT3 FS on hda2, internal journal
[ 20.340000] EXT3-fs: mounted filesystem with ordered data mode.
[ 24.540000] ibm_acpi: ec object not found
[ 24.580000] ACPI: AC Adapter [ACAD] (on-line)
[ 24.668000] input: Power Button (FF) as /class/input/input4
[ 24.672000] ACPI: Power Button (FF) [PWRF]
[ 24.716000] input: Lid Switch as /class/input/input5
[ 24.720000] ACPI: Lid Switch [LID]
[ 24.768000] input: Power Button (CM) as /class/input/input6
[ 24.772000] ACPI: Power Button (CM) [PWRB]
[ 24.816000] input: Sleep Button (CM) as /class/input/input7
[ 24.820000] ACPI: Sleep Button (CM) [SLPB]
[ 24.844000] Using specific hotkey driver
[ 25.016000] ACPI: Battery Slot [BAT1] (battery present)
[ 25.116000] No dock devices found.
[ 25.176000] ACPI: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 25.200000] wmi_add device=f6957c00
[ 25.200000] calling WQBA
[ 25.212000] pcc_acpi: loading...
[ 30.808000] ppdev: user-space parallel port driver
[ 31.504000] apm: BIOS not found.
[ 39.596000] hda-intel: Invalid position buffer, using LPIB read method instead.
[ 44.032000] eth0: no IPv6 routers present
