Zin
Inlägg: 11 Blev medlem: 16 maj 2008, 08:44
OS: Foresight
Inlägg
av Zin » 17 maj 2008, 14:52
Nu har en beta version kommit ut för flash player 10.
Ta hem filen här:
http://labs.adobe.com/downloads/flashplayer10.html
3D Effects - Easily transform and animate any display object through 3D space while retaining full interactivity. Fast, lightweight, and native 3D effects make motion that was previously reserved for expert users available to everyone. Complex effects are simple with APIs that extend what you already know.
Custom Filters and Effects - Create and share your own portable filters, blend modes, and fills using Adobe Pixel Bender™, the same technology used for many After Effects CS3 filters. Shaders in Flash Player are about 1KB and can be scripted and animated at runtime.
Advanced Text Layout - A new, highly flexible text layout engine, co-existing with TextField, enables innovation in creating new text controls by providing low-level access to text offering right-to-left and vertical text layout, plus support for typographic elements like ligatures.
Enhanced Drawing API - Runtime drawing is easier and more powerful with re-styleable properties, 3D APIs, and a new way of drawing sophisticated shapes without having to code them line by line.
Visual Performance Improvements – Applications and videos will run smoother and faster with expanded use of hardware acceleration. By moving several visual processing tasks to the video card, the CPU is free to do more.
TForsman
Inlägg: 1834 Blev medlem: 08 aug 2007, 18:53
OS: Foresight
Inlägg
av TForsman » 29 jul 2008, 15:35
Flash Player 10 beta 2, which was released on July 2, 2008.
Important: All users should uninstall any currently installed Flash Player before installing the latest beta.
TForsman
OS: Foresight
Inlägg
av TForsman » 06 aug 2008, 15:16
Kan tillägga att Opera funkar kanon med Adobe 10, opera 9.52 dev build.
pun
Inlägg: 5317 Blev medlem: 20 okt 2007, 22:11
Inlägg
av pun » 06 aug 2008, 15:36
Yup... men foxen löper amok.... Beta 1 funkar bättre.
swfdec har även kommit med en ny version sedan finns även utvecklingsversionen
http://swfdec.freedesktop.org/wiki/
TForsman
OS: Foresight
Inlägg
av TForsman » 06 aug 2008, 16:41
Tackar, ska testa utvecklingsversionen om ca 30 minuter, se hur den fungerar.
pun
Inlägg
av pun » 12 aug 2008, 08:24
RC version ute
http://labs.adobe.com/technologies/flashplayer10/
* Camera input works a whole lot better (V4L1 and V4L2 cameras both work; V4L2 cameras don't peg the CPU anymore)
* Software fullscreen performance is vastly improved
* Faster, more stable windowless mode (but be sure to use very recent browser builds)
* SSL now handled through NSS instead of flashsupport-OpenSSL alliance
* White speckles are gone from video playback
* Important stability fixes (fewer crashes)
* Still not 64-bit native, just to get that out of the way
TForsman
OS: Foresight
Inlägg
av TForsman » 12 aug 2008, 09:14
den kräver libcurl.so.3 fil?
trött jag blir, den är ju gammal
TForsman
OS: Foresight
Inlägg
av TForsman » 12 aug 2008, 09:20
Gick inte att hoppa över den heller, jag blir sååå trött
pun
Inlägg
av pun » 12 aug 2008, 09:34
TForsman skrev: Gick inte att hoppa över den heller, jag blir sååå trött
Jag låter "automagin" fixa filen...
https://lists.ubuntu.com/archives/intre ... hread.html
Det bli bara fel på symlänkar o dylikt annars.... plus att man inte kan fila buggar med egna ihopkok..
pun
Inlägg
av pun » 14 aug 2008, 22:37
64 bitars verkar trassla... se U-F tråden.
pun
Inlägg
av pun » 15 aug 2008, 22:16
Testat ua, Hardy 32 bit
http://ubuntuforums.org/showpost.php?p= ... tcount=472
Följande paket kommer att uppgraderas:
alsa-utils flashplugin-nonfree libasound2 libpulse-browse0 libpulse0
libpulsecore5 pulseaudio pulseaudio-esound-compat pulseaudio-module-gconf
pulseaudio-module-hal pulseaudio-module-x11 pulseaudio-utils
12 uppgraderade, 0 nyinstallerade, 0 att ta bort och 0 ej uppgraderade.
Behöver hämta 2281kB arkiv.
Efter denna åtgärd kommer 20,5kB diskutrymme att frigöras.
Vill du fortsätta [J/n]?
VARNING: Följande paket kunde inte autentiseras!
libasound2 alsa-utils flashplugin-nonfree libpulse0 libpulse-browse0
pulseaudio-module-hal pulseaudio-utils pulseaudio-module-x11
Installera dessa paket utan verifiering [j/N]? j
Läs:1 http://ppa.launchpad.net hardy/main libasound2 1.0.16-2ubuntu2~ppa1 [357kB]
Läs:2 http://ppa.launchpad.net hardy/main alsa-utils 1.0.16-1ubuntu3~ppa1 [1064kB]
Läs:3 http://ppa.launchpad.net hardy/main flashplugin-nonfree 10.0.1.218+10.0.0.569ubuntu1~ppa2 [19,2kB]
Läs:4 http://ppa.launchpad.net hardy/main libpulse0 0.9.10-2ubuntu4~ppa3 [143kB]
Läs:5 http://ppa.launchpad.net hardy/main libpulse-browse0 0.9.10-2ubuntu4~ppa3 [24,1kB]
Läs:6 http://ppa.launchpad.net hardy/main libpulsecore5 0.9.10-2ubuntu4~ppa3 [186kB]
Läs:7 http://ppa.launchpad.net hardy/main pulseaudio 0.9.10-2ubuntu4~ppa3 [294kB]
Läs:8 http://ppa.launchpad.net hardy/main pulseaudio-esound-compat 0.9.10-2ubuntu4~ppa3 [28,5kB]
Läs:9 http://ppa.launchpad.net hardy/main pulseaudio-module-gconf 0.9.10-2ubuntu4~ppa3 [10,3kB]
Läs:10 http://ppa.launchpad.net hardy/main pulseaudio-module-hal 0.9.10-2ubuntu4~ppa3 [15,5kB]
Läs:11 http://ppa.launchpad.net hardy/main pulseaudio-utils 0.9.10-2ubuntu4~ppa3 [123kB]
Läs:12 http://ppa.launchpad.net hardy/main pulseaudio-module-x11 0.9.10-2ubuntu4~ppa3 [16,8kB]
Hämtade 2281kB på 2s (1065kB/s)
Förkonfigurerar paket ...
(Läser databasen ... 117499 filer och kataloger installerade.)
Förbereder att ersätta libasound2 1.0.15-3ubuntu4 (med .../libasound2_1.0.16-2ubuntu2~ppa1_i386.deb) ...
Packar upp ersättande libasound2 ...
Förbereder att ersätta alsa-utils 1.0.15-3ubuntu2 (med .../alsa-utils_1.0.16-1ubuntu3~ppa1_i386.deb) ...
Packar upp ersättande alsa-utils ...
Förbereder att ersätta flashplugin-nonfree 9.0.124.0ubuntu2 (med .../flashplugin-nonfree_10.0.1.218+10.0.0.569ubuntu1~ppa2_i386.deb) ...
Packar upp ersättande flashplugin-nonfree ...
Förbereder att ersätta libpulse0 0.9.10-1ubuntu1 (med .../libpulse0_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande libpulse0 ...
Förbereder att ersätta libpulse-browse0 0.9.10-1ubuntu1 (med .../libpulse-browse0_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande libpulse-browse0 ...
Förbereder att ersätta libpulsecore5 0.9.10-1ubuntu1 (med .../libpulsecore5_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande libpulsecore5 ...
Förbereder att ersätta pulseaudio 0.9.10-1ubuntu1 (med .../pulseaudio_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio ...
Förbereder att ersätta pulseaudio-esound-compat 0.9.10-1ubuntu1 (med .../pulseaudio-esound-compat_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio-esound-compat ...
Förbereder att ersätta pulseaudio-module-gconf 0.9.10-1ubuntu1 (med .../pulseaudio-module-gconf_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio-module-gconf ...
Förbereder att ersätta pulseaudio-module-hal 0.9.10-1ubuntu1 (med .../pulseaudio-module-hal_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio-module-hal ...
Förbereder att ersätta pulseaudio-utils 0.9.10-1ubuntu1 (med .../pulseaudio-utils_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio-utils ...
Förbereder att ersätta pulseaudio-module-x11 0.9.10-1ubuntu1 (med .../pulseaudio-module-x11_0.9.10-2ubuntu4~ppa3_i386.deb) ...
Packar upp ersättande pulseaudio-module-x11 ...
Ställer in libasound2 (1.0.16-2ubuntu2~ppa1) ...
Ställer in alsa-utils (1.0.16-1ubuntu3~ppa1) ...
Installerar ny version av konfigurationsfilen /etc/init.d/alsa-utils ...
Ställer in flashplugin-nonfree (10.0.1.218+10.0.0.569ubuntu1~ppa2) ...
Downloading...
--21:55:28-- http://download.macromedia.com/pub/labs/flashplayer10/flashplayer10_install_linux_081108.tar.gz
=> `./flashplayer10_install_linux_081108.tar.gz'
Slår upp download.macromedia.com... 88.221.39.191
Ansluter till download.macromedia.com|88.221.39.191|:80... ansluten.
HTTP-begäran skickad, väntar på svar... 200 OK
Längd: 4 035 433 (3.8M) [application/x-gzip]
0K .......... .......... .......... .......... .......... 1% 399.16 KB/s
50K .......... .......... .......... .......... .......... 2% 1.07 MB/s
100K .......... .......... .......... .......... .......... 3% 1.38 MB/s
150K .......... .......... .......... .......... .......... 5% 1.20 MB/s
200K .......... .......... .......... .......... .......... 6% 1.51 MB/s
250K .......... .......... .......... .......... .......... 7% 1.55 MB/s
300K .......... .......... .......... .......... .......... 8% 1.36 MB/s
350K .......... .......... .......... .......... .......... 10% 1.55 MB/s
400K .......... .......... .......... .......... .......... 11% 1.45 MB/s
450K .......... .......... .......... .......... .......... 12% 1.55 MB/s
500K .......... .......... .......... .......... .......... 13% 1.59 MB/s
550K .......... .......... .......... .......... .......... 15% 1.56 MB/s
600K .......... .......... .......... .......... .......... 16% 1.49 MB/s
650K .......... .......... .......... .......... .......... 17% 1.59 MB/s
700K .......... .......... .......... .......... .......... 19% 1.56 MB/s
750K .......... .......... .......... .......... .......... 20% 1.52 MB/s
800K .......... .......... .......... .......... .......... 21% 1.62 MB/s
850K .......... .......... .......... .......... .......... 22% 1.39 MB/s
900K .......... .......... .......... .......... .......... 24% 1.56 MB/s
950K .......... .......... .......... .......... .......... 25% 1.55 MB/s
1000K .......... .......... .......... .......... .......... 26% 1.51 MB/s
1050K .......... .......... .......... .......... .......... 27% 1.57 MB/s
1100K .......... .......... .......... .......... .......... 29% 1.37 MB/s
1150K .......... .......... .......... .......... .......... 30% 1.58 MB/s
1200K .......... .......... .......... .......... .......... 31% 1.59 MB/s
1250K .......... .......... .......... .......... .......... 32% 1.58 MB/s
1300K .......... .......... .......... .......... .......... 34% 1.57 MB/s
1350K .......... .......... .......... .......... .......... 35% 1.52 MB/s
1400K .......... .......... .......... .......... .......... 36% 1.56 MB/s
1450K .......... .......... .......... .......... .......... 38% 1.58 MB/s
1500K .......... .......... .......... .......... .......... 39% 1.59 MB/s
1550K .......... .......... .......... .......... .......... 40% 1.55 MB/s
1600K .......... .......... .......... .......... .......... 41% 1.50 MB/s
1650K .......... .......... .......... .......... .......... 43% 1.57 MB/s
1700K .......... .......... .......... .......... .......... 44% 1.59 MB/s
1750K .......... .......... .......... .......... .......... 45% 1.51 MB/s
1800K .......... .......... .......... .......... .......... 46% 1.47 MB/s
1850K .......... .......... .......... .......... .......... 48% 1.56 MB/s
1900K .......... .......... .......... .......... .......... 49% 1.56 MB/s
1950K .......... .......... .......... .......... .......... 50% 1.32 MB/s
2000K .......... .......... .......... .......... .......... 52% 1.58 MB/s
2050K .......... .......... .......... .......... .......... 53% 1.35 MB/s
2100K .......... .......... .......... .......... .......... 54% 1.55 MB/s
2150K .......... .......... .......... .......... .......... 55% 1.55 MB/s
2200K .......... .......... .......... .......... .......... 57% 1.55 MB/s
2250K .......... .......... .......... .......... .......... 58% 1.55 MB/s
2300K .......... .......... .......... .......... .......... 59% 1.59 MB/s
2350K .......... .......... .......... .......... .......... 60% 1.49 MB/s
2400K .......... .......... .......... .......... .......... 62% 1.54 MB/s
2450K .......... .......... .......... .......... .......... 63% 1.45 MB/s
2500K .......... .......... .......... .......... .......... 64% 1.56 MB/s
2550K .......... .......... .......... .......... .......... 65% 1.53 MB/s
2600K .......... .......... .......... .......... .......... 67% 1.57 MB/s
2650K .......... .......... .......... .......... .......... 68% 1.56 MB/s
2700K .......... .......... .......... .......... .......... 69% 1.59 MB/s
2750K .......... .......... .......... .......... .......... 71% 1.52 MB/s
2800K .......... .......... .......... .......... .......... 72% 1.57 MB/s
2850K .......... .......... .......... .......... .......... 73% 1.54 MB/s
2900K .......... .......... .......... .......... .......... 74% 1.58 MB/s
2950K .......... .......... .......... .......... .......... 76% 1.60 MB/s
3000K .......... .......... .......... .......... .......... 77% 1.48 MB/s
3050K .......... .......... .......... .......... .......... 78% 1.52 MB/s
3100K .......... .......... .......... .......... .......... 79% 1.43 MB/s
3150K .......... .......... .......... .......... .......... 81% 1.59 MB/s
3200K .......... .......... .......... .......... .......... 82% 1.55 MB/s
3250K .......... .......... .......... .......... .......... 83% 1.53 MB/s
3300K .......... .......... .......... .......... .......... 85% 1.55 MB/s
3350K .......... .......... .......... .......... .......... 86% 1.60 MB/s
3400K .......... .......... .......... .......... .......... 87% 1.57 MB/s
3450K .......... .......... .......... .......... .......... 88% 1.42 MB/s
3500K .......... .......... .......... .......... .......... 90% 1.52 MB/s
3550K .......... .......... .......... .......... .......... 91% 1.58 MB/s
3600K .......... .......... .......... .......... .......... 92% 1.34 MB/s
3650K .......... .......... .......... .......... .......... 93% 1.54 MB/s
3700K .......... .......... .......... .......... .......... 95% 1.50 MB/s
3750K .......... .......... .......... .......... .......... 96% 1.50 MB/s
3800K .......... .......... .......... .......... .......... 97% 1.42 MB/s
3850K .......... .......... .......... .......... .......... 98% 1.76 MB/s
3900K .......... .......... .......... .......... 100% 1.40 MB/s
21:55:31 (1.46 MB/s) - "./flashplayer10_install_linux_081108.tar.gz" sparad [4035433/4035433]
Download done.
Flash Plugin installed.
Ställer in libpulse0 (0.9.10-2ubuntu4~ppa3) ...
Ställer in libpulse-browse0 (0.9.10-2ubuntu4~ppa3) ...
Ställer in libpulsecore5 (0.9.10-2ubuntu4~ppa3) ...
Ställer in pulseaudio (0.9.10-2ubuntu4~ppa3) ...
Installerar ny version av konfigurationsfilen /etc/pulse/default.pa ...
Installerar ny version av konfigurationsfilen /etc/pulse/daemon.conf ...
Ställer in pulseaudio-esound-compat (0.9.10-2ubuntu4~ppa3) ...
Ställer in pulseaudio-module-gconf (0.9.10-2ubuntu4~ppa3) ...
Ställer in pulseaudio-module-hal (0.9.10-2ubuntu4~ppa3) ...
Ställer in pulseaudio-utils (0.9.10-2ubuntu4~ppa3) ...
Ställer in pulseaudio-module-x11 (0.9.10-2ubuntu4~ppa3) ...
Processing triggers for libc6 ...
ldconfig deferred processing now taking place
