checking for directory with ALSA include files... /usr/src/linux/include
checking for kernel linux/version.h... no
The file /usr/src/linux/include/linux/version.h does not exist.
Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /usr/src/linux).
make: *** [all] Fel 2
make: *** [install] Fel 2
Installation Unsuccessful
Tittar man i instruktionen så säger den:
You must have the fully configured source for the Linux kernel and
ALSA which you
want to use for this device driver. Partial installed
kernels (e.g. From distribution makers) may be unusable for this
action.
Eller ska man vänta på en uppdaterad drivrutin?
/Gösta
