hallå har precis ändrat lite på min xorg.config för att få 3d accel.det funka skitbra, men när jag nu spelar up avi. eller annan videofil så får jag bara en svart bild och ljud. jag har prövat att spela både köp dvd, avi och mpeg med totem, mplayer och vlc med samma resultat. det verkar som om flashplayer funkar för jag kan se videos på youtube.
jag har oxå precis installerat compis fusion som följer med som standard till gutsy men det kan väl inte ha orsakat detta?
här är min xorg.config om det kan hjälpa.
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "se"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "ATI Technologies Inc R480 [Radeon X850XT Platinum (PCIE)]"
Driver "ati"
Option "AccelMethod" "XAA"
Option "ColorTiling" "on"
option "RenderAccel "true"
Option "EnablePageFlip" "true"
Option "XAANoOffscreenPixmaps"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "DELL 1905FP"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc R480 [Radeon X850XT Platinum (PCIE)]"
Monitor "DELL 1905FP"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Option "AIGLX" "true"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
får ingen bild bara ljud när jag spelar video filer
Re: får ingen bild bara ljud när jag spelar video filer
Jo, compiz kan vara så strulig ibland. Prova att avaktivera detta, gör ctrl-alt-backspace för att starta om x-servern och prova sedan att spela en liten videofil.
