Webcamera
Hårdvara som Hårdvara
Webcamera
Är det någon som vet om det går att få tag på ali m5603c drivrutiner till Ubuntu. Vill gärna få min inbyggda webcamera att fungera men hittar ingen lösning när jag söker på nätet.
Re: Webcamera
Får fram det här med sudo lshw, kan inte urskilja något specifikt om kameran.
bjorn@zepto:~$ sudo lshw
[sudo] password for bjorn:
zepto
description: Computer
product: Znote
vendor: Zepto
version: 6025WD/6625WD
serial: 773CS00230
width: 32 bits
capabilities: smbios-2.4 dmi-2.4 smp-1.4 smp
configuration: administrator_password=disabled boot=oem-specific cpus=1 frontpanel_password=unknown keyboard_password=unknown power-on_password=disabled
*-core
description: Motherboard
product: Znote
vendor: Zepto
physical id: 0
serial: 773CS00230
*-firmware
description: BIOS
vendor: Phoenix Technologies LTD
physical id: 0
version: Z15N011 (09/30/2007)
capacity: 960KiB
capabilities: isa pci pcmcia pnp upgrade shadowing escd cdboot acpi usb agp biosbootspecification
*-cpu
description: CPU
product: Intel(R) Core(TM)2 Duo CPU T7700 @ 2.40GHz
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.11
slot: U2E1
capacity: 2401MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx x86-64 constant_tsc arch_perfmon pebs bts rep_good pni monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr lahf_lm ida cpufreq
*-cache:0
description: L1 cache
physical id: 5
slot: L1 Cache
capacity: 64KiB
capabilities: asynchronous internal write-back
*-cache:1
description: L2 cache
physical id: 6
slot: L2 Cache
capacity: 4MiB
capabilities: burst external write-back
*-memory
description: System Memory
physical id: 16
slot: System board or motherboard
*-bank:0
description: SODIMM Synchronous 667 MHz (1.5 ns)
physical id: 0
slot: M1
width: 32 bits
clock: 667MHz (1.5ns)
*-bank:1
physical id: 1
slot: M2
width: 32 bits
*-pci
description: Host bridge
product: Mobile PM965/GM965/GL960 Memory Controller Hub
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 03
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Mobile PM965/GM965/GL960 PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport-driver
*-display
description: VGA compatible controller
product: GeForce 8600M GT
vendor: nVidia Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: driver=nvidia latency=0 module=nvidia
*-usb:0
description: USB Controller
product: 82801H (ICH8 Family) USB UHCI Contoller #4
physical id: 1a
bus info: pci@0000:00:1a.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0 module=uhci_hcd
*-usb:1
product: 82801H (ICH8 Family) USB UHCI Controller #5
physical id: 1a.1
bus info: pci@0000:00:1a.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:2
product: 82801H (ICH8 Family) USB2 EHCI Controller #2
physical id: 1a.7
bus info: pci@0000:00:1a.7
version: 03
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0 module=ehci_hcd
*-multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0 module=snd_hda_intel
*-pci:1
product: 82801H (ICH8 Family) PCI Express Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
*-network
description: Wireless interface
product: PRO/Wireless 4965 AG or AGN Network Connection
physical id: 0
bus info: pci@0000:02:00.0
logical name: wmaster0
version: 61
serial: 00:1d:e0:12:98:0b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list logical ethernet physical wireless
configuration: broadcast=yes driver=iwl4965 ip=192.168.1.3 latency=0 module=iwl4965 multicast=yes wireless=IEEE 802.11g
*-pci:2
product: 82801H (ICH8 Family) PCI Express Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: 03
width: 32 bits
clock: 33MHz
*-pci:3
product: 82801H (ICH8 Family) PCI Express Port 3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: 03
width: 32 bits
clock: 33MHz
*-pci:4
product: 82801H (ICH8 Family) PCI Express Port 4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: 03
width: 32 bits
clock: 33MHz
*-network
product: NetLink BCM5787M Gigabit Ethernet PCI Express
vendor: Broadcom Corporation
physical id: 0
bus info: pci@0000:05:00.0
logical name: eth0
version: 02
serial: 00:a0:d1:c3:9b:05
capacity: 1GB/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.86 firmware=5787m-v3.23 latency=0 link=no module=tg3 multicast=yes port=twisted pair
*-usb:3
product: 82801H (ICH8 Family) USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 03
width: 32 bits
clock: 33MHz
*-usb:4
product: 82801H (ICH8 Family) USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:5
product: 82801H (ICH8 Family) USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 03
width: 32 bits
clock: 33MHz
*-usb:6
product: 82801H (ICH8 Family) USB2 EHCI Controller #1
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 03
width: 32 bits
clock: 33MHz
*-pci:5
product: 82801 Mobile PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: f3
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-pcmcia
description: CardBus bridge
product: PCIxx12 Cardbus Controller
vendor: Texas Instruments
physical id: 6
bus info: pci@0000:06:06.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pcmcia bus_master cap_list
configuration: driver=yenta_cardbus latency=176 maxlatency=5 mingnt=192 module=yenta_socket
*-firewire
description: FireWire (IEEE 1394)
product: PCIxx12 OHCI Compliant IEEE 1394 Host Controller
physical id: 6.1
bus info: pci@0000:06:06.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm ohci bus_master cap_list
configuration: driver=ohci1394 latency=32 maxlatency=4 mingnt=2 module=ohci1394
*-storage
description: Mass storage controller
product: 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD)
physical id: 6.2
bus info: pci@0000:06:06.2
version: 00
width: 32 bits
clock: 33MHz
capabilities: storage pm bus_master cap_list
configuration: driver=tifm_7xx1 latency=57 maxlatency=4 mingnt=7 module=tifm_7xx1
*-system
description: SD Host controller
product: PCIxx12 SDA Standard Compliant SD Host Controller
physical id: 6.3
bus info: pci@0000:06:06.3
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=sdhci latency=57 maxlatency=4 mingnt=7 module=sdhci
*-isa
description: ISA bridge
product: 82801HEM (ICH8M) LPC Interface Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: latency=0
*-ide:0
description: IDE interface
product: 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller
physical id: 1f.1
bus info: pci@0000:00:1f.1
logical name: scsi0
version: 03
width: 32 bits
clock: 33MHz
capabilities: ide bus_master emulated
configuration: driver=ata_piix latency=0 module=ata_piix
*-cdrom
description: DVD-RAM writer
product: CDDVDW SN-S082H
vendor: TSSTcorp
physical id: 0.1.0
bus info: scsi@0:0.1.0
logical name: /dev/cdrom
logical name: /dev/dvd
logical name: /dev/scd0
logical name: /dev/sr0
version: SB00
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=open
*-ide:1
product: 82801HBM/HEM (ICH8M/ICH8M-E) SATA IDE Controller
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi2
version: 03
width: 32 bits
clock: 66MHz
capabilities: ide pm bus_master cap_list emulated
*-disk
description: ATA Disk
product: SAMSUNG HM320JI
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sda
version: 2SS0
serial: S16LJD0Q113511
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=000702aa
*-volume:0
description: EXT3 volume
vendor: Linux
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sda1
logical name: /
logical name: /dev/.static/dev
version: 1.0
serial: 1bea2393-bef5-46e9-b59d-6feaf972364b
capacity: 286GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files recover ext3 ext2 initialized
configuration: created=2008-03-17 19:43:03 filesystem=ext3 modified=2008-03-24 09:51:02 mount.fstype=ext3 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2008-03-24 09:51:02 state=mounted
*-volume:1
description: Extended partition
physical id: 2
bus info: scsi@2:0.0.0,2
logical name: /dev/sda2
capacity: 11GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume
description: Linux swap / Solaris partition
physical id: 5
logical name: /dev/sda5
capacity: 11GiB
capabilities: nofs
*-serial UNCLAIMED
description: SMBus
product: 82801H (ICH8 Family) SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 03
width: 32 bits
clock: 33MHz
*-battery
description: Nickel Metal Hydride Battery
product: Intel Corporation
physical id: 1
slot: Rear
capacity: 1000mWh
configuration: voltage=0.0V
bjorn@zepto:~$
zepto
product: Znote
vendor: Zepto
serial: 773CS00230
width: 32 bits
*-core
product: Znote
vendor: Zepto
physical id: 0
serial: 773CS00230
*-firmware
description: BIOS
physical id: 0
capacity: 960KiB
*-cpu
description: CPU
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.11
slot: U2E1
capacity: 2401MHz
width: 64 bits
*-cache:0
physical id: 5
slot: L1 Cache
capacity: 64KiB
*-cache:1
physical id: 6
slot: L2 Cache
capacity: 4MiB
*-memory
physical id: 16
*-bank:0
physical id: 0
slot: M1
width: 32 bits
*-bank:1
physical id: 1
slot: M2
width: 32 bits
*-pci
physical id: 100
version: 03
width: 32 bits
clock: 33MHz
*-pci:0
physical id: 1
version: 03
width: 32 bits
clock: 33MHz
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
*-usb:0
physical id: 1a
version: 03
width: 32 bits
clock: 33MHz
*-usb:1
physical id: 1a.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:2
physical id: 1a.7
version: 03
width: 32 bits
clock: 33MHz
*-multimedia
physical id: 1b
version: 03
width: 64 bits
clock: 33MHz
*-pci:1
physical id: 1c
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
version: 61
width: 64 bits
clock: 33MHz
*-pci:2
physical id: 1c.1
version: 03
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 1c.2
version: 03
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 1c.3
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
logical name: eth0
version: 02
capacity: 1GB/s
width: 64 bits
clock: 33MHz
*-usb:3
physical id: 1d
version: 03
width: 32 bits
clock: 33MHz
*-usb:4
physical id: 1d.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:5
physical id: 1d.2
version: 03
width: 32 bits
clock: 33MHz
*-usb:6
physical id: 1d.7
version: 03
width: 32 bits
clock: 33MHz
*-pci:5
physical id: 1e
version: f3
width: 32 bits
clock: 33MHz
*-pcmcia
physical id: 6
version: 00
width: 32 bits
clock: 33MHz
*-firewire
physical id: 6.1
version: 00
width: 32 bits
clock: 33MHz
*-storage
physical id: 6.2
version: 00
width: 32 bits
clock: 33MHz
*-system
physical id: 6.3
version: 00
width: 32 bits
clock: 33MHz
*-isa
physical id: 1f
version: 03
width: 32 bits
clock: 33MHz
*-ide:0
physical id: 1f.1
logical name: scsi0
version: 03
width: 32 bits
clock: 33MHz
*-cdrom
vendor: TSSTcorp
physical id: 0.1.0
version: SB00
*-ide:1
physical id: 1f.2
logical name: scsi2
version: 03
width: 32 bits
clock: 66MHz
*-disk
physical id: 0.0.0
version: 2SS0
*-volume:0
vendor: Linux
physical id: 1
logical name: /
version: 1.0
capacity: 286GiB
*-volume:1
physical id: 2
capacity: 11GiB
*-logicalvolume
physical id: 5
capacity: 11GiB
capabilities: nofs
*-serial UNCLAIMED
description: SMBus
physical id: 1f.3
version: 03
width: 32 bits
clock: 33MHz
*-battery
physical id: 1
slot: Rear
capacity: 1000mWh
bjorn@zepto:~$
Re: Webcamera
Nä, jag hittade inget där heller. Om du provar med lsusb och postar det också?
Re: Webcamera
Här har vi den.
bjorn@zepto:~$ sudo lsusb
Bus 007 Device 001: ID 0000:0000
Bus 006 Device 002: ID 13d3:3220 IMC Networks
Bus 006 Device 001: ID 0000:0000
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Re: Webcamera
Ursäkta glömde att slå på kameran.
Bus 007 Device 002: ID 0402:5602 ALi Corp. Video Camera Controller
Re: Webcamera
Hade du kameran igång när du lshw innan?
edit: lade till ny fråga
Kan du testa i Ekiga. Många kameror fungerar där. Välj V4L2 som drivers. Vilket program har du försökt använda tillsammans med kameran?
Re: Webcamera
Tror det, men jag har suttit och pillat fram och tillbaka så jag skickar igen för säkerhets skull.
zepto
product: Znote
vendor: Zepto
serial: 773CS00230
width: 32 bits
*-core
product: Znote
vendor: Zepto
physical id: 0
serial: 773CS00230
*-firmware
description: BIOS
physical id: 0
capacity: 960KiB
*-cpu
description: CPU
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.11
slot: U2E1
capacity: 2401MHz
width: 64 bits
*-cache:0
physical id: 5
slot: L1 Cache
capacity: 64KiB
*-cache:1
physical id: 6
slot: L2 Cache
capacity: 4MiB
*-memory
physical id: 16
*-bank:0
physical id: 0
slot: M1
width: 32 bits
*-bank:1
physical id: 1
slot: M2
width: 32 bits
*-pci
physical id: 100
version: 03
width: 32 bits
clock: 33MHz
*-pci:0
physical id: 1
version: 03
width: 32 bits
clock: 33MHz
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
*-usb:0
physical id: 1a
version: 03
width: 32 bits
clock: 33MHz
*-usb:1
physical id: 1a.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:2
physical id: 1a.7
version: 03
width: 32 bits
clock: 33MHz
*-multimedia
physical id: 1b
version: 03
width: 64 bits
clock: 33MHz
*-pci:1
physical id: 1c
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
version: 61
width: 64 bits
clock: 33MHz
*-pci:2
physical id: 1c.1
version: 03
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 1c.2
version: 03
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 1c.3
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
logical name: eth0
version: 02
capacity: 1GB/s
width: 64 bits
clock: 33MHz
*-usb:3
physical id: 1d
version: 03
width: 32 bits
clock: 33MHz
*-usb:4
physical id: 1d.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:5
physical id: 1d.2
version: 03
width: 32 bits
clock: 33MHz
*-usb:6
physical id: 1d.7
version: 03
width: 32 bits
clock: 33MHz
*-pci:5
physical id: 1e
version: f3
width: 32 bits
clock: 33MHz
*-pcmcia
physical id: 6
version: 00
width: 32 bits
clock: 33MHz
*-firewire
physical id: 6.1
version: 00
width: 32 bits
clock: 33MHz
*-storage
physical id: 6.2
version: 00
width: 32 bits
clock: 33MHz
*-system
physical id: 6.3
version: 00
width: 32 bits
clock: 33MHz
*-isa
physical id: 1f
version: 03
width: 32 bits
clock: 33MHz
*-ide:0
physical id: 1f.1
logical name: scsi0
version: 03
width: 32 bits
clock: 33MHz
*-cdrom
vendor: TSSTcorp
physical id: 0.1.0
version: SB00
*-ide:1
physical id: 1f.2
logical name: scsi2
version: 03
width: 32 bits
clock: 66MHz
*-disk
physical id: 0.0.0
version: 2SS0
*-volume:0
vendor: Linux
physical id: 1
logical name: /
version: 1.0
capacity: 286GiB
*-volume:1
physical id: 2
capacity: 11GiB
*-logicalvolume
physical id: 5
capacity: 11GiB
capabilities: nofs
*-serial UNCLAIMED
description: SMBus
physical id: 1f.3
version: 03
width: 32 bits
clock: 33MHz
*-battery
physical id: 1
slot: Rear
capacity: 1000mWh
zepto
product: Znote
vendor: Zepto
serial: 773CS00230
width: 32 bits
*-core
product: Znote
vendor: Zepto
physical id: 0
serial: 773CS00230
*-firmware
description: BIOS
physical id: 0
capacity: 960KiB
*-cpu
description: CPU
vendor: Intel Corp.
physical id: 4
bus info: cpu@0
version: 6.15.11
slot: U2E1
capacity: 2401MHz
width: 64 bits
*-cache:0
physical id: 5
slot: L1 Cache
capacity: 64KiB
*-cache:1
physical id: 6
slot: L2 Cache
capacity: 4MiB
*-memory
physical id: 16
*-bank:0
physical id: 0
slot: M1
width: 32 bits
*-bank:1
physical id: 1
slot: M2
width: 32 bits
*-pci
physical id: 100
version: 03
width: 32 bits
clock: 33MHz
*-pci:0
physical id: 1
version: 03
width: 32 bits
clock: 33MHz
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
*-usb:0
physical id: 1a
version: 03
width: 32 bits
clock: 33MHz
*-usb:1
physical id: 1a.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:2
physical id: 1a.7
version: 03
width: 32 bits
clock: 33MHz
*-multimedia
physical id: 1b
version: 03
width: 64 bits
clock: 33MHz
*-pci:1
physical id: 1c
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
version: 61
width: 64 bits
clock: 33MHz
*-pci:2
physical id: 1c.1
version: 03
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 1c.2
version: 03
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 1c.3
version: 03
width: 32 bits
clock: 33MHz
*-network
physical id: 0
logical name: eth0
version: 02
capacity: 1GB/s
width: 64 bits
clock: 33MHz
*-usb:3
physical id: 1d
version: 03
width: 32 bits
clock: 33MHz
*-usb:4
physical id: 1d.1
version: 03
width: 32 bits
clock: 33MHz
*-usb:5
physical id: 1d.2
version: 03
width: 32 bits
clock: 33MHz
*-usb:6
physical id: 1d.7
version: 03
width: 32 bits
clock: 33MHz
*-pci:5
physical id: 1e
version: f3
width: 32 bits
clock: 33MHz
*-pcmcia
physical id: 6
version: 00
width: 32 bits
clock: 33MHz
*-firewire
physical id: 6.1
version: 00
width: 32 bits
clock: 33MHz
*-storage
physical id: 6.2
version: 00
width: 32 bits
clock: 33MHz
*-system
physical id: 6.3
version: 00
width: 32 bits
clock: 33MHz
*-isa
physical id: 1f
version: 03
width: 32 bits
clock: 33MHz
*-ide:0
physical id: 1f.1
logical name: scsi0
version: 03
width: 32 bits
clock: 33MHz
*-cdrom
vendor: TSSTcorp
physical id: 0.1.0
version: SB00
*-ide:1
physical id: 1f.2
logical name: scsi2
version: 03
width: 32 bits
clock: 66MHz
*-disk
physical id: 0.0.0
version: 2SS0
*-volume:0
vendor: Linux
physical id: 1
logical name: /
version: 1.0
capacity: 286GiB
*-volume:1
physical id: 2
capacity: 11GiB
*-logicalvolume
physical id: 5
capacity: 11GiB
capabilities: nofs
*-serial UNCLAIMED
description: SMBus
physical id: 1f.3
version: 03
width: 32 bits
clock: 33MHz
*-battery
physical id: 1
slot: Rear
capacity: 1000mWh
Re: Webcamera
Nope. Inget nytt under solen.
Vilket program har du använt tillsammans med kameran?
Re: Webcamera
Testat med Ekiga och Skype men ingen av dem hittar kameran.
Re: Webcamera
Man kan välja drivisar i ekiga. V4L2 funkar med webbkameran på pågarnas datorer. Var precis inne och testade kopete, amsn och ekiga.
Jag letar fortfarande efter några idéer på nätet när det gäller ali kameran.
Re: Webcamera
jo jag kör v4l2 och har provat v4l men inget hjälper
Re: Webcamera
Nä,, jag förstår.
Jag lyckades leta upp lite information på nätet när det gäller webkameran. De håller på att arbeta med en drivis för ali5602, men är inte färdiga med en fullt fungerande. Dock finns där instruktioner så att man kan testa drivisen.
http://atlas.hasselbalch.com/znote6625wd/
http://sourceforge.net/projects/m560x-driver/
Re: Webcamera
Får det här meddelandet när jag följer instruktionerna:
Ingen regel för att skapa målet "install"
Några ideer?
Några ideer?
Re: Webcamera
Har du installerat ubuntus build-essential? Ubuntuinstallationen behöver lite program för att kunna bygga andra program och de installeras inte som standard. Så starta en terminal och
Sedan hoppas vi på att du kommer vidare med din kameradrivis.
sudo apt-get install build-essential
Re: Webcamera
Tyvärr problemet ligger inte där det är installerat.
Re: Webcamera
Jag fipplade lite i en virtuel installation av kubuntu7.10. Fick det inte heller till att funka. Jag tror där är saker som fattas som gör att "make install" inte fungerar. Provade att köra samma kommandon i en annan mapp av det som laddades ner och där gick det bra.
Jag är ute och trampar lite vatten här eftersom min erfarenhet av att kompilera och kommandon relaterade till detta inte är så stor. Är där någon som kan lotsa oss tror du?
Re: Webcamera
När kommandot protesterar, prova att skriva
Sökvägen ovan förutsätter att du har kernel 2.6.22-14 installerad. Det kan du kolla genom
Ändra ifall den inte stämmer.
och sedan
Fortsätt sen med
Kolla av att modulen är laddad genom
Prova sedan att starta din webcamera och se om du kan få en liten bild. Håller tummarna!
sudo install -m 644 -o 0 -g 0 m5602.ko /lib/modules/2.6.22-14-generic/kernel/drivers/usb/media
uname -a
och sedan
sudo depmod -a
sudo modprobe m5602
lsmod
Re: Webcamera
Tack, men tyvärr:
bjorn@zepto:~/webcam/m560x-driver/m560x/branches/m5602-ov9650-2$ sudo install -m 644 -o 0 -g 0 m5602.ko /lib/modules/2.6.24-12-generic/kernel/drivers/usb/media
bjorn@zepto:~/webcam/m560x-driver/m560x/branches/m5602-ov9650-2$ sudo modprobe m5602
FATAL: Module m5602 not found.
