SV: Visa upp ditt skrivbord - tråd 1 (Conky)
- pl1sk3n
@ fysroger
Skulle du kunna lägga ut din conky här?
- fysroger
background no
font Verdana:size=6
xftfont Sans:size=8
use_xft yes
xftalpha 0.9
update_interval 3.0
total_run_times 0
own_window yes
own_window_type normal
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
minimum_size 220 5
maximum_width 220
draw_shades yes
draw_outline no
draw_borders no
draw_graph_borders yes
default_color white
default_shade_color black
default_outline_color green
alignment top_right
gap_x 12
gap_y 3
no_buffers yes
uppercase no
cpu_avg_samples 2
override_utf8_locale no
uppercase yes # set to yes if you want all text to be in uppercase
TEXT
${color orange}${font webdings:size=28}ø ${font Verdana:size=9}${color White}UBUNTU -GUTSY GIBBON ${font}
${font Verdana:size=8}DatorNamn: $alignr$nodename
${font xspiralmental:size=17}${color orange}E${font}${color} LINUX: ${kernel}
${font StyleBats:size=18}${color lightgreen}P${font}${color} TID SOM DATORN VARIT PÅ: ${uptime_short}
${font StyleBats:size=18}${color lightblue}4${font}${color} ${time %A %d %B}
${font StyleBats:size=18}${color orange}A${font}${color} CPU 1: ${cpu cpu1}%
${font StyleBats:size=18}${color lightblue}A${font}${color} CPU 2: ${cpu cpu2}%
${font PizzaDude Bullets:size=16}${color lightgreen}J${font}${color} Ram: $mem / $memmax
${color White}processer ${hr 1}${color}
$alignr CPU% MEM%
${top name 1}$alignr${top cpu 1}${top mem 1}
${top name 2}$alignr${top cpu 2}${top mem 2}
${top name 3}$alignr${top cpu 3}${top mem 3}
PROCESSORHASTIGHET: ${alignr}${freq} MHz
${color white}NÄTVERK ${hr 1}${color}
${font PizzaDude Bullets:size=16}${color lightblue}m${font}${color} Upp. ${upspeed eth0} Kb/s
${font PizzaDude Bullets:size=16}${color lightgreen}s${font}${color} Ner. ${downspeed eth0} Kb/s
${font PizzaDude Bullets:size=16}${color lightblue}M${font}${color} TotUpp. ${totalup eth0} Kb/s
${font PizzaDude Bullets:size=16}${color lightgreen}S${font}${color} TotNer. ${totaldown eth0} Kb/s
FRITT UTRYMME PÅ HDD: ${alignr}${fs_free /home} / ${fs_size /home}
${color}${fs_bar 4 /home}${color}
${font weather:size=28}${color orange}C${font}${color white}VÄDER ${hr 1}${color}
${execi 1800 /home/roger/conkyrc/weather.sh SWXX0015}
- pl1sk3n
Tackar , behöver göra en del ändringar så klart för att överenstämma med min sättning.
En fråga , dina ikoner blir bokstäver hos mig, varför??
- fysroger
Ursäkta dröjsmålet. Du behöver installera de teckensnitt som du ser namnen på i conkyn. dvs xspiralmental, StyleBats, PizzaDude Bullets, webdings, weather. Då bör det fungera. Spara .conkyrc i Västerlänsk (8859-15)
- joda
hur funkar det med få till vädret i conky ?
Jag laddade ner mina "väderfiler" härifrån: http://conky.sourceforge.net/weather.tar.gzjoda skrev: hur funkar det med få till vädret i conky ?
Tror det står mer om det i den här tråden: http://ubuntu-se.org/forum/index.php/topic,1957.0.html
- pl1sk3n
Ingen fara fysroger
Vi måste väll kunna ha ett liv utanför detta lr
Ska testa & se om jag kan få ordning på detta imorron.
Tack igen.
"edit stava som en kråka
"edit nr2"
Kunde inte vänta men körde fast direkt.
Var & hur installerar jag dessa teckensnitt?
Tack igen.
"edit nr2"
- fysroger
Gör först så här som root dvs
Kopiera de nedladdade och uppackade teckensnitten.Ska du installera xspiralmental och du har dom i din hemma mapp så blir det som följer
avsluta med att skriva fc-cache -f -v i terminalen
Fortsätt sedan så med de andra teckensnitten
lycka till.
sudo mkdir /usr/share/fonts/truetype/myfonts
sudo cp /home/namnetduloggarinmed/xspiralmental/X-SPIRAL.TTF /usr/share/fonts/truetype/myfonts
lycka till.
- pl1sk3n
Tack så mycket Fysroger
Alltid kul & pröva nått nytt
