Jag försöker fixa till så att Ardour hanterar VST Plugins men har redan stött på patrull. Enligt Ardour själva ska man göra följande:
Building Ardour 2.0 with VST support involves a few extra steps before the usual scons-based build.
1. Download the VST 2.3 SDK from Steinberg. At this time, we cannot provide you with any advice on where to get this from. Steinberg seems to regularly change the URL required to get the SDK. We recommend that you use google to search for it. Do not download the 2.4 or upcoming 3.0 SDK packages, since Ardour cannot currently use them.
2. put the VST SDK zip archive into libs/fst
3. make sure you have the Wine “development” package installed (typically called “wine-devel”)
4. run scons VST=1
After a successful build, run scons install.
Det faller redan på punkt 2 - jag har ingen katalog som heter libs/fst, ska den skapas eller? och i så fall vart? HJÄLP!!!
